11-13-2012, 07:50 PM | #1 |
Rep 58
Could someone please identify this?
Does anyone know what this thing is in the engine? I've spent the past hour trying to figure it out... Blow off valve? Exhaust valve? It's driving me crazy!!!
Much appreciated! |
11-13-2012, 08:21 PM | #2 |
Rep 3,780
My guess is bypass valve- modern turbos have bypass valves which are like a blow off valve that recirculates.
'98 Dinan/RMS stage 2+(VAC cams, CES Cutring etc) '15 Buick Regal "T"(wife) '06 Saab 9-5 Combi 5mt (full suspension, LSD, clipped turbo etc) |
11-14-2012, 08:29 AM | #5 | |
Rep 69
My car has an N26, so this is electro-mechanical rather than vaccuum operated, but on the standard N20, BMW uses a pretty run of the mill twin scroll turbo w/vacuum-operated internal wastegate; only difference is the operation between N20/26. |
11-14-2012, 09:38 AM | #6 |
210
Rep 1,161
11-14-2012, 05:47 PM | #7 |
Rep 93
It is called an actuator. A wastegate is different, but they do similiar jobs. The actuator pushes the flap open when the turbine gets to the set boost to allow for some of the exhaust gases to bypass the rear turbine wheel, so it doesn't keep spinning to infiniti and blow the engine / the turbo up.
