AutoCompanion
      04-11-2026, 02:49 PM   #1
zxfy
gang gang gang
zxfy's Avatar
Drives: 2023 G80 M3 competition
Need Help: What’s Hurting My 60–130 (Intakes vs Wheels)?
Hey everyone, I could really use some solid input on improving my car’s 60–130 performance because I’ve been getting a lot of mixed opinions.
Right now, I’m trying to figure out what would actually make the biggest difference. A few people have told me my setup might be holding the car back, specifically my BMS top-mount open filter intakes. I’ve been considering switching to the AMS intakes with upgraded inlets, but I’m not sure how much of a real-world gain I’d see.
On the other hand, some friends are saying my wheels might be the issue. I’m running 20-inch Vossen wheels with Continental ExtremeContact DWS06 tires (285/30 all around), and they think the weight could be hurting my performance.
At this point, I just want to focus on what will actually improve my 60–130 times in a noticeable way. If anyone has real experience with either intake setups or lighter wheel setups on similar cars, I’d really appreciate your advice.
      04-11-2026, 03:34 PM   #2
forcefed
forcefed's Avatar
Drives: .
Your tuner is holding you back not wheels or inlets.
Schemxr125.00
      04-11-2026, 03:40 PM   #3
codean
Drives: 1999 Nissan Altima XE
Got to give the basics first:
full mod list
fuel being used
DME tuning being ots or custom
xhp or stock transmission tune
      04-11-2026, 03:44 PM   #4
zxfy
gang gang gang
zxfy's Avatar
full mod list
fuel being used
Downpipe + midpipe and intakes
E55
Mhd flexfuel
Custom bend tune
Xhp stage 3
      04-11-2026, 03:45 PM   #5
zxfy
gang gang gang
zxfy's Avatar
What makes you say this?
      04-11-2026, 04:17 PM   #6
codean
What downpipe, what midpipe?
Which 20" Vossen wheels? Are they big chunky heavy ones?
What ethanol content were you tuned for when Bend was working with you?
Are you logging any of your runs via mhd to see what your engine is doing?
      04-11-2026, 04:22 PM   #7
zxfy
gang gang gang
zxfy's Avatar
[QUOTE=codean;32725888]What downpipe, what midpipe?
Vsfr downpipe and mad 4 inch midpipe
In flex fuel so I can run 93-E60 and I’ve been working with bend for a while he recommended me towards better intakes with the inlets as well
      04-11-2026, 04:51 PM   #8
zxfy
gang gang gang
zxfy's Avatar
I have the HF-5 ones
Also yes I looked at my logs I have a very small amount of boost deviation like 1.5 which I just suspected was normal
      04-11-2026, 05:13 PM   #9
Commanderwiggin
Commanderwiggin's Avatar
Drives: M2C - X3M - Turbo E46 M3 - 45E
Only one person you should listen to and that’s your tuner.
650RWHP F87 M2C
875AWHP F97 X3M
1000+RWHP Turbo E46 M3
ALL TUNED BY BEND CALIBRATION
DLSJ5703.50
      04-11-2026, 05:15 PM   #10
zxfy
gang gang gang
zxfy's Avatar
I agree but I mean I was just getting opinions from everyone so why not ask ya know
But on a real note is this bend I’m convinced ur the guy I email
      04-11-2026, 05:17 PM   #11
Commanderwiggin
Lol, no
650RWHP F87 M2C
875AWHP F97 X3M
revhard74156.00
      04-11-2026, 07:15 PM   #12
zxfy
gang gang gang
zxfy's Avatar
Lol, no
I’m gonna take you up on your word and listen to bend on getting new intakes
I just ordered the ams intakes
      04-11-2026, 10:24 PM   #13
bgalway
Drives: G80 XDrive 23
Post a log
      04-12-2026, 01:14 AM   #14
zxfy
gang gang gang
zxfy's Avatar
Originally Posted by bgalway View Post
Post a log
data zap log
      04-12-2026, 01:30 AM   #15
shaunee
Drives: G80 M3 CX; TTRS; RS3 8V
People overthink this stuff!
Since when has running a 5.7s at these mods considered not performing well?
People going quicker on like for like mods, are either leaning harder on the engine or stripping weight. It's that simple.
You need to strip a decent amount of weight to make a difference as well.
Stage 3 Hybrids M3 CX
99ron (DI only): 60-130 5.8s
E25 (DI only): 60-130 5.6s
zxfy18.00
revhard74156.00
forcefed5117.00
      04-12-2026, 02:56 AM   #16
revhard74
Drives: G80 M3
5.7-6.1 (60-130) is on par for a safe custom tuned e55 map in variable conditions. Yes, your heavy wheels/tire combo and top mount intakes may play a role in your times. Just dont be disappointed if you get front mount intakes and your DA climbs to 3000 the next day and you're slower. If you want to go faster, add PI. If you want to go even faster, upgrade intake manifold and turbos. I can keep going on and on.
forcefed5117.00
      04-12-2026, 09:10 AM   #17
JasonSB
Drives: 2022 BMW M4 XC
Log looks pretty good. AFR is a little leaner than I run,but timing and boost are good with minimal corrections.
      04-12-2026, 10:02 AM   #18
zxfy
gang gang gang
zxfy's Avatar
How much do you think I can do pi with an intake manifold for? I rather not drill the stock one
      04-12-2026, 11:29 AM   #19
I’m not sure what wheels your stock ones are but rule #1 when it comes to aftermarket wheels is you NEVER buy ones that are the same or heavier than your stock wheels when spending money on them. Wheel weight will definitely make a difference in response and acceleration, even from a roll and at speed. Despite some of the bs out there trying to disprove this, I know from first hand experience that it does as I’ve seen it on my own cars over the years, so if you’re concerned about function over form, don’t go backwards on this and buy heavy aftermarket wheels because they look good. That said, shitty intake setup will cause some issues too, so that should have been initial research before buying, like everything else.
The engine is an air pump, so anything to improve upon and minimize pumping loss is a good direction to take.
On the wheels, it looks like those wheels could be as much as 4-7 pounds or more per corner, depending on sizing and depending on what you came from. Did you happen to weight them when you got them to make sure you were shaving weight off each corner rather than adding on?
zxfy18.00
      04-12-2026, 11:30 AM   #20
E55
Mhd flexfuel
Custom bend tune
Xhp stage 3
Brand and type of downpipes and midpipes is also important. What’s the specifics?
zxfy18.00
      04-12-2026, 11:31 AM   #21
zxfy
gang gang gang
zxfy's Avatar
Previous owner put those wheels on the car 🫩🫩
And I have vsfr downpipes and mad 4inch midpipe
      04-12-2026, 11:47 AM   #22
BadBoostedBMWM3
BadBoostedBMWM3's Avatar
Drives: e36m,F80,G80;TRX; 992 TTS; F95
Douglas and Ian know their stuff!
5.7s is well in to the 700whp+ category. There’s nothing to complain about that and simply put the chassis is just heavy.
I’m sure you can squeeze another 20 to 50 wheel horsepower out of it. But it best you might get into the 5.2-5.4 category. I don’t know if that’s worth it!
Take my opinion with a grain of salt, but I have blown up an s58, bent the rods asking for more. Thankfully, I was able to resleeve it and use my block! No, I was not on stock turbos. I was on a 6870 and NO Bend was not my tuner.
This is my signature...
zxfy18.00
DLSJ5703.50
davidatl198.00
