BMW 3-Series (E90 E92) Forum
F/S E9x M3 Active Autowerke Underdrive pulley +12bhp
03-13-2014, 06:15 PM | #1 |
Rep 1,247
Another part stripped from my E92. This pulley is completely safe and really livens up the revs. Various sources report +12bhp on a stock M3.
Included are two belts of the correct size for single sided belt cars (these can be used but new items are only a few quid) and a set of bolts. Double sided belts can be purchased from Active Autowerkes. Fitment is straightforward. Fan out, slacken the tension on the belts, remove an idler, swap the pulley and reverse. Quoted from http://store.activeautowerke.com/act...ulley-p52.aspx This is a complete bolt on kit engineered using Aircraft Grade Billet 6061 Hard Coat Anodized Aluminum. After months of R&D in house and overseas (various climates & conditions) we concluded that there may be a slight power increase by going smaller than our pulley but the trade off is a chance of making the engine run hotter or possibly overheat (we noticed this in both DCT cars and Manual cars on and off the track), we choose reliability over that extra 1-2 rwhp that we may get from a smaller pulley. Testing in Miami, FL and in other hot climates was a must in our R&D process to take things to the “extreme limits”. Another key element in the development of the Signature Pulley Kit was to retain the “Factory Crank hex Drive Adapter”, this was important to keep this factory feature for its inherent purpose. The pulley kit does not modify factory harmonics or dampening. Stronger side walls were the last key element in choosing our size over a smaller design. The Active Autowerke E9X Signature Pulley Kit yields gains of 12+HP on a completely stock car This is a complete bolt on system that is easily reversible. A must for the true enthusiast. Key Features: * HP gains: 10 RWHP ~ 12+ HP * Complete Bolt on System and is easily reversible * Aircraft Grade Billet 6061 Hard Coat Anodized Aluminum * Retains Factory Crank Hex Drive Adapter * Includes Replacement DRIVE and A/C Belts * Does Not Modify Factory Harmonics or Dampening * Compatiable for DCT and Manual models * Reduces Rotational Mass * Does not cause overheating found in smaller pulley designs These are $540 delivered which is around £325 at current exchange rates. I looking for £195 delivered. |
