BMW 3-Series (E90 E92) Forum
plasti dip window trim
05-03-2012, 10:44 PM | #2 |
Daily Driven!
188
Rep 2,516
Drives: BMW 335i
Search it makes everyones life easier!
But in most cases it will last for a pretty good time. As long as you don't take a pressure washer to it at close range you'll be good. Or you can just vinyl wrap/paint it and you'll never have to worry about it. |
05-30-2012, 08:33 AM | #4 |
Rep 1,588
I tried it yesterday, even though it came out really well, wasn't a fan of the roughness or the real matted out look. Go with Vinyl FTW!
################[Mac's '07 E93 328i]################ |
05-30-2012, 11:59 AM | #5 |
Rep 857
Drives: 2008 Montego Blue 335i
Is it worth it? It's $6 lol. If it lasted 6 months out of it, it is worth it. But people have had it for over a year with no problems
05-30-2012, 07:58 PM | #8 |
Rep 25,989
Agreed.
VMR|Wheels | 714.442.7916 |
sales@velocitymotoring.com | www.velocitymotoring.com | facebook | flickr | Instagram |
05-31-2012, 10:16 AM | #10 |
Rep 487
I've owned my car for almost 2yrs and it came w/sprayed window trim. About 3 weeks ago I decided to re-spray the trim. Had no problems removing 2+yr old spray and it did not mess up the original finish on the trim. As for texture, it's not rough, but it's not as smooth as vinyl/paint. I would suggest applying several thin layers of plasti-dip for 1) to build up layers for easy removal later and 2) to build up layers for smoother texture. I do not suggest spraying on a windy day; that will cause it to leave a rough texture - happened to me while spraying another part of my car. Fortunately, the next day after work, I peeled off the rough dip and sprayed it again, w/o wind, and it came out perfect.
I didn't notice if you have a sedan or coupe, but for sedans, the top trim pops off easy (start in the middle and carefully work your way down). As for the bottom trim, I removed mine and it was a PITA to re-insert. Next time I'll just tape it off and spray while on the car.
Tags |
plasti dip window trim e90 lci |
