E90Post
Studio RSR
BMW 3-Series (E90 E92) Forum > E90 / E92 / E93 3-series Technical Forums > Cosmetic and Lighting Modifications (exterior/interior) > H8 Angel Eye (Reflector?)
Reply
      08-08-2013, 10:57 AM   #1
gwake1
Drives: 2006 325XI
2006 BMW 325xi  [0.00]
Simple question.
Is the reflector attached to the OEM reusable for any H8 bulb upon replacement?
I am not interested in buying sole aftermarket angel eye upgrade bulbs/kits.
I have to run into my B&M to replace tail light bulb and would like to replace the angel eye bulbs.
After doing some research, every DIY I have come across is for an aftermarket kit.
My question is if any H8 bulb can can be used to insert into the reflector/condenser part that is SCREWED into the housing for the light source to the angel eyes?
e90 2006 325xi
      08-08-2013, 11:15 AM   #2
LuxAngelEyes
LuxAngelEyes's Avatar
i believe the answer would be yes. if you are trying to replace a H8 bulb with a different H8 bulb then it should be perfectly fine.
If you have a 2006 325xi then your car doenst use H8 bulbs for the angel eyes however, they use a unique bulb that you cant find a simple replacement for.
Reply
Tags
angel eye, angel eyes, cosmetic, diy, lighting
e90post
