BMW 3-Series (E90 E92) Forum
M-Tech Angel eye question.
07-14-2012, 10:39 AM | #2 |
Rep 2,217
definitely doesn't seem right... maybe try pulling them out again and making sure they're seated straight. If that's how they are, then i'd return them and go with something else; that looks like crap.
07-14-2012, 11:20 AM | #3 |
Rep 143
07-14-2012, 03:05 PM | #4 | |
Rep 592
One trick is to mimic Oem light as it is pulled out I know that is hindsight Try repositioning Thus is the mtec Cree led with 4 led??
2011 335i Space Grey Msport E90
BMW Performance Exhaust PPK Stage I Lux H8 , HID Fog lights 5k |
07-15-2012, 12:12 PM | #6 |
Rep 143
07-15-2012, 01:55 PM | #7 | |
Rep 592
But rather once unit is in, you turn it Some try to turn all the way possible Some memorize Oem position during removal That turn can be critical in achieving optimal luminescence in both rings
07-16-2012, 01:05 PM | #9 |
Rep 106
I think it has to be the positioning as well. Just installed the latest mtec on mine about a month ago. The should look equally bright. Double check the alignment. Make sure that the plastic piece that goes between the bulb and the headlight housing itself is not blocking one of the LEDs.
They should look more like this: http://www.e90post.com/forums/showthread.php?t=713353 Obviously a different vehicle but you get the point.
