F30POST
F30POST
BMW 3-Series and 4-Series Forum (F30 / F32) | F30POST > Technical Forums > N20, N26, B46, B48 Turbo Engine / Drivetrain / Exhaust Modifications > At what RPM does second exhaust open?
GetBMWParts
      06-22-2012, 02:28 AM   #1
SomeRandomer123
SomeRandomer123's Avatar
England
307
Drives: F30 328i Luxury - Sport Auto
...the second exhaust (inner of the two I assume) open on the 328i? And if one were outside the car, would the sound of the flap opening be audible?
At idle, is only one exhaust open or both? Or is it all dependent on exhaust gas regeneration and emission stuff?
Gone: 2006 BMW E60 520d SE 6MT
Gone: 2009 BMW E90-LCI 330d SE 6MT
Current: 2012 F30 328i Luxury 8AT
On Order: 2015 Audi A6 Avant Ultra, Black Edition (sorry!)
      06-29-2012, 02:30 PM   #2
Remonster
Drives: E90 M3
On cold start, the valve is open (both exhausts flowing) for a while until the car begins to warm up and then the valve closes. I'm trying to think back to before I disconnected the valve (25,000 miles ago, mine is always open and I love it) and I don't remember if there's a specific RPM, I think it just opens when you floor it or go past a certain throttle position.
You can't really hear the valve opening, it does make a sound but the exhaust noise itself is much louder. You can hear the exhaust growl more when it opens if you listen with the windows down, though.
      06-29-2012, 04:37 PM   #3
SomeRandomer123
England
307
I've noticed this cold start thing! Sounds awesome with both open then it gets warm and I can hear the valve open/close loud and clear OUTSIDE the car (not inside) and it all quietens down nicely.
      07-02-2012, 08:14 AM   #4
S_M
Drives: Many
Like Remonster said its open for about 30 seconds on a cold start then shuts. I took the clip out and fixed mine in the open position this weekend. It didn't make a big difference, but you can tell it's open at lower rpms now. Its now a little louder than it was, but still super quiet IMO. I would say 3000rpm is a good guess as to when it opens, as it used to be silent below that, and I can now hear the car a little bit.
      07-02-2012, 04:12 PM   #5
SomeRandomer123
England
307
How does one go about doing this to keep the flap open? Can be enabled again easily?
      07-02-2012, 04:16 PM   #6
S_M
Drives: Many
Yes. There is a metal clip that connects the flap to the motor that opens and closes it. All you have to do is take that clip out, and wire the flap so it is permanently open. Literally a 30 second job. If you don't like it, just push the clip back in, but trust me it doesn't make a huge difference.
      07-03-2012, 10:51 AM   #7
SomeRandomer123
England
307
Could you posts some pics or a video? I'm not confident!
Although that said, I'm probably not going to bother haha
      07-03-2012, 01:01 PM   #8
S_M
Drives: Many
Stealing this picture from Edmunds Insideline
See the metal clip shaped like a U? Take some needlenose pliers and pull that out. Then just use wire to fix the flap in place, there is a slot where the clip used to sit that works perfect.
It literally takes 30 seconds.
      07-06-2012, 04:34 PM   #9
SomeRandomer123
England
307
Ahh yes, looks stupidly simple!
Thanks for that
      07-09-2012, 11:38 AM   #10
Teemo Panda
*Bimmerpost Plasti Dip Guru*
Teemo Panda's Avatar
Drives: E53, E46-M3, E70, F25-X3
2013 BMW X3  [5.66]
Does it lower mpg?
      07-09-2012, 12:58 PM   #11
SomeRandomer123
England
307
Originally Posted by kamigawa120
Does it lower mpg?
Good question...
      07-09-2012, 01:03 PM   #12
S_M
Drives: Many
I haven't experiened any difference. I'm not sure how a closed flap in the exhaust would make milage worse, if anything I think it would be better. Either way I think you would be measuring hundreths of a mpg...
      07-09-2012, 03:52 PM   #13
SomeRandomer123
England
307
^^ True, I imagine the difference is negligible.
      07-09-2012, 09:16 PM   #14
Jadar
Dejan
Jadar's Avatar
Serbia
1753
Drives: 2018 Audi S3
I removed my clip, and its louder now in comfort mode, due to me always cruising at 50mph ish. Its ludest around 2200rpm and thats where I sit in comfort.
When its in sport, the rpms are at 3000 and its quieter for some reason.
All in all i like, it lets me know theres some power behind this n55
I wish there was a better way to secure the flap though. I used tie wire, and it works, but its a rig up job. Looks very cheap, like it was done on the side of the road, and I dont like that. Im just anal
FBO-PS1 and stuff
      07-09-2012, 09:59 PM   #15
Spikey
Australia
64
Drives: erratically
But you can't see it though?
      07-09-2012, 10:15 PM   #16
Jadar
Dejan
Jadar's Avatar
Serbia
1753
No, I know you can't, but I know its there. Its fine, untill I upgrade the exhaust.
Im OCD I guess, everything has to be neat.
FBO-PS1 and stuff
      07-09-2012, 10:30 PM   #17
Spikey
Australia
64
Drives: erratically
lol yea, i know how you feel... it's the annoyance factor that you know it's there... it's like invisible scratches ... as the owner you know it's there
      07-10-2012, 08:31 AM   #18
S_M
Drives: Many
I feel the same way, if I owned the car I'd probably put it back the way it was. But since its leased I really don't care
      07-10-2012, 10:22 AM   #19
DimSum
Drives: SLOW
the flap is only to keep the car quiet under low rpm and idle.
Otherwise, you can do without it.
      07-10-2012, 12:41 PM   #20
Teemo Panda
2013 BMW X3  [5.66]
when to do the mod, you wont hear that click sound at the back when turning off the car when it used too :P.
also i feel the car was much more lose when you drive it
      07-10-2012, 01:32 PM   #21
Jadar
Dejan
Jadar's Avatar
Serbia
1753
What do you mean loose? Like it performed different? I definetly didn't notice any positive or negative effects.
FBO-PS1 and stuff
      07-12-2012, 11:42 AM   #22
SomeRandomer123
England
307
Didn't think keeping the exhaust flap open reduced vehicle stability
f30post
