E90Post
Extreme Powerhouse
BMW 3-Series (E90 E92) Forum > E90 / E92 / E93 3-series Technical Forums > AUDIO/VIDEO + BLUETOOTH + Electronics/Alarm/Software > How does the Ipod interface sort the files?
Reply
      03-14-2012, 02:49 PM   #1
twozzie
Drives: X5 4.8i Xdrive
I listen to podcasts in the car via the USB ipod connection (Navigation & idrive) on my travels and the order they appear in the ipod is newest to latest, however when the appear on screen in my car, they're all over the place? Any idea how the files are sorted and if they can be resorted to be the same as the ipod?
      03-14-2012, 05:58 PM   #2
carjon
Drives: 328xi Sedan
I think there is options - a random option that I bet is checked for you. While on the USB select options and look. If checked - unchecked should provide the same order as on your drive.
2011 328xi black on black. Nav, connect, apps, Sirius.
      03-14-2012, 08:11 PM   #3
twozzie
So I took a look and it appears there is no Podcast option on the BMW screen. I find my podcasts under Genre or Artists and even then they are filing by some obscure field, some are grouped together and some are individual, not like the ipod at all.
I'll keep playing I guess
      03-15-2012, 06:02 PM   #4
twozzie
Ok, found a solution - sort of. Searched these here posts and, you create a playlist with the relevant podcasts. Title the playlist "00 ......" so it always appears at the top of the lists.
However, if you start playing songs randomly, a podcast may come up every once in a while, no biggee I guess.
      03-15-2012, 10:29 PM   #5
Carl Morris
Drives: 2008 335xi 6MT
I'm having the same questions. I like my podcasts to play in timestamp order, but if I look at them in iDrive they are in alphabetical order and will play in alphabetical order if I start them from iDrive. What has worked so far is to look at them and start playing them in the normal order before plugging the iPod (in the case an old iPhone 3g) into the BMW interface. Then when I select USB it starts playing them in the order they were arranged and playing before I plugged it in.
      03-21-2012, 06:46 PM   #6
twozzie
ah, good advice, I'll give it a try
Reply
e90post
