06-28-2012, 11:00 PM | #1 |
Expect the Unusual
259
Rep 1,344
Would a chip for the 335i work on the ActiveHybrid 3?
Wondering if I could buy a chip to further increase the output on the ActiveHybrid 3 I'm getting. I know it's the same engine as the 335i, but it's apparently tuned to work in sequence with the supplementary 50HP electric motor so I'm wondering if a chip would still work as I'd love to be able to increase the output by 50HP or so. Since the combined HP on the ActiveHybrid 3 is 335HP from the factory, if I could buy a chip that gave me an extra 65HP out of the engine, I would be pushing 400HP!
A 400HP Hybrid... we'd be talkin' then! |
07-21-2012, 09:51 PM | #2 |
Rep 42
I've seen this post unanswered for a while. I think were all rooting for you. I think it's anbodys guess though. Maybe you will get lucky since it is set to work with the auto start-stop. Wy doesn't anyone do a regular boost controller. You can easily and safely get 30hp without needing to change fuel maps and timing. I'm sure on these cars the boost is regulated electronically but I'm sure it can't be that hard. Definitely void the warranty though.
07-05-2014, 12:28 PM | #3 |
Rep 931
BMW F82 M4 Black MHD CS Map - GTS DKG - Navi -Performance Brake RSL1 Pads - USB - DivX-DVD - Bluetooth - VoiceControl - Connect - Apps - Online - H&K - TrafficInfo - SpLimInfo - WhiteMerino- PDC - Cam - Adaptive Led - Antitheft - CP Steering- Performance ST - Adaptive CP Setup - GarageDoorOpen - Pipercross - Stock Exhaust - Mdrivers Pack - 437M Wheels
07-09-2014, 07:48 AM | #4 |
Rep 6,990
Drives: 15 F80 M3, 22 G01 X3 30i
FYI - there have been no "chips" available for engine tuning since the 1990s...it's all done by engine software updates or "piggyback" tuners that alter the engine parameters. There is no way to remove/replace a "chip" on current vehicles - they're all permanently mounted to the circuit boards. Last car that I put an actual chip in was a 1993 Porsche 968; the advent of OBDII regulations pretty much killed off the whole replaceable E-PROM thing.
2015 F80 ///M3 Sedan 7DCT Tanzanite, 2022 X3 sDrive30i 8AT Brooklyn Grey |
12-30-2014, 11:12 AM | #5 |
Rep 931
Installed JB Stage 1
380Hp final The car is great in the midrange !
12-30-2014, 09:46 PM | #6 |
Rep 139
+1
2013 Active Hybrid 3 | M Sport | Alpine White | Coral Red | BM3 Stage 2 | ER FMIC | FabSpeed Catted DP | ER CP |
2016 F150 2021 RnineT 2022 K1600B Last edited by dougt.ah3; 12-30-2014 at 10:47 PM.. |
06-09-2015, 05:42 PM | #7 |
IG @bmwF9xG80
3813
Rep 7,593
Drives: G80 M3, X4M, G07 X7m50
I guess any piggyback tune for a 335/ N55 will work then ?
60-130mph 6.5s X4M #HCP
60-130mph 5.0s G80 M3 #OrlandoAutowerks Sauce IG: @bmwF9XG80 |
06-10-2015, 07:50 AM | #8 |
Rep 115,999
06-10-2015, 12:47 PM | #9 |
Rep 190,975
I had customers who got the Jb on the Active Hybrid and it works without a problem .
09-12-2016, 02:40 PM | #11 |
Rep 276
09-12-2016, 02:49 PM | #12 | |
Rep 190,975
Log boost and let us know how it looks like.
09-13-2016, 01:40 AM | #14 | |
Rep 931
The new software detect te map-tmap manipulation by the JB stage 1 In the ActiveHybrid 3 my JB and my tmcmotorsport piggy put the DME ecu in the same error after a lot of pull (freeway or trackday) : "Druck zu Nieder" (error appears only in navi screen, no mil lamps) After this the car run in "stock" power. Only with stop-start sequence the car run now with the contribute of the piggy Before this software update ( 3.57) no problem. A new logic in order to find tmap manuipulation ? A conflict with the electric engine in "eboost mode" ? the fact is that after upgrading my two piggy are detected when strong run in stock mode no problem
09-13-2016, 01:41 AM | #15 |
Rep 931
I have stage 1 sorry
09-13-2016, 02:01 AM | #17 | |
Rep 931
your car have a new software called psdzdata 3.59.3 ? (f20-16-7-503)
09-13-2016, 02:05 AM | #19 |
Rep 931
yes
with e-sys you check the software But this new software is available from august 2016. Have you visited BMW last month ?
09-13-2016, 03:02 AM | #20 |
Rep 1,292
No, I will visit them by end of year for the yearly visit; I guess we will know for sure then. I should find a way to get them to update earlier, so I can check and return the JB4 quickly in case of problem.
2017 M550i | Sophistograu
Previous cars: 2014 F30 ActiveHybrid 3 | 2012 f20 M135i |
09-13-2016, 03:43 PM | #21 |
Rep 113
I have a jb4 with an active hybrid 3 and just got a cel today after about a week. Jb4 can't read or clear the code. Going to check with carly and see if it shows anything. I definitely have the software update.
