R44 Performance
      03-29-2026, 12:55 PM   #1
R44 Performance
R44 Performance's Avatar
United Kingdom
3112
Drives: 1500 bhp xDrive G87 M2
Tom Wrigley Performance G80 M3 Sets World Record Fastest BMW at Texas 2K26
WATCH HERE:
If you've been following the BMW drag racing scene, no doubt you've come across Tom Wrigley Performance. We've been working with Tom for quite a few years now. He was a key proponent of our G87 M2 xDrive drag build & got behind the wheel last year at Texas 2K25, delivering some great times.
Read more about that here: https://g87.bimmerpost.com/forums/sh....php?t=2172318
A New Benchmark for the BMW S58 Platform
Tom Wrigley’s G80 M3 xDrive has officially become the fastest BMW in the world, recording a 7.674-second quarter mile at 183.94mph, surpassing the previous record of 7.77 seconds at 183mph, and winning the X58 class at Texas 2K26.
This isn’t just a marginal improvement. At this level, shaving even hundredths of a second requires major advancements in setup, power delivery and consistency. This run firmly cements the S58 & B58 platforms as one of the most capable performance engines BMW has ever produced.
From the outside, the car still resembles a G80 M3. Underneath, it is a fully developed drag platform engineered for one purpose: going faster than anything else wearing a BMW badge.
A fully built S58 engine featuring a 5150 AutoSport stroker kit, GSC valvetrain upgrades and a Headgames Motorworks cylinder head forms the foundation. Boost comes from a Precision Next Gen Sportsman turbo via a custom Overkill Performance single turbo setup, a combination Tom has been constantly refining.
The result is a car producing around 1650whp, capable of accelerating to extreme speeds in a timeframe that, not long ago, was reserved for jet-powered dragsters.
Day 1 – Driveshaft Failure
The event started with a driveshaft failure. At this level, that’s part of the game — but the key was how quickly the team got the car back up and running.
Day 4 – Transfer Case Swap
By Day 4, the team were faced with replacing the transfer case. What would normally be a major job was completed in record time, keeping them firmly in the fight.
Day 5 – Finals Pressure
After qualifying in the morning, the car broke an input shaft before the final. With minimal time, the team repaired it and lined up against the GSC A90 Supra.
The Role of Supporting Components
At this level, power alone is not enough. The difference between a fast car and a record-breaking car is how effectively that power is managed and deployed onto the strip.
The mapping, cooling, fuelling, suspension and drivetrain stability all become the drivers behind shaving tenths off your times.
Tom’s setup highlights several key areas where proven components and brands play a decisive role:
CSF Cooling
High horsepower S58 builds generate immense heat, especially under repeated drag runs.
The use of CSF cooling components, including upgraded coolers and a custom front-mounted charge cooling system, ensures consistent intake temperatures and drivetrain reliability. Without this level of thermal control, maintaining performance across runs simply wouldn’t be possible.
Tom was also running CSF's new air-to-air intake manifold. Learn more about this new release here: https://r44performance.com/blogs/the...01-8402-launch
For every day BMW enthusiasts, CSF cooling upgrades offer both reduced heat soak & long-term reliability. When tuning your car, they become even more beneficial.
AST MOTON 3-Way Suspension
Putting 1600+ horsepower down effectively is one of the biggest challenges in drag racing.
The AST MOTON 3-way suspension setup, combined with suspension geometry components, plays a huge role in eliminating squat and maximising traction off the line. It also assists with keeping the wheels straight under extreme load with solid bushes not flexing like rubber or polyurethane items.
Even if you're not pushing as much power as Tom, these modifications can offer noticeable handling and stability improvements whether you tailor it for drag racing, track or fast-road.
Funk Motorsport Heat Management
Components like the Funk Motorsport turbo blanket may seem small in comparison to major hardware, but they are essential in managing engine bay temperatures and protecting surrounding components..
In high-performance builds, controlling heat is just as important as generating power.
For everyday enthusiasts, this means:
  • Better component longevity
  • Reduced heat-related performance loss
  • A more stable overall setup
  • Not Just for 1600whp Builds
While Tom Wrigley’s G80 M3 operates at an extreme level, the significance of this achievement goes far beyond record-breaking numbers.
Most BMW owners are not building full drag cars. However, the same brands and components used in this build are designed with the same principles:
  • Reliability under stress
  • Consistent performance
  • Proven results in demanding conditions
  • Whether it’s a lightly modified street car, a fast road setup or a weekend drag build, these parts deliver tangible improvements without going to the lengths of a full engine or gearbox build.
Tom's record is a clear demonstration of how far the BMW S58 platform can be pushed when the right components, knowledge and development come together.
It also highlights how incredible BMWs have become:
  • The S58 is now a proven high-power platform
  • xDrive systems are redefining traction limits
  • Aftermarket brands are playing a bigger role than ever in performance development
  • For you guys, it means more accessible performance than ever before.
Congratulations to Tom Wrigley Performance
Breaking a world record at this level requires more than just parts. It takes relentless testing, constant iteration and a deep understanding of the platform.
How long do you guys think it will be before we see BMWs dip into the 6's?
We’re proud to support and supply many of the brands involved in this build here at R44 Performance, helping bring race-proven components to BMW owners around the world.
Explore the Parts Behind the Record
If you’re looking to take inspiration from this build, whether for a fast road setup or a serious performance project, the same core upgrade areas apply:
  • Cooling upgrades
  • Suspension setups
  • Heat management solutions
  • Fuelling components
  • Upgraded turbos
  • & more
These are the foundations of any high-performing BMW build, proven not just on the road, but at world-record level!
Appreciate 38
shawnhayes2266.00
6SPDG823827.00
Dieselmd265.00
Jason50450.00
forcefed5048.00
GOLFFRR12356.50
Stin6er291.00
Wanted_M1027.00
Needsdecaf10894.50
MDude340.50
Alan l.6591.00
Msondeck194.50
cfm56d7b7433.50
heymarkv712.00
SCCThree916.50
Holset431.50
doudzi10.50
Mamba352.50
DrePrime104.50
Niko ZV123.00
LucasM3477.50
Davil8578.50
SCD-1983678.50
LAGWAGN962.50
02M3ForMe4447.50
///minh811.50
jpf34022.50
jdmpimp106.50
M4Tejas1177.00
bSwiazzy383.00
      03-29-2026, 01:15 PM   #2
maticCRO
Drives: BMW G82 M4 Competition 2025
Jesus, thats a rocket ship not car
. Congrats to TW team, epic result
If i ever decided to tune my car to 700-800hp,that will be the place i will do it at
      03-29-2026, 01:23 PM   #3
///M4Lou
Drives: 24-x3m40i/23-m4c /24-x3mc/CSL
Dudes' already a legend. Crazy fast.
      03-29-2026, 07:08 PM   #4
Ultimateone
OG E46Fanatic
Ultimateone's Avatar
191
Drives: G82
Insane
      03-30-2026, 08:17 AM   #5
6SPDG82
6SPDG82's Avatar
3827
Drives: 2025 G82 MT, 2026 X5 x40i
2026 X5 40i X-Drive  [8.00]
2025 G82 M4  [9.50]
Ridiculously impressive. Congrats!
I’m curious about the details on the A2A intercooling setup. I understand the manifold design but how did he run the external intercooler(s)?
Did he go with A2A or water based with pump(s)? It looks like water based on what I can see in the front of the car.
Thanks!
2025 Skyscraper Grey manual G82. Instagram: 6SPDG82
2026 Skyscraper Grey X5 40i
      03-30-2026, 08:19 AM   #6
The Guvna
Drives: M3 Comp, Toyota GR Corolla
This is how I imagine myself looking when I get into my car every day
What an achievement!
      03-30-2026, 09:07 AM   #7
Vic55
Vic55's Avatar
26306
Drives: 2024 BMW M3 CS-2025 Audi RS6P
I love that I get to bring this out once again:
2025 Audi RS6 Performance
2024 Mercedes Benz AMG GT63
2022 Porsche Carrera GTS Coupe Shark Blue
2012 Mercedes Benz C63 AMG Black Series Obsidian Black
      03-31-2026, 03:53 AM   #8
R44 Performance
United Kingdom
3112
That power range is honestly the sweet spot in our opinion. We are in this range on our M3 Touring with a Stage 2+. All you need is some downpipes, a midpipe, a high-flow air filter & a flex fuel setup to run ethanol + software of course. Stock engine, stock transmission, stock turbos. It's the best-value setup.
maticCRO1044.50
Dieselmd265.00
///minh811.50
      03-31-2026, 03:57 AM   #9
R44 Performance
United Kingdom
3112
Thanks!
Hello, yes, Tom is running it as an air-to-water cooler with the core mounted at the front. The other competitors in the X58 class ran it as an A2A.
We'll have to do a more detailed look into his setup in the future!
6SPDG823827.00
      03-31-2026, 11:08 AM   #10
christianb5s4
Drives: Built 2001 Audi S4
Absolutely amazing stuff, I have to feel that 6s are not too far off at this point. Also amazing that the driveline has held up relatively well at this power level as a testament to how strong this platform is.
2024 M3 CompX Dravit Grey - MP HAS - Millway - MHC+ carbon - CS ECU software + Full Suite - Fabspeed - MAD - PPF
2019 G05 X5 x40i, built 2001 600whp B5 S4.
      04-01-2026, 07:33 AM   #11
thatsfr3sh
thatsfr3sh's Avatar
Drives: 2018 M3 Competition
Oh to the Moon 🚀
      04-01-2026, 07:54 AM   #12
forcefed
forcefed's Avatar
Drives: .
All of their cars run 10's in the uk, they bring it here and it's 7's
      04-01-2026, 07:59 AM   #13
hotrod182
hotrod182's Avatar
1369
Drives: 2023 i4 M50
That trap speed is awesome. Wonder what the weight of the vehicle is.
      04-01-2026, 08:01 AM   #14
GOLFFRR
GOLFFRR's Avatar
12357
Drives: GOLFFRR cart
gzzz, awesome! great pics also
CURRENT DEALS,ALWAYS UPDATED! CLICK HERE!
FOR ALL SALES:david@bmwdavid.com Cell:202-262-2900
vipfinance@bmwofcamarillo.com for WARRANTIES!
      04-01-2026, 09:12 AM   #15
ASAP
ASAP's Avatar
12636
Drives: '26 G80x M3
This is very impressive of a result... but if you think about it, this car really has nothing to do with a G80 M3 anymore... what transmission and rear end are in this car? its also a fully built s58 w a massive turbo... also is this a stock ecu car?
N54->N55->S55->B58->S58
      04-01-2026, 09:16 AM   #16
I-driver
Passionate
I-driver's Avatar
169
Drives: M340 & i3s
2023 Mini Cooper SE  [0.00]
2019 BMW i3s  [0.00]
2020 BMW M340  [0.00]
One happy rabbit!
They should use it as a Safety Car at the F1 races.
Congrats!
Driven by a 30-year long passion since my first E-30
      04-01-2026, 09:22 AM   #17
Wanted_M
Wanted_M's Avatar
Drives: Frozen Blue M4CS
Captain, Xdrive engaged...
M4CS Frozen Blue
ARM DP's/Resonated Mid-pipe | SPL links | Hotchkis bars | JRZ RS2/camber plates | Infinity Design | Koyorad HX | Powerflex purple | Rouge | Spiegler | Speed Eng. snorkel | Vargas CBC/hub | Wagner IC | xHP | Xpel stealth ppf
      04-01-2026, 10:25 AM   #18
Matt@Evolve
Matt@Evolve's Avatar
2826
Drives: F82 M4, E36 M3 Touring, Z3
Incredible work by all involved!
      04-01-2026, 10:52 AM   #19
G MONEY
Drives: 2017 458/ YAS m4
Hope you have the star rated PS4 on that thing
      04-01-2026, 10:57 AM   #20
G MONEY
Definitely interested to see what is controlling all this? Jb4?
DrewNewM22488.00
      04-01-2026, 11:29 AM   #21
cfm56d7b
Drives: 2025 BMW X6 M60i & 2015 BMW X5
Humbly speaking: truth in engineering delivers amazing performance.
AST MOTON 3-Way Suspension ... solid choice.
maticCRO1044.50
      04-01-2026, 11:42 AM   #22
heymarkv
heymarkv's Avatar
712
Drives: 2018 F82 M4
That’s insanely impressive, congrats to the team! Also highlighting the importance of supporting mods because all that power is wasted if there’s not proper support is major key like ya said. 👌🏼
