F30POST
F30POST
BMW 3-Series and 4-Series Forum (F30 / F32) | F30POST > Technical Forums > Cosmetic Maintenance: Wash, Wax, Detailing, Repairs > Engine is dirty best way to clean?
Studio RSR
      11-25-2012, 02:38 PM   #1
trowe002
Drives: 328i 2007
What is the best way to clean an engine?
      11-25-2012, 02:42 PM   #2
Noor
Drives: '12 BMW 328i, '02 VW Passat V6
Yes please advice, I want to know too
      11-25-2012, 02:48 PM   #3
vince88
vince88's Avatar
Drives: '13 328i Xdrive Sports
You mean running a pressure washer through it?
If so, I remember reading that if the engine is cold: must be running
If it's hot: off is OK...
(or was it the other way around???) Cant remember exactly.
Some of the more knowledgeable members will tell you (if that's what you're looking for)
      11-25-2012, 04:04 PM   #4
trowe002
Drives: 328i 2007
Cleaner
That helps but do you know of a safe cleaning agent?
      11-25-2012, 04:32 PM   #5
vince88
vince88's Avatar
on my old e90, I had cleaned the engine bay, (cant remember if it was running or not) with my pressure washer... For the soap, I used regular car wash diluted with water already connected to my pressure wash.
Once the foam was good enough, I ran water only until it was clean.
      11-25-2012, 10:30 PM   #6
woderd
Drives: boat
what every you do, do NOT clean it after the engine has been running and it is hot. It is best to clean it when its cold
Reason being is the cold water will rapidly cool the hot engine parts to quickly and this can cause things to crack. Happened to me with an alternator a couple years ago
      11-26-2012, 09:23 AM   #7
bananachipz
Drives: F30 Mineral Gray 335i
Cold Engine.
Cover electrical contacts that are exposed
I use Optimum Power Clean
Regular hose, fan spray - no pressure washer
I finish the cover with Ultima tire and trim guard
      11-26-2012, 10:20 AM   #8
Tsuvoi
22
Drives: 2013 F30 328i
I would try cleaning by hand... Never a good thing to hose anything down in my opinion.
f30post
