09-15-2012, 06:07 PM | #1 |
Rep 145
What's the OEM center bore size for BMW rims?
Hi folks
I tried searching in the Sticky section as well as searching but I was not able to find the answer. What's the center bore size for 2013 wheels or BMW wheels in general Thanks Max |
09-16-2012, 08:22 AM | #4 |
General
1569
Rep 29,202
Well almost all, a few are 74.1 like the X5 E70, the X6 E71 (front wheels only) and the old 5 series E39.
F10 520d M-Sport Alpine White | HRE P43SC 20x9+20x11 | Michelin PSS 255/35+295/30 | KW V3 Coilover | M5 Front Sway Bar + M550d Rear Sway Bar | 3DDesign Front Lip | BMW M Performance CF Spoiler | BMW M Performance Diffuser | BMW M Performance Black Grills | BMW M Performance Pedals | |
09-17-2012, 07:25 PM | #5 |
I plead the 5th.
523
Rep 1,519
We have a winner!
-Matt
10-25-2013, 02:26 PM | #7 | |
Rep 2,650
If you purchase a replacement rim with a smaller diameter center bore it will have to be bored out by a machine shop. If you purchase a replacement rim with a larger diameter you must purchase hub-centric rings (plastic or metal) and install them inside the hub bore of the wheel. Hub-centric rings come in many sizes, but make sure to purchase the correct size for your wheel/car (i.e. if your hub bore is 72.56mm and you purchase wheels with a 74mm hub bore, you must install 74mm to 72.56mm hub-centric rings). If you do not install hub-centric rings, you will likely experience steering wheel shake/vibration at cruising speed due to the wheel not being perfectly centered. The safest method is to purchase wheels with the correct hub bore as they are a direct fit that won't need any machining or rings. Hope this helps!
925-245-0773 /// info@apexraceparts.com
Wheels /// Accessories /// Vehicle-Specific Fitment Guides /// Careers |
lo_xyooj57.00 Mousejunior122.00 |
10-27-2016, 09:18 PM | #8 |
Rep 216
I had to bump this old thread. Thanks Apex for confirming what I need to buy...Winter mode in full effect... Thank goodness I found this thread to confirm buying the right ring before mounting the wheels..
Expert@ApexWheels3533.00 |
