F30POST
F30POST
BMW 3-Series and 4-Series Forum (F30 / F32) | F30POST > Technical Forums > Cosmetic and Lighting Modifications (exterior & interior) > Voiding the warranty with bulb replacement
proTUNING Freaks
      07-24-2012, 08:33 AM   #1
G3raldT
Drives: 2012 328i Jet Black / Black
Im planning to change to headlight HIDs to white.(that yellow color just downgrades the look of my 328i) but will it void any warranty? Fyi i the extended warranty..
      07-24-2012, 08:42 AM   #2
bananachipz
Drives: F30 Mineral Gray 335i
If they are yellow, they aren't HID's...
      07-24-2012, 11:56 AM   #3
G3raldT
Thanks for that.noted. So does changing those void any of the warranty? I have the 2 yr extension.
      08-30-2012, 02:46 PM   #4
turtle335
Drives: E92 335i
If they are halogen headlight and you changed it to be HID headlight. You may void your headlight warranty. Because you may need to drill a hole on the light bulb cover for the wire that connected to HID bulbs and ballast. You can change your yellow light bulbs to some 7500K or 8000K halogen light bulbs to make it white color. Or replace your whole headlight to be a HID projector headlight.
      08-30-2012, 03:20 PM   #5
Cyberdemon
Cyberdemon's Avatar
1538
Drives: 2020 X5 40i, 2018 M3 Comp
Changing light bulbs does not void your warranty.
However, avoid the common mistake of buying a bulb that is not rated correctly for your car. Your brighter lights run the risk of melting the wiring harnesses, which is not covered under warranty because you broke the car by replacing a part with something that was not rated correctly. It's the same difference as putting a 100watt bulb in a lamp rated for a 20w. When it melts, you can't blame the lamp maker. I know at least half a dozen people who've done this (this impacts halogen bulbs, not HID's which are a different beast)
Current: '20 X5, '18 M3 ZCP
Previous: '11 E90 335i, '11 E90 M3, '16 VW GTI, '15 M235i, '13 335i, '08 TL-S, '00 Corvette
f30post
