BMW 3-Series (E90 E92) Forum
HID fog light issue. Please help.
03-01-2010, 09:46 PM | #1 |
Rep 663
i have a issue, hopefully some one can help me out. I picked up a set of H11 8k for my fogs from a local company. I went with them because they give the capacitors free with the HID unit as long as you ask for them. going on a 2007 328i.
The issue I have ran into is the capacitors keep blowing out. I made sure the lights were wired correct, which give the flickering effect. If i wired it the other way, no power want so ever. Don't know if someone is local that can help me out with this issue. They already sent me two sets of capacitors to help me out. I got one more set on the way and really don't want to mess those up. here is what i did. I wired them as such, just as instructed here is the complete set up. capacitors are prewired and cover as such i cut one open a blown one to see what size capacitors they are, they are 10000 wired this way in order to get power cause as stated before, if i wired the other way, there is no power to the unit. pretty much stuck right now and don't know what to do. any help would be great and if anyone local can help with this and get them to work, i would buy food or beer. |
03-01-2010, 10:45 PM | #2 |
Rep 108
Ask if you can return them and get a full refund? If they refund you, I know a shop in the LA area that I bought my HID fog lights from, I got them for $105 with the capacitors and no problems whatsoever.
03-01-2010, 11:34 PM | #3 |
Rep 663
i might try to return them if these next capacitors don't work. The only thing i can see them saying no because the HID works just it won't work on my car. it didnt cost me much to get them.
03-02-2010, 09:52 PM | #5 |
hi
129
Rep 1,140
camaross, a vendor on here, sells HID fog light kits i'm in the process to the buying some, he maybe be able to help you out?
also MSD82, created lux angel eyes, could help you out shoot him a PM.
2022 M Sport G05
Jb4, CTS catless dp, M performance exhaust, bms intake, IND goodies, Maxton kit |
03-02-2010, 10:07 PM | #6 |
Rep 543
Drives: Alpine White 335i coupe
bmw polarity is reversed from the standard h8 connectors..make sure the brown wire goes to negative side. To accomplish this you might have to trim the connector in order to flip it. That is the reason why you would be blowing the capacitors
03-02-2010, 11:57 PM | #7 |
Rep 663
thanks, will double check that tomorrow. i did notice there is a solid brown wire and a brown with yellow in it. Just make sure the negative wire (black wire) is connect to the solid brown one, correct?
03-03-2010, 12:13 AM | #8 |
Rep 543
03-03-2010, 11:02 AM | #10 |
Rep 967
Wires are definitely switched. I went through hell getting my HID fogs to work, but now they're perfect and I couldn't be happier.
Also look at the connector going into your ballast...the (-) sign has a red wire going to it. Alwyas try flipping the wires around and flip the switch for just a second to see if that's the problem
| PROcede Rev3 | Vishnu Meth | DCI | BMW Perf. Exhaust | AR Coated/Catless | CP-E FMIC | Quaife | |
03-03-2010, 03:20 PM | #11 | |
Rep 663
