BMW 3-Series (E90 E92) Forum
Failed at angel eye installation :(
05-25-2014, 01:48 PM | #1 |
Rep 62
Hey guys,
So I bought a set of these from Top Gear Solutions. I tried to install them today, but was ultimately unsuccessful. The directions provided with the bulbs seem woefully inadequate. I have the following questions: 1. Is there anything I need to harvest from the OEM bulbs, such as the plastic housing (with the oval thing) or the metal lens (is that a UV filter?) (see images below)? They appear to be inseparable from the OEM bulb. It ended up seeming like I might not actually need to take anything from the OEM bulbs. But I want to make sure. 2. Is there some trick I'm missing to getting the wires to stay connected? The connectors (pictured below) were very loose and would readily slip apart. I thought about just electrical taping them together, but the electrical connection itself was tenuous even when the connectors were physically together. I had to wiggle them to get the bulbs to light up. 3. At one point I decided to give up and just button everything up and leave the new bulbs in but disconnected. However, it appears that the bulky shape of these bulbs' heatsinks makes the plastic bulb recess cover (the cover that covers both the high beam bulb and the AEs) simply not fit at all. I could not see any way whatsoever to make the cover fit on with the TGS AE bulbs installed. Am I missing something? How do I get the cover back on? Ultimately I had to take the new bulbs out. I wanted to put the old bulbs back in, but I couldn't get the white plastic oval thing to fit over the oval fiber optic connection to the AE rings. So now I have nothing in the driver's side AE bulb recess. Last edited by Wycy; 05-25-2014 at 09:58 PM.. |
05-25-2014, 06:32 PM | #2 | |
Rep 1,185
2015 BMW M4 F83
2009 335i X-Drive | GC 2.0 Turbos (sold) 2009 335i e93 (Sold) 2007 Bmw X5 (Sold) |
