F30POST
F30POST
BMW 3-Series and 4-Series Forum (F30 / F32) | F30POST > Technical Forums > Cosmetic and Lighting Modifications (exterior & interior) > M-Sport Rear Reflector DIY?
proTUNING Freaks
      04-28-2013, 12:44 PM   #1
fricfracfrank
fricfracfrank's Avatar
Drives: 2019 X3 M40i
IND M-Sport Rear Reflector DIY?
I see all the information and DIY instructions for replacing the front reflectors but after searching for a while I can't find a detailed guide to replacing the rear reflectors especially with m-sport bumper.
Any help is greatly appreciated!
Present: 2019 X3 M40i Phytonic Blue
Past: 2013 335i xdrive Estoril Blue
2011 328i xdrive Black Sapphire Metallic
      04-29-2013, 03:01 PM   #2
fricfracfrank
Anyone? IND where are you with some help
      05-02-2013, 06:57 AM   #3
spindiesel
spindiesel's Avatar
Drives: 2024 M3 Comp X drive
I took my rear fascia and reflectors off and plasticoated them black. Super easy.
      05-02-2013, 07:02 AM   #4
R12ax7
R12ax7's Avatar
120
Drives: 2021 340xi
2011 328i  [0.00]
Pics?
Current: 2021 340xi
Retired:
2018 330xi | 2016 340i 6MT | 2013 335i 6MT |
2011 328i 6MT (N52) | 2008 335xi (N54)
      05-02-2013, 10:24 AM   #5
fricfracfrank
Yea where are the pics...or at least description haha
      05-02-2013, 11:52 AM   #6
n55x3
Drives: n55 BMWs
They take 2 minutes to remove. If you are looking at the back of the car there are 3 clips on each reflector. For the first reflector removal I'd lay on your back under the rear of the vehicle (once you do it once you can remove them without crawling under). Press in the clip that is closet to the middle of the car and push outward lightly. This will undue the inside clip, then for the middle clip you have to press down and push lightly. The third clip (the one towards the outside of the car) isn't so much a clip as it is more of a hook to hold the reflector in. When the inside and middle clips have been depressed you can just push on the reflector and it will pop out.
I just pulled mine out a couple days ago to tint them. Did a mock up by putting some clear tape on them and cut that to shape. Then sprayed VHT niteshade to tint them relatively dark. After I reinstalled them I decided it was a little odd looking on my MSport so I simply pulled the now tinted clear tape off and reinstalled the reflectors. I may decide to paint them the same color as the diffuser at a later date.
      05-02-2013, 01:50 PM   #7
fricfracfrank
THANK YOU! I just didnt want to start ripping them off and ruin anything.
      05-04-2013, 06:33 PM   #8
IM2C
IM2C's Avatar
2069
Drives: ∞ Improbability Drive
Did you mean "plastidip"?
///| g87 | f87 Comp | g29 M40i | f97 Comp | f80 Comp | f80 | f30 | e92 | tt | S5 | e92 | 350z | e90 |
      05-30-2023, 11:57 PM   #9
SPod23
SPod23's Avatar
Drives: '10 528, '13 AlpinaB7, '16 328
2013 Alpina B7  [0.00]
2010 BMW 528iX  [0.00]
Anyone installed LED rear reflectors? pop in just like the red reflectors pop out, but I'm not sure how to wire them up... im assuming to the tail light some how?
      05-31-2023, 08:31 AM   #10
Oksamit78
Oksamit78's Avatar
Drives: E39, F30 & F34
1. Which functions did you get? - Parking lights/brake lights double function (brightness difference) or parking/brake/turns?
2. Are the LEDS COB (diffused light beam over the full surface of reflector) or a single/double string of LEDs along the reflector?
Example of double string LED reflector:https://www.aliexpress.com/item/3289...7295074&isdl=y
Yes, you will have to wire to the tail lights. If no turns' function, you could wire both LED reflectors in series to one side (left or right). If triple function with turns - then will have to wire to individual sides separately.
Post some pics before/after/in operation...
2003 E39 530i 5-Speed w/ M Spec, Saphire/Black, M54B30, Active Autowerke Performance Tune
2010 Lancer GTS 5-Speed, Black Pearl/Black, 4B12
2015 F30 335i XDrive w/ M Sport Pack, Alpine White/Black, N55B30M0
2017 F34 340i XDrive w/ M Sport Pack, Azure II /Black, B58B30M0, Dinan Stage 1
      04-15-2024, 08:06 PM   #11
Salty B.
Drives: 2014 335i 6MT MSport
I know this is an ancient thread, but I tried removing mine tonight (w/M-Sport) and it seems they're snapped into a well molded into the bumper cover as in there's no access to the reflector itself from the back of the bumper cover (I contorted myself quite a bit to reach in there and have a bunch of nice new cuts and scrapes for it), and although I was able to wedge a trim tool under the middle was unable to get it to pop out so I could apply a blackout film.
So how the hell do these come out? There isn't any double-sided tape strong enough to yank these things out based on the fight they put up.
2014 F30 N55 6MT, gray/red, M-sport, VMR 710/Mich PS 4S, MPPK, MPE
2001 E53 M54 5MT peeling green/black, well-optioned
      04-16-2024, 07:46 AM   #12
Oksamit78
Oksamit78's Avatar
If you are talking about the FRONT bumper reflectors, then - yes, they are installed using a double sided acrylic tape (3M). In order to remove the reflectors without cracking them or breaking them off the substrate (orange reflecting lens is mounted on the grey or white backing plate) you should heat-up the area and the backs of them so that the tape becomes much more softer. Do not overheat the bumper itself - could cause damages to paint.
This is a non-M bumper/reflector shown, but the mounting process is the same:
      04-16-2024, 09:06 PM   #13
Salty B.
Originally Posted by Oksamit78 View Post
If you are talking about the FRONT bumper reflectors...
Sorry, maybe I was not clear. I mean the REAR red M-Sport reflectors.
I replaced the amber fronts with gray ones. That was a pain in the ass removing the old adhesive which must be done else the new ones will not sit flush with the bumper cover.
Nobody seems to make gray replacements for the rears; I don't want to paint them for insurance reasons and I have a roll of transparent gray film to apply, but I need them OUT to do that!
      04-18-2024, 07:48 AM   #14
Oksamit78
Oksamit78's Avatar
... but I need them OUT ...
Take a look at the image I've put together for you. It describes removal of the RIGHT side rear reflector:
I had the reflectors out for cleaning while replacing the stock rear diffuser with aftermarket M Performance diffuser. So you might have to take the diffuser out first in order to reach the tabs shown above. The diffuser is easy to remove as it is held in place with a couple screws and plastic pull-out rivets from the bottom and with series of tabs at the top split line.
Installation is in reverse order of the steps in the image.
Good luck.
      04-22-2024, 09:26 PM   #15
Salty B.
Good luck.
Thank you!! I don't have a diffuser so this should be e.z. But I had friends ask me about the "burn" on my arm. "Nah, just lost some skin on a sharp thing..."
      04-23-2024, 05:21 PM   #16
andyb313
Drives: F32 440i RWD
I just did mine on the weekend and wrapped in black vinyl, for the left side i was easilly able to get my hand behind and push out the clips, for the right hand side i removed the 2 screws of the rear diffuser to the far right, pulled off a couple of the diffuser clips on the right and it was enough to allow me to get my hand behind there and push the reflector clips
      05-05-2024, 11:41 AM   #17
WeAreVenom
WeAreVenom's Avatar
9
Drives: 2016 BMW F32
I tinted my rear reflectors, not a fan of them just being body color. I used precuts so I didn’t have to bother removing them
      05-06-2024, 08:19 AM   #18
Oksamit78
Oksamit78's Avatar
Same here (but wrapped in place) on side and rear reflectors and I've used Vvivid+ Bio Hex+ Micro Smoke Tint.
Also, wrapped the tail lights with the same film to tone down the red color:
      05-07-2024, 06:53 PM   #19
Salty B.
Where did you get the film?
      05-07-2024, 06:56 PM   #20
WeAreVenom
WeAreVenom's Avatar
9
rvinyl.com
f30post
