E90Post
TNT Racewerks
BMW 3-Series (E90 E92) Forum > E90 / E92 / E93 3-series Technical Forums > All-Wheel-Drive (Xi / xDrive) Talk > m3 suspension part compatibility
Reply
      02-20-2009, 10:09 AM   #1
stratplaya06
stratplaya06's Avatar
Drives: 2008 E92 335xi-SOLD 5.0 Miata
Hey guys,
I have an 08 e92 335xi, which i put the kw v3 coilovers on. I am now looking to further enhance the handling. PS2's will be put on as soon as the weather gets back to warm, and I am looking to do some m3 parts.
I have heard that the m3 rear sway, in conjunction with the m3 bushings for the front stock bar is a great combo.
Any other suggestions? I would REALLY appreciate if someone would help me out with part numbers etc. as to just what I need to get this car as m3 as it can be.
Thanks in advance
| PROcede Rev3 | Vishnu Meth | DCI | BMW Perf. Exhaust | AR Coated/Catless | CP-E FMIC | Quaife |
      02-20-2009, 11:50 AM   #2
ho_grayson
Drives: 2008 335i sedan
buddy! kw v3 is good enough for daily driving and racing on track. save money for something else!
      02-20-2009, 11:57 AM   #3
stratplaya06
Have everything I want to do to the car done already. It has more than enough power, and looks fantastic. The only thing I want is better handling. I have seen posts on the forum about it, and just want a nice list.
      02-20-2009, 09:34 PM   #4
jgalaxy
Gearing
jgalaxy's Avatar
Drives: E46 M3, F22 M240
The XI's only take advantage of rear M3 components. All front components from the M3 are a no go. The M3 rear sway is likely not worth it at this stage. Minor stiffness for a huge cost. Will you be going to the track frequently? Check out Mr 5 and Orb's discussion threads.
If at first you don't succeed ...
      02-21-2009, 08:37 AM   #5
stratplaya06
I'm more just looking for a little less body roll in turns. I heard bushings make the biggest difference, and would likely do the sways at the same time.
      02-23-2009, 08:46 PM   #6
jgalaxy
Gearing
jgalaxy's Avatar
Changing for coilovers will yield a much greater impact, although the v3s are still not correctly matched.
      02-24-2009, 09:55 AM   #7
stratplaya06
I've already got a set of v3's on there
I remember orb saying that the m3 rear sway in conjunction with the sway bushings front and rear is a good combination to go with the v3's.
I was just wondering the part numbers for these, and if there are any other bushings etc. that I can get installed at the same time in order to save on labor costs.
Reply
e90post
