F30POST
F30POST
BMW 3-Series and 4-Series Forum (F30 / F32) | F30POST > Technical Forums > N20, N26, B46, B48 Turbo Engine / Drivetrain / Exhaust Modifications > Strange stuttering after starting the car sometimes.
Studio RSR
      05-13-2013, 06:58 PM   #1
superkevx
Drives: f30 sport line
Recently I put in an AFE intake and scorcher on my 328i sport line. Everything seems OK but sometimes when I start the car the engine seems to stutter/rumble for about 2-3 seconds. It's pretty scary and the tachometer will fluctuate up and down during these 2-3 seconds. After that it settles down and the car appears to be perfectly fine. Its happened 3-4 times already and I'm worried one of the AFE mods might be damaging something. Any ideas? I don't know much about cars.
      05-13-2013, 09:37 PM   #2
ScarecrowBoat
Zooombie attaaack!!
ScarecrowBoat's Avatar
Drives: 328
How much fluctuating are we talking about? 100 RPM? 1000 RPM?
      05-13-2013, 09:55 PM   #3
David328M-Sport
Australia
101
Reset your car to stock & test over a few weeks. If all is ok, then introduce one aFe mod at a time & test. Hope you find a solution.
      05-13-2013, 11:40 PM   #4
superkevx
I'd say 1-200. I may just start taking things off but would like to avoid the hassle if anyone has any idea why it's happening.
      05-14-2013, 01:15 AM   #5
tricksterr24
Drives: 2012 328i
2009 328 sulev  [0.00]
That has happened to my car a few times and I don't have any mods.
      05-14-2013, 02:33 AM   #6
Joshhleee
///M Enthusiast
Joshhleee's Avatar
Drives: '12 F30, '15 x5 5.0, '15 M4,M5
same thing happens to me, i have the bms stage 1 chip.
      05-14-2013, 10:06 AM   #7
ScarecrowBoat
Zooombie attaaack!!
Drives: 328
That's normal. Mine actually used to do it until I installed BMS Stage 1
      05-14-2013, 10:28 AM   #8
reedo302
Estorilblau Member
reedo302's Avatar
Drives: Dinan Estoril 328i M Sport
Mine does it, and I'm stock
      05-15-2013, 12:26 AM   #9
slmdgee
Usofstance
Drives: 328I 6SPD
normal, In Europe they dont have this issue cause because the fuel their is cleaner.Main reason to the idle issue and not only do bmws get it but audis,volkswagens etc. Info via a master tech.
2013 328i 6MT Bagged
IG Stu_UnitedStatesOfStance
United States Of Stance
      05-15-2013, 02:46 AM   #10
topcat87
Drives: F30
try out some Nos octane booster race formula w/ mmt it should smooth things out
      05-15-2013, 12:59 PM   #11
superkevx
thanks for the info guys. I've just been using 91 shell gas in socal since it's close to my work. I'll try other places and see if it helps.
      05-16-2013, 01:15 PM   #12
BRM6
BRM6's Avatar
Brazil
11
Drives: 328/335/M235i/M4 - Current M6
Also happens a few times on mine. 95 octane (E20)
      05-25-2013, 11:53 AM   #13
HiiiPowerrrrrr
Drives: 2013 328i Sportline, N26engine
This also happened a few times to me while my car was stock..
      05-30-2013, 08:13 PM   #14
dli1237
Drives: 13 328xi
Not sure if its the same. Just happened to my car
Stalled once, rough idle rpm fluctuating. Car attempts die sitting idle.
Turned out 2nd cylinder injector at fault
More fuel than needed spark plugs burnt.
Both replaced at dealership took five days to get parts
All good now finally.
      05-30-2013, 08:42 PM   #15
crex11
Drives: 13 328i Msport
assuming this is an issue with the factory tune, hopefully BMW makes an update for these cars fixing the problem.
      06-03-2013, 02:00 PM   #16
kppanic
Drives: 2015 Macan S
I just noticed in the past week or so, when I turn on the engine from an overnight parking and start to go right after, the car "surges" forward, feels like it has a small amount of "explosive" forward momentum, it's hard to describe, it's like it's on race gas boost or something.... It "jolts" forward, would be a more appropriate description... It goes away after about 20 sec of driving, but this jolting started happening recently.
I wonder what's going on??
      06-05-2013, 07:41 PM   #17
mjmonjure
mjmonjure's Avatar
Drives: 2013 F30
My 2013 328i had the same fluctuation and I called the dealer. They said its common and normal as long as the idle does not drop to the point of killing.
Slightly off topic, but how is the AFE kit working? Are you getting a noticeable boost? I am just waiting for some mad money to come in so that I can buy the intake/scorcher combo.
      06-05-2013, 11:33 PM   #18
superkevx
I hope this problem clears up eventually or something. It's annoying and scary.
I had the bms stage 1 tune before this and when I took that off I put both the afe scorcher and intake on at the same time. The main noticeable difference is that the engine is louder, there's a hearty rumble from it when I accelerate. The boost feel is pretty similar in both cases. Maybe faster in comfort mode for afe and faster in sport mode for bms. I liked both and just wanted to try something different. I don't have any real stats to back up what I said though but you'll definitely be happy with the combo.
      07-30-2014, 11:21 AM   #19
retiredmarine
Drives: 2014 328i msport
I just posted a thread about this. my car is stock, and it seems to be kinda rough or chattery at cold start sometimes, then smooths out. guess this is normal? anything to do with the turbo spooling up?
      07-31-2014, 10:05 PM   #20
Tiago@VRSF
Tiago@VRSF's Avatar
Drives: F90 M5
Seems normal, cold starts tend to be a bit difficult for this motor.
      08-01-2014, 04:58 PM   #21
Sherhart
Sherhart's Avatar
90
Drives: 2016 M4 Vert & 2015 RR Sport
I get this first start in the AM almost every day with no intake. If you feel it is really severe, try taking the intake off to see. The intake could also be messing up the MAF and amplifying the issue.
Jim
      08-18-2014, 06:29 PM   #22
TomDenmark
TomDenmark's Avatar
61
Drives: 14' 320i ActiveFlex
Something similar happened to my car last week, but much worse.
The car would start and studder heavily and die after 5-10 seconds.. Happened 4-5 times in a row. I tried to get some life into it by pressing the accelerator, which only killed if faster. Anyway tried it one more time and this time reving it a bit helped, and all was back to normal.
I have no clue what this was about, only happened this one time.
But the reason could be that I was up in 6000ft above sea level and my airfilter was probably a bit dirty from driving on a dirt road.
The car is completely stock
f30post
