F30POST
F30POST
BMW 3-Series and 4-Series Forum (F30 / F32) | F30POST > Technical Forums > N20, N26, B46, B48 Turbo Engine / Drivetrain / Exhaust Modifications > N13 1598cc 100kW engine tuning
ARMA SPEED
      09-10-2013, 09:06 AM   #1
Funkier
Drives: F30 316i + F54 Cooper
Hi guys,
I drive 316i f30 2012. Recently the same engine is being sold as 320i ED and the horsepower capacity is increased by 25% via software I guess.
Any of you familiar with engine tuning? May I code my ecu to act as a 320i ED? Same engine same hardware same gearbox
      12-29-2013, 06:38 AM   #2
Tommy_hf
Netherlands
70
Drives: F36 CQ M, Z4 E85 3.0iS MSL SC
The engine is very similar, but the camshafts in the 316i are different. Both inlet and outlet cams. They allow the car to reach the peak hp at 4400 rpm already and torque starting 1250 rpm up to 5000 rpm. In the 320i ED peak hp starts at 4800-6450 and torque 1500-5000 rpm.
racechip and other companies make plug in tuning kits giving the 316i decent power. There are youtube video's of the racehip ultimate in 316i, mostly from Turkey as well. I just wonder how reliable those tuning boxes are. The engine should cope with it fine. The engine is basicly the N18 mini cooper S engine, so buying hardware upgrades for Mini cooper S N18 should work, I think. (alta blow off valve spring, turbo upgrades) and look into the bastuck downpipe back exhaust. It deals with the small diameter exhaust as the 316i and 320i ED have the same 63,5 mm downpipe diameter, but on the 316i, 320i ED and 320i the front connecting pipe is about 60 mm, mid pipe on the 316i and 320i ED 52,5 mm, 320i 60 mm and on the 328i it's full bore 76 mm front to back. Bastuck replaces the small diameter piping with 76 mm. The exhaust systems are all the same for the 4 cyl F30, but include a large bore front connecting pipe for the N13 versions.
      01-07-2014, 10:20 AM   #3
Mike@N54Tuning.com
Drives: 2007 335i, 2015 M3
BMS makes the most popular MINI N18 tune. It's possible the same tune will carry over to all of the BMW 1.6l gasoline engines. But since those cars are not in the USA BMS has not done much testing with them.
Mike
      01-07-2014, 11:36 AM   #4
Tommy_hf
Netherlands
70
Interesting,
And then there's Steinbauer who supplies the tuning kits to AC-Schnitzer.
Are the tuning kits different for the Mini , BMW 1-series F20 and F30 3-series?
      01-10-2014, 11:23 AM   #5
Mike@N54Tuning.com
Interesting,
At least for the N18 MINI it's a different product than the N20 2L products. If you email BMS photos of your engine bay maybe they will send you a free tune to test out and verify everything works as it should be.
Mike
      01-23-2014, 09:26 AM   #6
rpagianotto
Drives: F22 m235i 8AT
I e-mailed the folks at BMS asking if the Mini JB+ would work on the n13 (I own an 118i) and they said they are working on it! Let's see what they come up with!
      07-29-2018, 03:36 AM   #7
F30 316i
Drives: Bmw f30 316i m sport (2015)
do u know whats the max hp and torque my 316i f30 2015 could take? i have everything stock except k&n drop in aor filter.
thanks for the answer. btw one company said to me they would remap my ecu to 210hp and 320 nm tq. is that max or could i look at higher numbers.
      08-06-2018, 03:33 AM   #8
Galaxy1223
Drives: 316iA F31
I also have 316i (A). I still have the BPS warranty ongoing but after that I am planning to remap my car. I was asking from one quite reliable place and they stated that after remap hp will be 200 to 210 and maximum safe torque out of automatic transmission is 330-340Nm. To my understanding the turbo is the limiting element so thats why everyone is telling about the same numbers.
f30post
