F30POST
F30POST
BMW 3-Series and 4-Series Forum (F30 / F32) | F30POST > Technical Forums > N20, N26, B46, B48 Turbo Engine / Drivetrain / Exhaust Modifications > Late production change to the N20?
ARMA SPEED
      02-07-2013, 08:02 PM   #1
Jamesons Viggen
Drives: '98 M Roadster stg 2+ S/C
So I went to install my BMS stage 1 today.
I know it works on both N20 and N26.
From what I had read, at first all manuals were N20's. Then I read that later on in production N26's were replacing N20's, and so some people were seeing N26/6mts.
I was told the way to spot an N26 was the electric boost solenoid on top of the turbo.
So I got to do the install and the first sensor I am supposed to tap is not there. I take a few pics, figure I would send them to BMS. I looked at the pics and thought man, that is what the N26 solenoid is supposed to look like. WTF, do I have an N26?
Sure enough, Terry confirmed.
I either have an N26, or in my later production run of 7/12, they began using the N26 electronic solenoid on the N20.
When I looked up my VIN, it clearly states N20.
For those who don't know what to look for, see this pic, this is what your turbo will look like if you have the solenoid. If your VIN comes up N26, that's to be expected, but if you have an N20, then it might be interesting to share your build date.
'98 Dinan/RMS stage 2+(VAC cams, CES Cutring etc)
'15 Buick Regal "T"(wife)
'06 Saab 9-5 Combi 5mt (full suspension, LSD, clipped turbo etc)
      02-08-2013, 02:10 AM   #2
bbj
Drives: F30 328i M-Sport
So did you end up installing the tune with all the connectors? Because mine doesn't work and i have not the time to contact BMS yet and I suspect mine is the same as yours. 7/2012 production.
      02-08-2013, 08:57 AM   #3
Jamesons Viggen
Yeah, went in fine. All the other connectors are where they should be, it's just the first one you leave unplugged. Terry replied to my email in less than five minutes. Taking pictures helped.
      02-08-2013, 09:57 AM   #4
bnekic
Drives: 2013 328i xDrive Sport Line
Mine was the same way, I have the N20 motor with electronic boost solenoid. My BMS works great!
      02-08-2013, 10:42 AM   #5
Alpine F31
Alpine F31's Avatar
Drives: MB E350 4MATIC Estate
Will either of you guys test your cars on a dyno to see what the gains are?
      02-08-2013, 11:28 AM   #6
Jamesons Viggen
Yep, I will redyno when the new exhaust is put on. There are some other dynos posted and they so far all support BMS's claims.
      02-08-2013, 03:01 PM   #7
Turbo00
Drives: 2013 328i M-Sport
Same here, believe they went to electronic wastegate on the N20 late in the summer.
      02-08-2013, 06:18 PM   #8
Alpine F31
Alpine F31's Avatar
Originally Posted by Jamesons Viggen View Post
Yep, I will redyno when the new exhaust is put on.....
Cool. Looking forward to that!
      02-10-2013, 08:36 AM   #9
manicottiK
Drives: 530i (2017 G30)
Any remaining differences?
If this is correct, what differences are there between N20 and N26? I thought that the wastegate was "it."
      02-10-2013, 12:14 PM   #10
chugster
B0$$
chugster's Avatar
Drives: 2020 HS M2C
So I just checked my car and I found the same thing! My vin says n20 I ordered at late 6/12 so I guess it would be the around the same production time as yours(7/12).
      02-26-2013, 11:35 PM   #11
Chris@codemybimmer
Chris@codemybimmer's Avatar
Drives: AW F30 328i Xdrive
Are we losing out on some of the tunes claimed gains if we dont have this connection?
      02-27-2013, 09:58 AM   #12
Jamesons Viggen
Nope.
They posted a dyno on an N26 and the numbers were as good if not better than the early N20 dyno.
      02-27-2013, 12:33 PM   #13
Chris@codemybimmer
Nope.
Oh ok cool
i just got my BMS tune yesterday
Dont know if anyone with xdrive has gotten it yet and posted up dyno numbers yet.
      03-02-2013, 04:54 PM   #14
c3r2z8f30i
c3r2z8f30i's Avatar
43
Drives: 2020 540ix & 2021 x5 40i
Where in the VIN does it say which engine I have?
      03-02-2013, 04:58 PM   #15
Jamesons Viggen
Put the last 7 digits of your vin into bmwvin.com
      04-04-2013, 06:26 PM   #16
BMAISH
Drives: 2013 328i
Hey Jamesons Viggen what exhaust are you going with?
      04-04-2013, 07:33 PM   #17
Jamesons Viggen
Rogue Engineering, but it's going to be another couple months.
      04-05-2013, 12:53 PM   #18
BMAISH
Drives: 2013 328i
is it cat back or axle back?
      04-05-2013, 01:01 PM   #19
Jamesons Viggen
Cat back. Will be under $1000, 15-20% lighter than stock and has a standard option to bypass the muffler or add an electric bypass for extra $$$.
f30post
