BMW 3-Series (E90 E92) Forum
Stock 2011 335 HID Temperature?
11-25-2011, 12:27 PM | #1 |
i build cool shit
581
Rep 712
Drives: 2018 Individual SMB F80 M3
I was searching but I can't seem to find the answer. What is the stock temperature of the HID bulbs in a 2011 335? Are they white or will I need to replace them?
11-25-2011, 12:57 PM | #2 |
Brotographer
88
Rep 1,741
The bulbs are either Phillips or Osram bulbs (can't remember off the top of my head) with a color temperature of 4300K. I personally don't mind the color, if you really want to upgrade, I would go with Morimoto 5000K bulbs from theretrofitsource.com. 5000K is a great compromise, because it will be whiter than the 4300K bulbs, but you will only experience a slight drop in lumen output from the increased color temperature. Don't go above 6000K, it becomes glarey and visible light output drops off quickly. Morimoto makes extremely high end products, and TRS considers them to be on the same level, if not better, than OEM products. And they back that with warranties.
11-25-2011, 11:01 PM | #3 | |
Rep 13,877
Drives: E92 M3 & F80 M3 & G82 M4
11-25-2011, 11:27 PM | #4 |
Brotographer
88
Rep 1,741
It will be a whiter color, but it won't have that hint of blue like the 6000K bulb will. I think 5000K is perfect--think close to the Acura TL/TSX projector color temp. No real downsides, and it will look OEM, while 6000K will definitely look more aftermarket.
11-25-2011, 11:42 PM | #5 | |
Rep 13,877
I hope the DIY won't be too hard. I might try these out. Oh wow thats a lot of products. Could you help me find the correct one and send me the link? THanks
11-26-2011, 10:05 AM | #6 | |
Brotographer
88
Rep 1,741
Just make sure you select 5000K in the drop-down box! Replacing these bulbs yourself won't be too difficult. And yes, I know these are a bit pricier than what you see on ebay. But I've heard horror stories of ebay bulbs blowing OEM ballasts. I would be legitimately shocked if these caused damage, simply because Morimoto makes such incredibly well-built products |
11-26-2011, 10:36 AM | #7 | |
Rep 13,877
By chance do these come in 55w? And, would the Caddy escalade be considered like a 6000k? Thanks for bearing with me and my ridiculous questions.
11-26-2011, 11:25 AM | #8 |
3441
Rep 79,211
Drives: C6 Z06, 09 335i, 10 335xi
Yes atleast stay away from the ebay bulbs. They like to burn up ballasts quite frequently these days.
Majority of OEM cars stay in the 4300-5000K range. That range has the brightest output of light. |
11-26-2011, 11:52 AM | #9 |
Brotographer
88
Rep 1,741
As far as I know, that's not the case. I feel like BMW wouldn't use different color temperature D1S bulbs for different cars, just for the sake of economics. And as far as I know, there are no 55W D1S bulbs (I've seen a bunch of high-wattage D2S bulbs though), but more importantly, it's not the bulb that determines the wattage, but the ballast. You get a more powerful ballast, paired with a bulb designed for the higher voltage, and then bada-boom, bada-bing, you have a 55W (or higher) HID system. And I think the Caddy probably uses a 5000K bulb. But it might be a 4300K bulb and a really good projector. Hard to say.
11-26-2011, 01:41 PM | #10 |
Rep 49
all the OEM bulbs on the newer mercedes models are "Osram cool blue intense (5000K)". IMO they look amazing on the road, much better then the OEM bmw bulbs. ANyone know of a reputable online dealer that sells authentic osram bulbs?
11-26-2011, 02:30 PM | #11 |
i build cool shit
581
Rep 712
How are these? http://www.khoalty.com/bmw-e90-e92/l...ment-bulb.html
11-26-2011, 03:13 PM | #12 | |
Brotographer
88
Rep 1,741
11-26-2011, 11:28 PM | #13 | |
Rep 13,877
Thanks for the help. So, I should get those bulbs you listed. There isn't really much I can do. I'm not looking to get new projectors. I take it the ballast in those 5000k will be nice!
11-26-2011, 11:37 PM | #14 |
Rep 184
Ive had good luck with Phillips d1s bulbs. I got the pair off ebay for ~$120. But yes like others said look out for "cheapo" bulbs on eBay. I actually haven't installed them in my 335 yet but I took them out of my Audi before I traded it in and plan to install them in my new car. I had them for 2 hrs with no problems.
11-27-2011, 10:21 AM | #15 | |
Brotographer
88
Rep 1,741
1. The Ballasts: These take the 12V electricity supply from the battery, and up the voltage to something around 25,000 volts so that the bulbs can ignite and put out light. More expensive ballasts will do this better, more reliably. The OEM ballasts we have, while they are certainly sensitive to cheap aftermarket bulbs, the same can be said for any ballast. I would rate ours as "Very Good/Excellent" 2. The Bulbs: The bulbs are what define the majority of the color output. A lower color temperature bulb (3000K, yellow) will throw out a lot of lumens and little glare, while a higher color temperature bulb (1000K, heavily-blue-tinted white) will throw out less lumens and more glare. It will be less useful for you. The ideal range is between 4300K-6000K. I would rate the bulbs in our cars as "Very Good/Excellent" in terms of quality, but "Good" in terms of color. This is what upgrading to a 5000K bulb, like the Morimoto bulb, will impact. Build quality will be the same, but color will be improved. 3. The Projectors: Have you ever noticed when you're driving in front/behind of a very new, high-end Mercedes, Porsche, Acura, or Lexus equipped with Xenons, that the headlights seem to "flicker" a little bit? They seem to color shift, almost, showing a brilliant violet or blue for a moment, before you see the white light again? That is caused by very high end projectors. They make the cutoff on the headlights razor sharp, and the cutoff has a very visually pleasing narrow band of tron-esque color. I would rate the BMW projectors as "OK/Good Enough". Better than some (i.e. Current-gen Ford Explorer ), but there are plenty that are better (Caddy CTS, new CLS 500) For such expensive cars, they could have put significantly better projectors in, and I hope we see an improvement in the F30. Changing the bulb will not create these color shifts you see here. So, when you replace the bulb, you are not changing the ballast (unless you know for a fact that you had the unfortunate situation of blowing a bulb and a ballast--rarely/never happens with OEM or high-end bulbs) |
11-27-2011, 01:45 PM | #16 | |
Rep 13,877
You have been very helpful! I get it now.
I will have many other questions for you soon, actually.... I will be doing a lot of LED work and I'm not very fond of these kinds of works. So, keep in touch I have plenty of interior and exterior lighting that will be done soon! Quote:
11-27-2011, 07:29 PM | #17 | |
Brotographer
88
Rep 1,741
11-27-2011, 09:44 PM | #18 | |
Rep 1
http://www.hidplanet.com/forums/show...-RELEASED-SOON! If that info is real...I'd call them first. |
