03-14-2013, 12:15 AM | #1 |
Rep 1,201
328i M peformance exhaust hp gains?
Since active autowerke claims 9hp/13tq, does that mean that power can be gained from the M performance exhaust as well?
03-14-2013, 12:52 AM | #3 | |
206
Rep 7,298
03-14-2013, 01:10 AM | #4 | |
Rep 3,566
More meaner than leaner. Ok, so it's not even leaner. At all.
03-14-2013, 03:06 AM | #5 |
Rep 3,780
I saw 7whp 20ft lbs with a catback. That was likely mostly muffler. I would say the MP units likely give little hp, within variance in dyno runs, say 2-3whp.
'98 Dinan/RMS stage 2+(VAC cams, CES Cutring etc) '15 Buick Regal "T"(wife) '06 Saab 9-5 Combi 5mt (full suspension, LSD, clipped turbo etc) |
03-14-2013, 08:54 PM | #6 |
Rep 1,105
03-26-2013, 09:35 PM | #7 |
Feeling horny
36
Rep 152
I've just installed my m performance exhaust for my 328i.
Although I don't think there's any said hp gain but I can feel a little more power from it and the turbo sounds a bit louder too. Must be from the better air flow. So far I'm loving the exhaust, a little bit louder would suit me more, so by time when I get my bms and dp that should sort out all my problems. Cheers
BMW F30 328i Sport Line
03-26-2013, 10:17 PM | #8 |
Rep 1,029
Drives: 2019 440xi Gran Coupe
Is there a resonator on the 328? I see a can near the middle and not sure if that is the resonator or cats?
03-26-2013, 11:50 PM | #9 | |
Rep 145
03-27-2013, 06:34 PM | #10 |
Rep 1,029
05-26-2014, 11:06 AM | #11 |
Rep 1,029
05-26-2014, 11:42 AM | #13 |
Rep 1,436
05-26-2014, 03:31 PM | #14 |
Rep 3,288
Drives: anything given a chance
First time I've read there's a cc in that section of the exhaust. Last I knew there was one in the mid- and one in the down-pipe. From your other post your AA system is also droning, which I have to say I wouldn't be a fan of.
05-26-2014, 04:10 PM | #15 |
Rep 1,436
yes it does drone if you installed CATLESS downpipe too not alone of course and not all the time just certain times in hot weather ONLY but given the sound everyone is going crazy what exhaust is making that sexier sound than a stock 335i, no one believes this is coming from a 4 banger.. aside all that maybe what's causing the drone is a leak
05-26-2014, 05:08 PM | #16 |
Rep 1,029
is cat the same as resonator? I was referring to the resonator that is located smack in the middle of the pipes. I know the downpipe is in the front.
Add a catless downpipe and it will definitely change the sound but not planning to do that yet. Just bought the MPE and wanted a bit more sound from it and therefore was considering in removing the resonator and replace it with a straight pipe. Would that do anything of will it just make the interior noise worst. |
05-26-2014, 07:06 PM | #17 | |
Rep 3,288
05-27-2014, 09:33 AM | #18 |
Rep 3,780
