F30POST
F30POST
BMW 3-Series and 4-Series Forum (F30 / F32) | F30POST > Technical Forums > Cosmetic and Lighting Modifications (exterior & interior) > F30 Smoked side indicators - DIY
proTUNING Freaks
      08-16-2012, 10:35 AM   #1
scott@bmwhn
Drives: Msport X3
I'm not fond of side mirror turn indicators so I was a little bummed when it became apparent BMW would go this direction on the F30. However, my mind began to devise ideas on how to overcome this small aesthetic inconvenience.
The most obvious, easiest, and cheapest solution I devised is to tint them.
Now I've personally never been a fan of smoked lenses, but luckily BMW designed the indicators to run parallel with the mirror base trim (which on my car is Gloss black) so a thick coat (or two) of lens tint should allow the indicators to blend with the gloss black base, thus hiding the indicators and giving the mirrors a slightly more aggressive look. Excited by the idea, I ordered some new indicators and got to work.
Supplies:
-BMW OE turn indicators:
Left 63-13-7-280-771 $31.10
Right 63-13-7-280-772 $31.10
-RustOleum Spray tint $11.99 @ Autozone
-Bone Tool/panel tool
-T10 allen key
Note: The mirror caps slide and fit together a certain way so some wiggling is necessary to remove and reinstall them. The mirror glass is the only thing that requires some leveraged force to pop off the motor (a bit unnerving considering that piece of glass costs about $300)
03' 525iT stick, 22' 530i
Previous: 20' X3 M40i, 19' 740i Msport, 17' 430i GC, 15' Msport X3 28i, 15' Sportline X1 28i, 13' Msport 328i, 09' Msport 335i, 07' Msport 335i
      08-16-2012, 03:17 PM   #2
m5 guy
m5 guy's Avatar
Drives: 2020 M5 Comp
Very nice, I like mods like this. Would go great together with the m performance cf mirror caps as well
2020 F90 M5 Comp Oxford Green Metallic II-Aragon JOURNAL
2016 F10 M5 Space Gray-Black SOLD
2012 E70 X5M Monte Carlo Blue-Silverstone SOLD
2001 E46 M3 Oxford Green Metallic II-Cinnamon SOLD
      08-17-2012, 11:57 PM   #3
RollingLower42
RollingLower42's Avatar
71
Drives: 2012 BMW 335I
I like the idea and spirit, and definitely think it looks much better than stock with the clear and yellow (yuck)
However, even with the tint, you still have the ugly yellow color when it blinks. When you took off the light, was there anyway to change the bulbs in there? I would imagine there would be many bulbs to change if you did want to go all the way and get rid of that yellow for good.
If you were to put a clear/ white bulb in place of the yellow ones, I think it would win even more. You would get rid of the yellow color and have only side lights with the tint, and I think that would look so much better and still be street legal. I personally will probably end up doing this at some point as well.
      08-18-2012, 12:37 PM   #4
scott@bmwhn
Drives: Msport X3
they are LED bulbs on a circuit board so just changing them to white is not an option unfortunately.
      10-12-2012, 02:39 AM   #5
RollingLower42
71
Damn, well looks like the next best thing is to tint them then. I will have to follow your guide very soon, thanks
f30post
