Feral Industries
      03-12-2026, 02:52 PM   #1
1rmy7
1rmy7's Avatar
561
Drives: Bmw M4 G82
Should i go for coilovers?
Hey! I have been on H&R has kit adjustable springs and I don’t like at all how the car is riding on the highway,it’s very bunpy and has a very uncontrollable feeling when going over bumps etc,also when i am driving fast in the mountains I don’t trust the car,the steering feels loose and has a dead (numb) center zone (i already have all the cs coding).
What can i do to fix these stuff? Am i asking too much from this car?
I’m currently looking at kw v3’s, hoping to get some feedback…thank you!
      03-12-2026, 03:20 PM   #2
WhiteF30M6Spd
Drives: Brooklyn Gray G80 Comp RWD
It's a yes, but. Answer. In the most simple way, a coilover setup will allow the car to feel different. Due to the subjectivity in what "feels good" means to you, it's hard to say if you will like it or think that it feels better.
Practically all off the shelf coilovers will be much more stiff, so you will trade bouncy for potentially harsh or crashy. For me personally I think with kw, anything less than their club sports is a poor compromise. I also prefer inverted monotube shocks over twin tube.
      03-12-2026, 03:39 PM   #3
1rmy7
1rmy7's Avatar
561
Drives: Bmw M4 G82
Appreciate your input! Is the nitrom r1 any better than the kw v3? I sae that the materials are more for the track rather than daily driving. Would there be any problems with corrosion?
      03-12-2026, 03:51 PM   #4
tom @ eas
tom @ eas's Avatar
2018 BMW i3s  [5.00]
2010 BMW M3  [6.50]
2015 BMW M4  [6.20]
Much different. KW V3 is a street coilover, while Nitron is a Motorsport-oriented kit.
It sounds like you want more of a street-oriented kit. The V3s have stainless housings, which will withstand corrosion.
      03-12-2026, 03:57 PM   #5
1rmy7
1rmy7's Avatar
561
Drives: Bmw M4 G82
Yeah,i am a bit worried about the nitron corroding or having problems longterm, i don’t really like aftermarket parts that need maintenance. I have the opportunity to buy either kw v3 or nitron r1 at about the same price,wich one should i go for?
      03-12-2026, 04:11 PM   #6
tom @ eas
tom @ eas's Avatar
2018 BMW i3s  [5.00]
2010 BMW M3  [6.50]
2015 BMW M4  [6.20]
Since Nitron HQ is headquartered in the UK, I highly doubt rain or wet conditions are an issue for them. They have some of the worst conditions there (ie: corrosion)
If the VTF feels too harsh for your taste, the KW V3 is probably the better fit. Nitrons lean much more toward the Motorsport side of things.
      03-12-2026, 04:38 PM   #7
1rmy7
1rmy7's Avatar
561
Drives: Bmw M4 G82
Appreciate it! The vtf isn’t too harsh, the car doesn’t feel planted at all and the steering is not very precise,it’s kinda loose snd i feel that the car is almost balancing if i can say that when corning fast or going over bumps at higher speeds
      03-12-2026, 05:51 PM   #8
WhiteF30M6Spd
I'm not at all impressed with nitron. If the choice was nitron or kw, I would choose kw.
      03-15-2026, 07:07 PM   #9
1rmy7
1rmy7's Avatar
561
Drives: Bmw M4 G82
Hey! What do you think about sway bars or monoballs?
      03-16-2026, 07:08 AM   #10
D_SheerDrivingPleasure
D_SheerDrivingPleasure's Avatar
1792
Drives: Very Fast F80 & G80
I'll chime in. I would recommend front control arm monoballs no matter that you decide for dampers. They are must have if you want a responsive front end with good steering feedback. Millway, Bimmerworld and others sell them.
Depending on your goals, I would also consider MCS from the USA. I have them on two M cars, including 3WR's on my G80. They are super compliant on the street and incredible on track. The cost is higher but I they are top quality. They are now offering rebuild service in the NL.
If you just want a better ride, I would revert to the EDC. The HAS is only good for eliminating wheel/fender gap.
Dare I squeeze three at yo' cherry M3
cronut698.50
      03-16-2026, 01:33 PM   #11
mike@x-ph.com
mike@x-ph.com's Avatar
why?
https://x-ph.com/sale/
Phone number 725-221-5267
      03-16-2026, 01:55 PM   #12
tom @ eas
tom @ eas's Avatar
2018 BMW i3s  [5.00]
2010 BMW M3  [6.50]
2015 BMW M4  [6.20]
Thrust bearings/monoballs should be the first thing to upgrade. We typically go with the Millway units.
I wouldn’t bother with sway bars. The rear bar is quite a bit of labor to install for very little benefit per dollar. That money is better spent on a proper coilover setup.
      03-16-2026, 02:17 PM   #13
1rmy7
1rmy7's Avatar
561
Drives: Bmw M4 G82
Appreciate it. Are there any megatives of doing monoballs if i am in an area with bad roads? Does it affect other suspension compononents or the actual monoball taking more damage from bad roads?
      03-16-2026, 02:23 PM   #14
tom @ eas
tom @ eas's Avatar
2018 BMW i3s  [5.00]
2010 BMW M3  [6.50]
2015 BMW M4  [6.20]
No downsides at all, other than kicking yourself for not doing it sooner.
      03-16-2026, 02:29 PM   #15
blvck.g82
Drives: BMW M4CX
I had H&R VTF before my Nitron R3's and hated it as well. Love my setup currently and wouldn't change it
Hit_Apex4149.00
      03-16-2026, 05:37 PM   #16
emthreepa
Drives: Mint Green G82 M4 Competition
I went from KW HAS KIT to Ohlins Coilovers and regret ever messing around with the KW HAS KIT. Not that it didn't serve it's purpose, just personally enjoy the coilovers that much more.
      03-16-2026, 06:25 PM   #17
WhiteF30M6Spd
Originally Posted by mike@x-ph.com View Post
why?
They have not demonstrated that they know how to choose good spring rates or match them to a set of shocks, and the shock dyno curves I have seen have bad rebound: compression ratios and as a whole are too stiff.
      03-16-2026, 10:03 PM   #18
cronut
Drives: e36 m3
Raise your ride height OP. Lower is not always better especially for the street. When your tires lose contact with the ground, abrupt change in ride and direction will cause you to lose traction. Coilovers are not necessarily the solution especially for the street.
      03-17-2026, 12:40 PM   #19
TselaG80
Drives: SMB G80 M3 X-Drive
With my new G80 coming in a few months I'm on the fence between
Nitros, KWw, Olins.
car wont be a daily, but also don't super stiff/uncomfortable suspension.
i like the nitros cause they come with their own camber plates.
thoughts?
      03-17-2026, 01:21 PM   #20
tom @ eas
tom @ eas's Avatar
2018 BMW i3s  [5.00]
2010 BMW M3  [6.50]
2015 BMW M4  [6.20]
Nitros, KWw, Olins.
thoughts?
There’s no one-size-fits-all answer here. It really comes down to how your M3 is driven.
If the goal is simply to lower the car and eliminate wheel gap, there’s no reason to spend $6k+ on a motorsport coilover. You won’t be using even a fraction of what that system is designed for. On the flip side, if you’re an aggressive driver or plan to see track time, a HAS setup isn’t going to cut it. There's no damping control, spring rate choices, or overall capability needed for that level of use.
We can include camber plates with any coilover package, but it is nice to have a full complete kit like Nitron. I'll shoot over a PM shortly and we'll discuss your options and get you the perfect setup.
      03-17-2026, 02:17 PM   #21
1rmy7
1rmy7's Avatar
561
Drives: Bmw M4 G82
I’m not low at all, dropped like 20mm maximum
      03-17-2026, 02:38 PM   #22
M4_lgnd
M4_lgnd's Avatar
639
Drives: 2022 G82 M4
I went from KW H.A.S. kit to KW V4 and I couldn't be happier. also did the monoballs and the car feels like a gokart.
2022 G82 Signal Green M4 Competition XDrive
maticCRO1059.50
