F30POST
F30POST
BMW 3-Series and 4-Series Forum (F30 / F32) | F30POST > Technical Forums > N20, N26, B46, B48 Turbo Engine / Drivetrain / Exhaust Modifications > Installed BMS Clutch Stop
GetBMWParts
      07-03-2012, 06:54 PM   #1
bmwm311
Drives: '12 Alpine White F30 N20 ZSL
I just installed the BMS Clutch Stop in my 6MT F30. It was a pretty easy install, you don't need to take out a panel to install it like the e9x. You can see the clutch stop behind the brush cover behind the clutch pedal. I just reached in there and yanked out the tiny rubber clutch stop and inserted the BMS Clutch Stop in under 30 secs. The Clutch feels much shorter without all that dead space. I didn't have any trouble starting up the car with the clutch fully depressed. Now it feels like the clutch engages at about 20% from the floor and as opposed to 50% from before. It's only $10 shipped from Burger Motorsports or I read you can make your own for under $5. I like it a lot more as it feels more manageable and a little bit less work
Sorry I tried taking pics but it was pretty tough getting the camera in the tight spots. You can actually feel around in there where the clutch stop is.
      07-03-2012, 07:55 PM   #2
F30.ca
Drives: GTI
I haven't picked up my car yet but if the clutch has too much travel then I think this would've a great mod. Simple and cheap. That's how all mods should be.
      07-03-2012, 08:18 PM   #3
RPM90
Drives: 340i M-sport AT
BMW clutch travel is a bit long.
Both my E46 325i and current 135i both needed a clutch stop.
You should put a stop in there, it does make a noticeably positive difference. I've never modded the CDV's in either car. Once the stop is in place, my biggest complaint is gone.
I'm surprised that BMW still refuses to address that aspect of the MT's.
For my 335i Msport I won't have to deal with it, cause I decided to try the sport AT.
      07-03-2012, 11:23 PM   #4
ric124
ric124's Avatar
Jamaica
452
Drives: F87 M2 BSM MT
2017 BMW M2  [0.00]
Thank you.... I just placed my order. $10 mod that improves shift times
      07-04-2012, 04:47 AM   #5
johnofcross
johnofcross's Avatar
Drives: Superman 2013 F30 335i M Sport
Is there a reason why the clutch pedal has that much travel? And also, what happens when the clutch gets hot, is there fade (the clutch point is much closer to the floor)? Just curious if this stop would affect it in any way negatively.
      07-05-2012, 04:18 AM   #6
pkimM3r
pkimM3r's Avatar
206
Drives: m3 saloon in granny mode.
Is there no way to adjust the clutch pedal by adjusting the locking nut and rod?
      07-07-2012, 09:22 PM   #7
PrazVT
PrazVT's Avatar
Drives: '21 M240i 6mt (soon)
Thanks for sharing this! I too felt the clutch was a little deep when I was driving around in Europe. Just ordered one as well - and good to know we don't have to take the panel off.
f30post
