BMW 3-Series (E90 E92) Forum
HELP finding Accessory wire (push start 1 time) aftermarket radio
05-05-2014, 11:22 PM | #1 |
Rep 241
Could anyone tell me where to find a 12v accessory wire (push start 1 time) for the aftermarket radio? I've been searching a few days and everyone is tapping into cigarette or homelink fuse. I did try to tap into that too but the radio shuts off when stopping the car(push start) which i don't like. I did a reading with a multimeter on every fuse but all of them are either 12v constant or "on" position (push start 2 times, brake pedal off)
I took out the instrument cluster but i found it had a constant power and the switching is probably done internally The only place i found a switched push start 1 time is a wire on oem bluetooth harness in the trunk but it has between 4-11v. Maybe i should use a relay? don't really want or know how to do it. Should i try to check into emergency button on the dash (light comes on on push start 1 time) or is it the same as instrument cluster switched internally? please advice Last edited by constantin_md; 05-05-2014 at 11:56 PM.. |
05-06-2014, 09:37 AM | #2 |
Rep 5,120
With the right harness you won't have this problem. Mine stays on when you turn off the ignition and stays on for about 15 minutes or until you pull out the key.
http://www.dynamicsounds.co.uk/bmw-1...n-support.html |
05-06-2014, 02:55 PM | #3 |
Rep 25
The cluster would work on the can bus I would of thought. A can bus interface might do what you need and is the easiest way to be honest. It can be done at the rear of the stereo as long as it gets the can information it needs on the green and orange green.
As for the relay on the mulf standard 4 pin relay pin 85 from the wire you mentioned. 86 to ground 87 to live 30 to ignition live on stereo. |
05-06-2014, 03:12 PM | #4 |
Rep 2,366
Drives: 2007 E90 323i (Cdn)
I had the same issue with my aftermarket HU... There is a thread here that identifies which wire to use as a trigger to turn the unit on as soon as you put the key in ignition (no need to hit start).
Look through the threads I've posted to, it's one of them.
05-07-2014, 03:41 AM | #5 | |||
Rep 241
i never used one. ebay has cheap ones that are rated 40A 4 prongs. I also heard they require at least 5V trigger, in my case is 4v-11v variable Quote:
Also found this by "AMP" member Pin 4 of the CAS module (under the steering column). It's a Violet .5mm wire. In splice X8103 (in the passenger footwell under the dash. This one will be hard to find. It's a Violet wire... .5mm Pin 17 of connector X279 which is located in the "storage compartment" in the floor under the passenger seat. This is a strange 25 pin connector. On the car side it's a Violet .5mm wire and on the seat side of the junction it's a violet/blue .5mm wire. Pin 2 of connector X10218 which connects to the passenger seat occupancy sensor and is located on the underside of the seat itself. This is also a violet/blue .5mm wire. Pin 3 of the passenger airbag deactivation light (violet wire) thanks! Last edited by constantin_md; 05-07-2014 at 04:35 AM.. |
