BMW 3-Series (E90 E92) Forum
Check Out this E9xx Storage Net Solution
05-21-2012, 11:12 AM | #1 |
No 55mph
1622
Rep 8,476
So, In my quest to find more storage options for my E92, I came upon this BMW OEM Passenger Footwell Storage Net - not made specifically for E9xx cars (I think it's originally for E34/E36 Z3), but I took a chance & ordered it anyway.
Turned out it worked great The clips simply 'screw' into the carpet on the side of your front console, then the net snaps into place using the clips. It could be removed and you would never know it had been installed. Along top edge of net is heavy elastic cord. Part numbers: Net - 51 47 2 261 407 Clips - 51 47 2 263 062 (Need Qty. 6/Ea) Installed pics: Total cost is $18.27 & the install takes all of about 3 min
F32 435ix//MGM//M Sport-Prem-Tech-Driver Assist-Lighting-Cold Weather-Dyn Handling Pkgs//M4 Black Lthr Int w/M4 Alum Blade Trim//HK w/Bavsound Stg3//763M//M4 Euro LCI Tails//M4 Mirrors w/CF Covers//AWCarbon CF F/R Spoilers-Side Splitters-Diffuser 6WB/ID6 HU+HUD/IND M4 Alcantara Armrest//PURE S2 Turbo//AA FMIC+DP//ER CP+TIC//3.5bar TMAP/TS DV//AWE Tuning Exh w/Blk Tips//Turner MS CF Intake//BM3 Cary Jordan Tune//MPerf Diff//PrecRW Ignition Kit
05-21-2012, 03:02 PM | #5 |
Rep 4,525
I have this in my e91 335i. Had it in my e46 M sport 4 dr 1st and transferred it across after getting the 335 touring and before selling my sedan.
Nice mod and it works a treat |
05-21-2012, 05:43 PM | #6 |
Rep 142
Op, great mod. I think I'm going to try that.
Where did you get the CF trim around the shifter and cup holders? Do they make anything like that in aluminum finish?
2008 BMW E93 328i Monaco blue/cream beige/walnut, ZSP, ZPP, ZCW, Step/paddles, BMW Performance exhaust, smartTOP.
Former BMWs:2000 E46 328i ZSP, Conforti shark injector, M68 wheels. 1976 2002, Weber carb, headers, Ansa sport exhaust, Kamei air dam and trunk spoiler. |
05-21-2012, 05:47 PM | #7 |
No 55mph
1622
Rep 8,476
They are part of one of those hi end dash kits - I liked the look of the factory wood, but wanted some CF accents also. It was the only thing I could find that was made to replace items OTHER than the normal wood trims.
There's much more to the kit that isn't showing in pics (and some items I decided not to use). And they do make the same kit in aluminum (as well as a couple other finishes). I'll have to look back to see mfg. of kit and where I got it from. I know one thing I DIDN'T get it from eBay
05-21-2012, 05:59 PM | #9 |
Rep 142
Would be a great addition to my e93 as a quick place to stow stuff so it doesn't fly around and/or out with the top down. Thanks for the part numbers.
05-21-2012, 06:23 PM | #10 |
No 55mph
1622
Rep 8,476
Exactly why I wanted this. I frequently have work documents setting on my seat and have to weigh them down with something to keep them from flying out either the window or roof. Now I can stick them in this net and they'll stay put
07-02-2013, 06:55 PM | #13 |
Rep 98
I know this is an old thread, but you say you need 6 clips?
But I see only 4 on the photos... could you confirm quantity please? -Thanks!
07-03-2013, 10:24 AM | #14 |
No 55mph
1622
Rep 8,476
BMW calls for Qty. (6), I found that I only needed (4)...
07-03-2013, 11:04 AM | #16 |
No 55mph
1622
Rep 8,476
Actually, BMW already has a custom fit net that installs on PS interior trunk trim:
51477131152 NET BAG 61219158226 WAVE WASHER - D=5,7 You can see it in the 3rd & 4th pics
07-03-2013, 11:42 AM | #17 |
Rep 6,092
damn. your trunk looks like a BMW accessories catalog.
i like the net idea tho. i could use that.
06-07-2015, 09:50 PM | #19 |
Rep 271
Sorry but is this all e90/e92 OEM trunk accessories? Would you mind describing them or even include the part numbers?
06-08-2015, 08:55 AM | #20 | |
No 55mph
1622
Rep 8,476
If so: Grocery Bag Holder 82260153360 BAG HOLDER - UNIVERSAL 82110306046 GROCERY HOLDER MOUNT First Aid Kit 82111469062 FIRST AID KIT Trunk Storage Net (Not Shown) 51477131153 BOOT/TRUNK FLOOR NET Elastic Band for Owners Manual 51476989314 RUBBER BAND - MITTELGRAU Under Trunk Storage Trough Liner w/Dividers (Not Shown) 51477148920 STORAGE TROUGH LUGGAGE TRUNK FLOOR 51477146048 DIVIDING ELEMENT LONG 51477146050 DIVIDING ELEMENT SHORT Jack Kit (Not Shown) 71102182448 SET: SET OF LIFTING JACK Tire Mobility Kit (Not Shown) 71100413439 SET: TIRE MOBILITY SET - MOBILITY SET Spare Oil Bag Kit 83292158848 KIT: SPARE TOP OFF OIL Hazard Warning Triangle 51477131760 TRIANGLE BRACKETS 71601095457 WARNING TRIANGLE W/CASE The Trunk Floor Liner is from Weathertech, but there is an actual BMW version - only difference is the emblem says 'BMW' instead of 'Weathertech' Weathertech makes the BMW floor liners
06-08-2015, 09:52 AM | #21 | |
Rep 271
What is the difference between these? They look the same on google images 82260153360 BAG HOLDER - UNIVERSAL 82110306046 GROCERY HOLDER MOUNT |
06-08-2015, 09:54 AM | #22 |
No 55mph
1622
Rep 8,476
If I remember well, the 1st number is the bag holder itself with the scalloped edge, and the mount is the kit with studs & hardware to mount it to the rear deck...
