F30POST
F30POST
BMW 3-Series and 4-Series Forum (F30 / F32) | F30POST > Technical Forums > N20, N26, B46, B48 Turbo Engine / Drivetrain / Exhaust Modifications > Anyone pull out the extra air filter on the N26?
ARMA SPEED
      10-09-2012, 10:43 AM   #1
DR.Nefario
DR.Nefario's Avatar
86
Drives: 2013 Dakar Yellow M3
I tried running an aftermarket intake but kept getting lean faults. I went back to stock but I removed the extra air filter they added for the N26. The lean fault returns but it takes much longer than with the aftermarket intake installed. I also have a BMS stage 1 tune and am hoping that isn't what's causing the fault.
      10-09-2012, 11:53 AM   #2
jwilly
Drives: They're all white now.
Simple enough to determine. Put the extra air filter back it and wait for the lean fault. If you don't get the fault, suspect the tune.
Joel
That's a lot of white
      10-09-2012, 12:22 PM   #3
DR.Nefario
DR.Nefario's Avatar
86
Joel
I know, I'm just sick of messing with the damn thing lol. I took it in and out a few times already trying different things to get the aftermarket intake to work
      10-09-2012, 12:54 PM   #4
tiltmode43
I plead the 5th.
tiltmode43's Avatar
Drives: '18 Frontier Pro-4X, '06 Z4MR
I'm sure you checked, but vacuum line is nice and tight?
-Matt
| Z4M Build Thread | @violetnites | flickr |
      10-09-2012, 02:52 PM   #5
DR.Nefario
DR.Nefario's Avatar
86
Yeah I triple checked it. Have you had a chance to dyno before/after with the tune and downpipe yet? Still rocking out with the SES light? lol
      10-09-2012, 04:26 PM   #6
tiltmode43
I plead the 5th.
tiltmode43's Avatar
Yup, still have the light on, lol
Haven't dyno'd yet - I probably won't do one without the dp, a bit too hard to switch out on a whim. Will do with & w/o tune though. There's a dyno in the shop next door to ours, I should have gotten numbers through every step of the modding process, kind of regret it now.
-Matt
      10-17-2012, 09:33 PM   #7
f30racerM
Drives: F30 328
Do you have a photo of it? How do I know if I have an N20 or N26?
      10-18-2012, 03:10 PM   #8
DR.Nefario
DR.Nefario's Avatar
86
N26 has an electronic wastegate. Easiest way to tell
      10-20-2012, 04:55 PM   #9
L0UD0G
Drives: 2012 328i Sport
Wouldn't it also say SULEV or ULEV underneath the hood? I have a 2012 328 in Arizona with the N26 manufactured in 5/2012 and mine says SULEV underneath the hood and I have the electronic wastegate.
So if it says SULEV then its the N26 and if it says ULEV then its the N20 right?
      10-21-2012, 03:07 PM   #10
john08135i
john08135i's Avatar
Drives: 2013 M Sport, 2010 bmw S1000RR
amazing know one can verify this?
M Sport Line Estoril Blue
      12-09-2012, 11:01 AM   #11
john_f30
john_f30's Avatar
Drives: 2016 340i
2016 BMW 340i  [0.00]
my 2013 328i has an electronic wastegate and its a N20..
      12-09-2012, 11:04 AM   #12
john_f30
john_f30's Avatar
Drives: 2016 340i
to check which engine you have is to look for the stamped engine code at the front of the cylinder block.. its between the air intake box and the block.
      12-09-2012, 11:03 PM   #13
pkimM3r
pkimM3r's Avatar
206
Drives: m3 saloon in granny mode.
Lean = kaBOOOOM!
      12-10-2012, 09:10 AM   #14
john_f30
john_f30's Avatar
Drives: 2016 340i
Lean = kaBOOOOM!
mine?.. just bought it a couple of weeks ago and have verified that my car has a N20.. stamp on the engine with the serial number.. so how come mine have a electronic wastegate?..
      12-10-2012, 09:16 AM   #15
bnekic
Drives: 2013 328i xDrive Sport Line
Mine too. BMW recently switched to the electronic wastegate for the N20.
      12-10-2012, 10:30 AM   #16
john_f30
john_f30's Avatar
Drives: 2016 340i
thats good to know.
      12-13-2012, 05:54 PM   #17
tiltmode43
I plead the 5th.
tiltmode43's Avatar
Manual transmission?
-Matt
      12-13-2012, 06:01 PM   #18
john_f30
john_f30's Avatar
Drives: 2016 340i
nope.. auto
      12-13-2012, 06:13 PM   #19
tiltmode43
I plead the 5th.
tiltmode43's Avatar
nope.. auto
Interesting, I was under the impression all newer F30 328i's in CA, as well as some other states, were N26? I thought I had read all manual transmission cars would be N20 but this could have been incorrect.
On your title is your car listed as 328i or 328is? I believe N26 are listed as 328is which indicates SULEV (Super Ultra-Low Emissions Vehicle).
-Matt
      01-05-2013, 11:49 PM   #20
john_f30
john_f30's Avatar
Drives: 2016 340i
It's listed as 328i
      01-06-2013, 06:43 AM   #21
rado
Drives: F30 328i M Sport
My 2013 328i 6MT has an N20, and an electronic wastegate. The 2013 BMW ordering guide published last June indicates that there is no SULEV/N26 with 6MT, only ULEV/N20. Of course that's subject to change at some point.
-Ed
2013 F30 328i M Sport
2008 Lotus Exige S240
      01-06-2013, 07:26 AM   #22
clarence
Drives: F30 328i M-Sport
The electric wastegate was fitted to N20 since 7/12.
f30post
