10-06-2012, 01:44 PM | #1 |
Rep 1,157
Which fuel?
I realise this may open a can of worms but we'll see
Which is the best type of fuel to use or are the effects so minimal that it doesn't even warrant thinking about it? Supermarket fuel is usually the cheapest but is it as good as the main oil companies standard fuel or is it just worth paying the extra for the extra special ultimate fuel? The nearest petrol station to me is a Texaco and the times I've filled up I have put in their Supreme Diesel, this is more because I've been in a hurry and that was the only pump free rather than anything else. However, the car does feel smooth and responsive so maybe there is something in it, or I'm just getting used to the car and it's characteristics. As I don't have anything to compare this against with it being a new car and different to my previous cars I thought why not ask the question and see if the extra pence per litre is worth it or if I should just queue patiently and save my money So what do you do? Which fuel do you use and why?
Current: recovering slowly
Previous: F31 340i Ruby Red IIM5 Singapore Grey, F30 335d Moonstone, F30 320d Tanzanite Blue |
10-06-2012, 02:54 PM | #2 |
Rep 159
Shell fuel save Diesel....I notice a smoother throttle response and slightly better mpg in my current f25 X3 compared to the supermarkets diesel products, however I work for Shell so I may have a slightly biased view.
10-06-2012, 03:10 PM | #3 |
Rep 9,709
Never tried the premium Diesel before other than once when I filled up as it was the only diesel a station had and I was out. I didn't notice a difference, and didn't brim the tank either as it was like 4p a litre more. Needless to say, couldn't get any indication of better economy.
Petrol, now that is different between premium and the likes of the high octane derivatives like Shell V Power, IF you drive a high performance car. Only ever put Tesco 100 or V Power in my Subaru Sti. Coming back to Diesels, Shell seems to be quite competitive vs supermarket fuel in my area, so try to fill up there if possible. Otherwise use supermarket diesel. I figure as long as I put enough tanks of the advanced cleaning additives in on a regular basis I get the good cleaning effect Not sure I can feel any difference TBH. |
LobB5109.00 |
10-06-2012, 04:46 PM | #4 |
Rep 1,197
There's good reasons why premium petrols are empirically better for certain petrol engines although economically they never make sense.
But I've often wondered what the excuse is for uber expensive diesels like BPO and Shell because I know of no technology that gives more power in a diesel engine. Hopefully someone can explain and save me having to Google it
"Sleeper 335D xDrive M Sport" Glacier Silver / Black
ZMS | ZNP | ZVI | 2VF | 2VL | 3AG | 494 | 6NS | 8TH |
10-06-2012, 05:12 PM | #5 |
Rep 3,022
I ran the e90 330d on premium, and either via placebo and not, its runs smoother and picks up quicker. When I had to put in Shell standard once, there was a distanct throttle lag at first (I would never ever put in supermarket)
This debate raged on and on within e90post. The main argument was if you have a high performance car (330d/335d) why on earth would you not put the best fuel in for the sake of a few quid? Fifth Gear did a test and found out Premium Diesel does give more power!
M2 Arrived!
Family 5er |
LobB5109.00 |
10-06-2012, 05:23 PM | #6 | |
Rep 11,292
Although a few people running Ultimate in 4 cylinder diesels on the E90post forum said they could not tell much difference - so, from what I've read, the 6 cylinders seem to like it the most. I also put Shell V-Power in mine once and couldn't tell any difference than normal fuel and not as good as BP Ultimate. Wont be putting Shell in again. |
LobB5109.00 |
10-07-2012, 01:10 PM | #9 |
Rep 400
Drives: F30 LCI 330e M Sport
Shell V Power every time for me. Supermarket especially makes my E90 go like a tractor
Current- F30 330e M Sport
2016 - 2019 F30 LCI 330 M Sport 2012 - 2016 F30 320d ED 2008 - 2012 E90 320d SE |
10-07-2012, 01:41 PM | #10 | |
Rep 3,022
Shell V-power seemed good in the 330d as well though, just not there standard stuff.
M2 Arrived!
Family 5er |
LobB5109.00 |
10-08-2012, 03:36 AM | #13 |
Rep 3,022
just out of interest mate, do you run the 328i on Super or Reg ul?
Yup...why are BP garages so expensive? I had one exception near me, with the BP garagee attached to the Subura dealer. But then have closed down
M2 Arrived!
Family 5er |
10-08-2012, 06:45 AM | #15 |
Rep 184
TMP
I have only ever used cheap diesel wherever i am at the time but i think i read your views on BP Ultimate before. I am looking forward to trying it when and if I get my 330d in 9 weeks. My 530d went back 3 weeks ago so havn't tried it yet.
Ordered: 17/08/2012
330d M-Sport / Glacier Silver / M-Adaptive / Variable Steering / HK / Xenons - Collecting 20/12/12 Previous: E60-530d M / E60-530d M / E39-525d M |
10-08-2012, 07:49 AM | #16 |
Rep 4,936
Drives: 340i MPPSK
If I'm filling up at Shell then it's usually just vanilla unleaded (they do V Power & Regular on the same pump). I have used premium before, but tends to be when there's a queue and doing so will save me time. Not really noticed a difference in the car's behaviour though.
I rarely go near supermarket gas stations though as they are usually the most busy in these parts. I'm sat on the fence about regular vs. premium. Seems that for every report that says there's a difference, there's another that says there isn't. WhatCar? tested it in a VW Golf GTi 2.0 and reckoned mpg was the same although performance was marginally down which surprised me.
Life is a state of mind |
LobB5109.00 |
10-08-2012, 09:34 AM | #17 | |
Rep 265
I *may* notice an improvement in MPG / Power delivery / refinement etc. I *will* notice a difference in my wallet. The difference that I *may* notice is marginal The difference that I *will* notice is not.
2016 BMW 340i .. driving it like I stole it !!!
2016 Golf GTI .. gone 2014 Lexus NX .. gone 2012 BMW 330d .. gone 2009 MB C250 .. gone |
LobB5109.00 |
10-08-2012, 12:01 PM | #18 |
Live for today tomorrow never comes
1989
Rep 9,498
5th gear proved that these fuels are just not worth the money, the worst of which had NO improvements was BP ultimate it made NO improved performance at all, the only "noticeable" one was shell and that was 5BHP at high revs , how often will that be used in every day driving?.
So regular diesel and petrol is fine to use unless you are going racing. Save your money it's all placebo.
Live for now, life is too short.
2021 LCI M5 Marina Bay Blue/ Smoked White Leather |
LobB5109.00 |
10-08-2012, 03:35 PM | #19 | |
Rep 11,292
Are you sure you are not getting mixed up with the programme they did on fuel additives? They really are a waste of money and in some cases cars lost bhp. I've tried them over the years and I agree they are a waste of money (eg Millers Sport 4). I have absolutely no doubt the throttle response is improved with BP Ultimate in my car. I wouldn't put it in otherwise. I dont think it makes the car any faster, but to me it just feel livelier under the throttle foot. Over the summer I had to put in Morrisons stuff when on holiday and I could tell a difference straight away. Felt like I was carrying 3 extra people in the car and stunted the throttle response. It doesn't make a massive difference, but it is noticeable, and other people have said the same. I'd say to people try it if you want to and if you dont feel any difference then dont buy it again Last edited by dopper99; 10-08-2012 at 03:43 PM.. |
LobB5109.00 |
10-08-2012, 03:57 PM | #20 |
Rep 1,197
Johnbmw6 must have seen the more recent 5th Gear about posh petrol since that was their conclusion. Obviously the diesel conclusion was very different
10-09-2012, 11:41 AM | #21 |
Rep 9,709
Whether high octane fuels makes a difference or not, depends on whether the engine map is being damped down by the knock sensors. This is for petrol engines only.
In my prodrive tuned subaru sti, high octave fuel totally transformed the car, same with my Nissan Skyline. Key factors, petrol engine, turbo charged, high performance maps. You will notice now that manufacturers tune power/ torque to set figures. For example BMW 163hp, 184hp, 204hp. These all relate to kw values 120, 135, 150 kw. Pretty rounded off right? With this in mind, you know that the hardware is being restricted by the tuning on the latest cars, so not sure that would allow the average driver to notice a difference in fuels. |
LobB5109.00 |
