E90Post
TNT Racewerks
BMW 3-Series (E90 E92) Forum > E90 / E92 / E93 3-series Technical Forums > BMW Coding > bmw assist error code
Reply
      03-19-2011, 02:31 PM   #1
Meat'sG80
Dictator
Meat'sG80's Avatar
31
Drives: 2023 BMW M3 Competition
Hey guys looked around on this thread, but could not find where anyone had removed the bmw assist error after replacing the stock head unit. Has anyone done this?
thanks
Demetri
      03-19-2011, 02:34 PM   #2
matrix76
matrix76's Avatar
61
Drives: 2020 Z4 M40i Black/Red
You should post your question here;
http://www.e90post.com/forums/showthread.php?t=451145
Brian
Black Sapphire, Black w/Burrwood Trim & Shifter, 162's, Mtec H8 AE's, DS1 HID 6000K
      03-19-2011, 08:58 PM   #3
fdriller9
Drives: '06 AW 330xi
2006 330xi  [6.44]
Did you replace your HU with an oem one?
If not then you broke your most loop and need to join it back together.
      06-14-2011, 02:21 PM   #4
HellsBells
Drives: 335xi
I replaced it with the Dynavin unit, I know others have ran MOST connection to factory HU and put it in the trunk, but why do this if deleting the error is possible?
I just want to know if no one has figured this out or is it just not possible??
      06-14-2011, 03:10 PM   #5
DESI4life10
DESI4life10's Avatar
Drives: Coding: Desi4life10@gmail.com
What error you getting? Sos error? If so you deactivate it by going into the tcum (bluetooth) module. I will confirm the lines when I get home.
      02-20-2013, 05:09 PM   #6
MJ777LR
Drives: 2007 BMW328i
Hi DESI4life10, do you know which lines need to be changed in the TCUM module to code out the SOS error? I recently replaced my faulty MOST HU with a newer non-MOST model, and as expected, I'm getting an SOS error warning. I don't use BMW Assist, etc. anymore, so the error is redundant.
How do I code this out?
      02-25-2013, 10:17 PM   #7
MiamiTuning
Drives: 2015 F80 M3
Kombi module
TCM_ALIVE_MONITOR
aktiv
TCM_ID_MONITOR
aktiv
change to nicht_aktiv
      03-01-2013, 09:03 AM   #8
carlosalbertogui
Drives: bmw E91 facelifted by me
how do i code with ncsexpert ??? .....
please help for dummyds to do this.
      03-03-2013, 02:04 AM   #9
MJ777LR
AZAJ, thanks for the info! I haven't checked here in a while, but I found out too on another forum that those were indeed the right values to set! Cheers!
      04-07-2013, 09:28 PM   #10
gunda
Drives: 2008 BMW 335i e92
Hey, thanks for the information, I got rid of my SOS error as well. I was just wondering, does this disable the use of the SOS button? or can I still click it and connect to BMW assist?
Originally Posted by AZAJ View Post
Kombi module
TCM_ALIVE_MONITOR
aktiv
TCM_ID_MONITOR
aktiv
      04-14-2013, 04:02 PM   #11
graham4
Drives: bmw
Dealer tool or advanced diag tool can reset it.
Reply
e90post
