BMW 3-Series (E90 E92) Forum
WSTO - Pivot Hybrid Gauge *Grand Opening Limited Time Special*
06-14-2010, 05:00 AM | #1 |
1768
Rep 7,652
Pivot Hybrid Gauge The Pivot Hybrid gauge is another easy to use, innovative product by Pivot Japan. The boost gauge is a key missing component in my opinion on the N54 engine cars like the 335i and the 135i. Pivot has an easy solution. The pivot Hybrid gauge system is an easy to install system of 3 gauges (Boost / Water Temp / Exhaust Temp). The gauges are very easy to install as they obtain their reading through the DME via OBD ports. This also simplifies installation as no wire splicing and complicated senders are needed to be routed from the engine bay to the gauges. Only the vacuum line to the diverter valves are tapped for boost readings. Gauges: - Boost (kPa) - Water Temp (Celsius) - Exhaust Temp (Celsius) Ease of Installation: - Comes with specific harness for install to OBD for temperature readings - Boost is tapped via Vacuum line to the diverter valves - No wire splicing - Connects with the Pivot 3-Drive Throttle Controller for multiple instruments - 3D Design Gauge Pod for seamless integration to ash tray compartment Check out installation instruction HERE Video of the Pivot Hybrid Gauge on WSTO Demo car. Limited Time Special (Ends July 5th): Pivot Hybrid Gauge for BMW: $685 Pivot Gauge + 3D Design Gauge Pod: $985 Please feel free to call/email/pm to order! This Special Ends on July 5th!
06-17-2010, 11:51 PM | #4 |
1768
Rep 7,652
The beauties of the Hybrid gauge is in its simplicity and reliability.
It has a CAN Server that translates all the needed temp data and a Boost server that measures the boost. The lighting is not "BMW Orange" but it is very subtle and pleasing. For the Serious Enthusiasts, we offer full line to professional stepper motor gauges by STACK. This is for the daily driver with a tune who likes to keep things in check and make sure you are boosting, right!
