06-25-2013, 10:42 AM | #1 |
Rep 623
50% mixture of E85 fuel and 91 octane: harmful?
Would such a combination harm the engine? Or void the warranty if some (not necessarily related) issue comes up and the dealership blames it on the fuel mix?
Because my eyes are popping out when I see the gains on JB4 Stage 2 ...
Enjoying: 2014 Yamaha FZ-09 | 2015 Lexus GS 350 | 2015 Lexus RX 350
Past affairs: 2014 Lexus RX 350 | 2012 BMW 328i Sport | 2009 Audi A4 2.0T | 2007 BMW 750Li | 2006 Kawaki Ninja 650R | 2004 BMW 530i | 2004 BMW 520i | 2001 BMW 530i | 2003 Opel Vectra | 2002 Citroen Xsara |
06-25-2013, 11:47 AM | #2 |
JB4 King
Rep 29
Only if your car runs too lean on it. Best to make sure what your AFR is, when running the mix....
06-25-2013, 11:54 AM | #3 |
Rep 808
Well mixing anything that's 85% alcohol vs 10% can be harmful (giving you a fuel with roughly 45-50% alcohol content depending on your mixing).
If they were to find out, they could void your fuel pump, fuel lines could corrode which would leave you with that bill, and they could then void anything down the line from that (including your motor). They would, however, have to prove that caused the damage. |
06-25-2013, 04:28 PM | #4 |
Rep 623
So using E85 in a N20 - without serious side effects - it's out of the question, right?
06-25-2013, 04:44 PM | #5 | |
Rep 3,206
e92 ///M3 |
06-26-2013, 08:24 AM | #6 |
Rep 453
I add 3 gallons of E85 to each tank, unless I am on a long highway run and want the better gas mileage. On the couple of occasions that I have taken it to the track, I use 50/50 e85 just to be safe. Been doing this for a few months now and it seems ok. No predicting the long term effects but so far so good.
06-26-2013, 06:36 PM | #7 |
Rep 336
Drives: 2012 328i
It made my engine light go on.
06-26-2013, 09:13 PM | #8 |
Rep 623
Did it go away after you got back to just gasoline?
06-27-2013, 01:01 AM | #9 |
Rep 336
Drives: 2012 328i
06-28-2013, 09:27 AM | #10 |
Rep 453
The fuel would not make your check engine light go on. I have used multiple tanks of the stuff and never gotten a CEL. Something else was amiss...
06-28-2013, 02:47 PM | #11 | |
Rep 234
http://www.realoem.com/bmw/showparts...17&hg=13&fg=15 |
08-19-2013, 11:16 PM | #14 |
Rep 3,523
People are joking here about running E85 in a car designed, manufactured and materials carefully selected for Premium octaneTop Tier unleaded fuel??
None of the parts of your fuel delivery system is designed for E85 or even mixtures of. |
08-20-2013, 03:07 AM | #15 | |
Rep 556
Drives: 2012 BMW 335I
I agree with you though, if you fill up all of your tank or even a majority of it with E85, it will run too lean..I run the tune, and I prefer 100 octane over the E85, even though dynos show E85 has more HP and people say runs better than 100 octane.. I personally run a mixture of 100 octane, and if I do put E85 in now, it is only a couple of gallons mixed in with that. Runs fine. Or if I can't get to some 100 octane, i'll mix some 91 octane with 2-4 gallons of E85, and that gets me by and feels fine until I get to a place with the 100. (actually did that today) I think you just don't want to over do it, moderation isn't going to hurt.. |
08-20-2013, 11:50 AM | #16 |
Rep 3,523
No amount of E85 is acceptable.
The 10% of ethanol in our fuel is still a push on the elastomers in the fuel system. BMW is stuck supporting the NA market with that ethanol content. Nobody else in the world does it cause its stupid. Anyone here can do anything you won't, run nitro if you want, I am telling you no you can't run any E85 in your car. Anyone here who says you can has no evidence, no support and no discussion with BMW, they are just doing what they want. It's your car, your money and your warranty, do what you want. The fuel system isn't designed for it and if you have problems BMW will find evidence to throw you under the bus. They aren't idiots. |
08-20-2013, 08:04 PM | #17 |
20
Rep 688
08-20-2013, 08:35 PM | #18 |
Rep 808
BMW has already come out and said they won't cover any damage done by E15... nonetheless E85.
How they will know? Who knows. They'll make up a reason and you have to prove your innocence. |
08-20-2013, 08:52 PM | #19 |
Rep 3,566
Info on inside of my car's fuel filler cap states/warns not more than 10% ethanol in the fuel mix.
08-21-2013, 09:17 AM | #20 |
Zooombie attaaack!!
136
Rep 1,179
