08-23-2013, 10:46 AM | #1 |
Rep 344
Drives: 2019 BMW M760li
I read a post here not long ago about some folks experiencing hesitations on acceleration and flat spots. I have been getting these on and off for awhile now and have noticed a slight decrease in performance recently. Cars been to the dealer about it but no fix. I use 93 octane and have been using octane boost and cleaners regularly. I even ran a half tank of 105 race fuel to clear everything out. With direct injection I doubt the cleaners will do much good and I still haven't seen much improvement.
Someone mentioned they used sea foam and it worked quite well. Could someone point out where to pour/spray the sea foam into the vaccuum line on a 328 N26? I don't need an argument about sea foam I just need someone who's successfully ran the cleaner through the intake to chime in for me. Thanks guys! |
08-23-2013, 07:09 PM | #2 |
Rep 1,659
Drives: 2022 WRX World Rally Blue
Seafoam
Just put in directly in your gas tank.
08-23-2013, 07:22 PM | #3 | |
Rep 344
08-23-2013, 10:16 PM | #4 |
Rep 1,659
Seafoam
I guess I didn't understand. If you put it in the gas tank, wouldn't it travel through the injection system. I've used it and I'm a believer for sure.
08-23-2013, 11:05 PM | #6 | |
Rep 1,436
Then I took the risk and cleaned pcv valve but I didn't use seafoam, then all hesitation was fixed Last edited by rustyminded; 08-24-2013 at 03:42 AM.. |
08-24-2013, 04:24 PM | #7 | |
Rep 1,397
do you have pictures? thanks |
08-28-2013, 09:28 AM | #9 |
Rep 20
Guys as far as Sea Foam goes, is there a maximum recommended frequency of use?
With their recommendations, 1oz per gallon means 1 full bottle for the car's 60 Litre tank. How many KM's between uses would be recommended? Once every oil change makes sense, but I don't want to overdo it if there can be potential harm to gaskets, rings etc.. (even though their product literature says it's safe for those components). |
08-28-2013, 11:52 AM | #10 | |
Rep 1,436
08-28-2013, 12:38 PM | #11 |
Rep 20
08-28-2013, 03:31 PM | #13 |
Rep 1,436
08-29-2013, 09:17 AM | #16 |
Rep 1,029
Drives: 2019 440xi Gran Coupe
Which sea foam do you guys use
08-29-2013, 12:30 PM | #17 |
Rep 20
This one: http://www.canadiantire.ca/AST/brows....jsp?locale=en
I just put 1 bottle in each of my 2013 328x and my 2008 528x. Let's see how it works out. |
08-29-2013, 01:08 PM | #18 | |
Rep 1,436
08-29-2013, 01:18 PM | #19 |
Rep 20
09-07-2013, 06:34 AM | #20 |
Rep 1,029
09-07-2013, 06:58 AM | #21 |
Rep 1,436
