Bimmer Car Deals
      08-27-2025, 10:12 AM   #1
analogue
analogue's Avatar
Drives: 1M, iX
BMW M3/M4 Service Bulletin List
Here you will find all of the service bulletins BMW has submitted to NHTSA for the M3 and M4 (G80/G82). Bulletins usually take several weeks to appear in the NHTSA database after they are published internally in BMWTIS.
This thread will be updated with recent bulletins after they land at NHTSA and a reference is published here: https://itsanalogue.github.io/bmw-tsb/G80.html. You can find all of this information on the NHTSA website if you know where to look, but this is a consolidated list and should help search engines find and index the SIB PDFs faster.
Appreciate 13
ADDONE575.50
rush111321.50
ToneM2506.50
forcefed5117.00
Vmaxx2214.00
M2C4ME63.50
OXOJE5545.50
ERNurse184.50
ayilar196.50
M4Tejas1178.50
      08-27-2025, 10:12 AM   #2
analogue
analogue's Avatar
Drives: 1M, iX
Recent Bulletins
SIB 32 01 23 (2026-04-06)
BMW M3 2021,2022,2023,2024
BMW M4 2021,2022,2023,2024
(plus 18 other models)
STEERING, SUSPENSION
When turning the steering wheel while stationary or when driving on uneven roads; cracking, creaking, or knocking noises may be heard.
MC-11031574-0001.pdf
InVeh-InApp-Comm (2026-03-25)
BMW M3 2025
(plus 1 other model)
ENGINE
It was determined that due to a manufacturing defect, there may be a peeling of the sliding layer of the main bearing shells. The peeling may cause engine damage to your vehicle in some cases. The main bearing shells will need to be replaced.
MC-11030317-0001.pdf
SIB 11 01 26 (2026-02-06)
BMW M3 2026
BMW M4 2026
ENGINE
Delivery Stop - Bearing Shell
MC-11029098-0001.pdf
SIB 65 20 25 (2026-01-15)
BMW M3 2025
BMW M4 2025
(plus 11 other models)
ELECTRICAL SYSTEM
After replacing the Multifunctional Display (MFD), the Central Information Display (CID) is black. Thebacklight of the CID is illuminated, and touch function does register an audible sound.
MC-11027777-0001.pdf
SIB 41 07 25 (2026-01-08)
BMW M4 2021,2022,2023,2024,2025
(plus 6 other models)
STRUCTURE: BODY
While driving on a smooth and/or unevenroad, a “cracking” sound is heard from therear wheel arch area (highlighted in orange) on either the right or left side.
MC-11027766-0001.pdf
SIB 34 09 25 (2025-12-17)
BMW M3 2024,2025,2026
BMW M4 2024,2025,2026
(plus 3 other models)
SERVICE BRAKES
There may be an internal leakage in the brake fluid expansion tank (aka brake fluid reservoir). In the rarecase of a leak, the filling level sensor might malfunction over a relatively long period of time.
MC-11026950-0001.pdf
SIB 84 06 25 (2025-10-03)
BMW M3 2023,2024,2025
(plus 17 other models)
ELECTRICAL SYSTEM
In some situations, an emergency call may be triggered in the vehicle without either the customer pressing the SOS Call button, or an airbag deployment event. In some cases, the customer may not even be inside the vehicle.
MC-11024211-0001.pdf
RECALL 25V643000 (2025-09-26)
Affecting 4 total vehicles
BMW M4 2026
ELECTRICAL SYSTEM: 12V/24V/48V BATTERY: CABLES, ELECTRICAL SYSTEM: WIRING: POWER DISTRIBUTION MODULE/IPDM
BMW of North America, LLC (BMW) is recalling certain 2026 M4 and 430i vehicles. The positive battery cables may not be properly connected to the power distribution box, resulting in an engine stall and a fire.
SIB 51 22 22 (2025-09-17)
BMW M3 2021,2022,2023,2024,2025
LATCHES/LOCKS/LINKAGES: HOOD: LATCH, STRUCTURE: BODY
Hood lever is pulled twice but the hood only achieves the pre-latch position on both sides.
MC-11024208-0001.pdf
SIB 65 19 25 (2025-08-26)
BMW M3 2025
BMW M4 2025
(plus 9 other models)
ELECTRICAL SYSTEM
Central Information Display (CID) in the vehicle is black or only displays “BMW”. The head unit (HU-H5) is not responding in ISTA. Additionally, the Receiver Audio Module (RAM), Instrument Cluster (KOMBI) and Telematic Module 4 (TCB4) may not be responding in ISTA.
MC-11022856-0001.pdf
SIB 41 04 24 (2025-08-20)
BMW M3 2025
BMW M4 2025
(plus 12 other models)
STRUCTURE: BODY
A groaning sound from the front of the vehicle while driving can be heard, particularly while cornering. The groaning sound can be heard in the A-pillar/instrument panel area.
MC-11022859-0001.pdf
SIB 12 01 25 (2025-06-06)
BMW M3 2022,2023,2024,2025
BMW M4 2022,2023,2024,2025
(plus 4 other models)
ELECTRICAL SYSTEM
EMISSIONS RECALL 25E-A03: PROGRAM CONTOL UNITS (DME)
MC-11019550-0001.pdf
SIB 66 07 25 (2025-05-30)
BMW M3 2024
BMW M4 2024
(plus 14 other models)
ELECTRICAL SYSTEM
The speed limit warning adopted speed, which is set by the customer, is automatically reverting to lowervalue after an extended duration of the sleep cycle.
MC-11018732-0001.pdf
SIB 34 06 25 (2025-05-02)
BMW M3 2024
BMW M4 2024
(plus 5 other models)
SERVICE BRAKES
Brake “groaning” noises heard at the rear axle at slow speeds, i.e. close to standstill, stop and go driving;when parking or maneuvering.
MC-11018518-0001.pdf
SIB 51 46 16 (2025-02-03)
(plus 71 other models)
STRUCTURE: BODY, STRUCTURE: BODY: TAILGATE
Upon opening and closing the tailgate, a creaking/groaning sound can be heard from tailgate actuator.
MC-11014038-0001.pdf
SIB 34 09 21 (2025-01-14)
BMW M3 2021,2022
BMW M4 2021,2022
POWER TRAIN: AXLE ASSEMBLY, SERVICE BRAKES
A turbine-like noise can be heard from the rear axle while deceleration during the first 300 miles of operation when braking from low speed.
MC-11013041-0001.pdf
SIB 11 05 21 (2024-12-06)
BMW M3 2022
ENGINE, ENGINE AND ENGINE COOLING, FUEL SYSTEM, GASOLINE
The belt pulley on the mechanical coolant pump may fracture allowing the engine drive belt to come off thecoolant pump and alternator.
MC-11012077-0001.pdf
SIB 51 09 23 (2024-08-19)
(plus 10 other models)
VISIBILITY/WIPER, VISIBILITY: POWER WINDOW DEVICES AND CONTROLS
Sudden failure of the power window(s).
MC-11006730-0001.pdf
SIB 11 02 24 (2024-07-17)
BMW M3 2024
BMW M4 2025
ENGINE
The drive belt idler pulley bracket material does not have adequate hardness and the attaching bolts may loosen.
MC-11005212-0001.pdf
SIB 65 04 21 (2024-06-04)
BMW M3 2021
BMW M4 2021
EQUIPMENT: ELECTRICAL: RADIO/TAPE DECK/CD ETC., STRUCTURE: BODY
A rattling/ droning noise is heard in the vehicle interior when the air conditioning (AC) is activated. Vibrationsare felt in the driver’s footwell.
MC-11002861-0001.pdf
SIB 36 01 21 (2024-05-01)
(plus 74 other models)
EQUIPMENT, EQUIPMENT ADAPTIVE/MOBILITY, SERVICE BRAKES, AIR: DISC, STEERING
At low outside temperatures (below 40 degrees F) and slow driving speeds (i.e. when parking, maneuvering)with a large steering angle, the front end can be slightly axially misaligned.
MC-11000563-0001.pdf
SIB 64 04 22 (2024-02-16)
(plus 20 other models)
ELECTRICAL SYSTEM, VISIBILITY: DEFROSTER/DEFOGGER/HVAC SYSTEM
An interference noise (groaning noise) can be heard from within the heating and air-conditioning unit in thecenter of the instrument panel. The groaning noise always occurs when either a ventilation flap, air stratification flap or the recirculated airflap moves to a different position. Due to the complex design of the heating and air-conditioning unit, the kinematics causing it (top or bottom,left or right) may not be able to be precisely located. Depending on the vehicle model, the number of servomotors (and the associated kinematics unit) varies.Various models use either 2 or 3 servomotors.
MC-10250374-0001.pdf
SIB 61 13 05 (2024-01-11)
(plus 362 other models)
ELECTRICAL SYSTEM, EQUIPMENT, EQUIPMENT ADAPTIVE/MOBILITY
The electrical system of BMW vehicles has been subject to an ongoing development process over the last few years. This has led to increased demands being placed on the battery. This document covers important information for the dealer on how to handle "discharged battery" complaints.
MC-10249027-0001.pdf
SIB 31 01 24 (2024-01-09)
SUSPENSION
With the vehicle is on a lift and the front struts are in the extended position, there may be a cracking and orclicking type noise when turning the steering wheel left/right. See attached video V31 01 24. The sound can reoccur when the vehicle is lowered, and the wheels are once again under load. The noise might also be heard for a short time while driving.
MC-10249016-0001.pdf
SIB 61 05 24 (2024-01-05)
(plus 57 other models)
ELECTRICAL SYSTEM, EQUIPMENT: ELECTRICAL: INFOTAINMENT
The Central Information Display goes black intermittently due to resets of the Head Unit (HU-H3). FaultB7F8F9 " "HU-H: Reset" will be stored in the HU-H3.
MC-10249032-0001.pdf
SIB 16 01 23 (2024-01-05)
(plus 51 other models)
A vehicle arrives at your center to be diagnosed for a micro-leak in the fuel evaporative (EVAP) system(NVLD natural vacuum leak detection). For this condition, the following fault is stored in the DME: 190302 - fuel tank ventilation and scavenging air system, micro-leak: leakage more than 0.5mm For: Model vehicles other that the ones listed above, or for EVAP faults related to a "large leak," after confirming that the fuel filler cap is fitted properly, then, proceed to follow the corresponding test plan
MC-10249015-0001.pdf
SIB 52 17 23 (2024-01-02)
ELECTRICAL SYSTEM, SEATS
Customer states one of the front seats is inoperative. The seat heater and power supply are inoperative. During the vehicle test, the seat module does not respond. The power supply fuse for the seat module isfound to have blown.
MC-10249023-0001.pdf
SIB 84 03 23 (2023-12-06)
BMW M3 2022,2023
(plus 15 other models)
ELECTRICAL SYSTEM, EQUIPMENT: ELECTRICAL: WIRELESS CHARGER/CRADLE, EQUIPMENT: OTHER: OWNERS/SERVICE/OTHER MANUAL
BMW AG has issued a Delivery Stop (effective February 9, 2023) on certain Model Year 2022 " 2023 BMW vehicles that were produced between June 29, 2022 and February 16, 2023. This was originally called "Wireless Charging Tray". Software in potentially affected vehicles may not recognize the removal of the digital key (Key Card or mobile phone) from the wireless charging tray, and thereby not meeting a federal requirement. On February 17, 2023 , the Delivery Stop was upgraded to a Non-Compliance Recall (see SI B84 01 23 ). SIB84 01 23 outlined a procedure for vehicles at that time which were- a) in BMW center inventory b) already delivered to customers This new SI B84 03 23 addresses vehicles which were in BMW center inventory or at the Vehicle Distribution Center (VDC) at that time. Those vehicles had the Key Card removed and were able to be retailed to the customer Such vehicles now need to return to the center to receive a new Key Card and updated programming. Please note that vehicles which were already in customer hands will be addressed by an update to SI B8401 23
MC-10248092-0001.pdf
SIB 34 07 14 (2023-10-13)
(plus 29 other models)
SERVICE BRAKES, HYDRAULIC
Functional noises (squealing/honking) when braking shortly before the vehicle comes to a stop. CAUSE Material-
MC-10244237-0001.pdf
SIB 24 04 23 (2023-09-28)
BMW M3 2023
(plus 8 other models)
POWER TRAIN
BMW AG has issued a Delivery Stop (effective September 28, 2023) on certain Model Year 2023 BMWvehicles that were produced between January 23, 2023, and June 15, 2023.
MC-10242970-0001.pdf
SIB 84 09 17 (2023-07-01)
BMW M3 2021
BMW M4 2021
(plus 35 other models)
ELECTRICAL SYSTEM, EQUIPMENT, EQUIPMENT: ELECTRICAL
While using the wireless charger, one or both of the following may occur: 1) The BMW display key or mobile phone becomes hot to the touch, 2) The device switches off due to over temperature (built-in device protection).
MC-10241374-9999.pdf
SIB 63 08 21 (2023-06-01)
(plus 42 other models)
ELECTRICAL SYSTEM, EXTERIOR LIGHTING
Headlight check control (CC) message 128 "High beam headlight failure" is displayed. The following fault codes are stored during a vehicle test: 80419A - Left high-beam headlight: Short circuit and/or 8041A5 - light outputs: Number of permitted short circuit cycles exceeded
MC-10239611-9999.pdf
SIB 63 03 21 (2023-06-01)
(plus 19 other models)
EXTERIOR LIGHTING, EXTERIOR LIGHTING: TAIL LIGHTS
Condensation is present on the inner surfaces in one or both taillights (circled).
MC-10239610-9999.pdf
SIB 12 03 23 (2023-06-01)
(plus 34 other models)
BMW AG has issued a Delivery Stop effective June 6, 2023 on certain Model Year 2023 - 2024 BMW vehicles that were produced between October 26, 2022 and May 8, 2023.
MC-10239601-9999.pdf
SIB 12 01 23 (2023-04-01)
BMW M4 2023
In hot ambient conditions, if the engine was running for a prolonged time while the vehicle is stationary, a jolt may be experienced while lightly accelerating.
MC-10236218-9999.pdf
SIB 84 14 22 (2023-03-01)
BMW M4 2021,2022
(plus 47 other models)
EQUIPMENT: ELECTRICAL: NAVIGATIONAL SYSTEM(GLOBAL POSITIONING SYSTEM), LANE DEPARTURE: LANE KEEP: NAVIGATION SYSTEM/SOFTWARE
Customer is shown an incorrect GPS location in the vehicle (i.e., Nav Map, coordinates).
MC-10235206-9999.pdf
SIB 65 16 23 (2023-03-01)
BMW M4 2021,2022
(plus 49 other models)
Customer states there is no audio playback (telephony, navigation, radio) and system sounds (PDC, turn indicators, acoustic signals) may also have failed.
MC-10235203-9999.pdf
SIB 62 02 23 (2023-03-01)
ELECTRICAL SYSTEM: INSTRUMENT CLUSTER/PANEL
In SPORT mode, a black square appears in the RPM gauge (tachometer) section of the instrument cluster display.
MC-10235198-9999.pdf
RECALL 23V118000 (2023-02-23)
Affecting 120 total vehicles
BMW M3 2023
ELECTRICAL SYSTEM: BODY CONTROL MODULE: SOFTWARE
BMW of North America, LLC (BMW) is recalling certain 2023 330i, 330i xDrive, M340i, M340i xDrive, M3, 330e, 330e xDrive, 430i Convertible, 430i xDrive, M440i, 2022-2023 430i, 430i xDrive, M440i xDrive, i4 eDrive40, and i4 M50 vehicles. During a service visit, a replacement electronic control unit (ECU) may have been installed with incorrect programming, which can cause the automatic door locking (ADL) function to not lock the doors as intended.
RCRIT-23V118-0454.pdf
SIB 61 01 20 (2023-02-01)
BMW M3 2021,2022
BMW M4 2021,2022
(plus 23 other models)
ELECTRICAL SYSTEM, EQUIPMENT, EQUIPMENT ADAPTIVE/MOBILITY, EQUIPMENT: ELECTRICAL: WIRELESS CHARGER/CRADLE, POWER TRAIN
Customer is unable to power up or charge accessories through a plug adapter inserted in the front 12-volt power socket plug. Alternatively, it will only operate when constant downward hand pressure is maintained.
MC-10233162-9999.pdf
SIB 84 12 22 (2022-12-01)
BMW M3 2021,2022
(plus 7 other models)
EQUIPMENT: ELECTRICAL, EQUIPMENT: OTHER: OWNERS/SERVICE/OTHER MANUAL
BMW AG has issued a Delivery Stop (effective November 10, 2022) on a small number of Model Year 2023 BMW vehicles that were produced between August 8, 2022 and October 18, 2022.
MC-10230739-9999.pdf
SIB 61 33 22 (2022-12-01)
BMW M4 2021,2022
(plus 24 other models)
Due to a software error, Remote Software Upgrade (RSU) and Remote Support are currently not possible. Additionally, the Integrated Owner's Handbook cannot be displayed.
MC-10230734-9999.pdf
SIB 17 03 22 (2022-12-01)
BMW M3 2021,2022
BMW M4 2021,2022
ENGINE AND ENGINE COOLING: COOLING SYSTEM
The charge air cooler housing may sperate and lose charging pressure.
MC-10230723-9999.pdf
SIB 12 10 21 (2022-11-01)
BMW M3 2022
(plus 13 other models)
ELECTRICAL SYSTEM, ENGINE, EXTERIOR LIGHTING, POWER TRAIN
Due to an unfavorable operating point, primarily in the low-end torque range, an incorrect detection of amixture that is too rich could happen.
MC-10228426-9999.pdf
SIB 65 20 22 (2022-11-01)
BMW M3 2021,2022
BMW M4 2021,2022
AIR BAGS, ELECTRICAL SYSTEM, LANE DEPARTURE
A check control message for the restraint system appears. In the instrument cluster, the red air bag warning light lights up permanently. One of the following fault codes is stored in the ACSM (air bag control unit): 930949 - Knee airbag, driver: short circuit to negative terminal 93094F - Knee airbag, front passenger: short circuit to negative terminal 93094C - Knee airbag driver's side: Resistance too great 930952 - Knee airbag, front passenger: Resistance too great.
MC-10227929-9999.pdf
SIB 65 19 22 (2022-10-01)
BMW M3 2021,2022
BMW M4 2021,2022
(plus 40 other models)
The customer complains that the radio stations change by themselves.
MC-10227575-9999.pdf
SIB 61 12 22 (2022-10-01)
BMW M3 2021,2022
BMW M4 2021,2022
(plus 41 other models)
VISIBILITY
After opening the vehicle with the radio remote control and changing the profile, the exterior mirror settings are lost.
MC-10227558-9999.pdf
SIB 66 24 19 (2022-09-01)
BMW M3 2021,2022
BMW M4 2021,2022
(plus 61 other models)
ELECTRICAL SYSTEM, ENGINE, EQUIPMENT, EQUIPMENT ADAPTIVE/MOBILITY, EQUIPMENT: ELECTRICAL, STEERING
Vehicle cannot be opened or closed using comfort access, engine start is not possible, and the vehicle may not start when placing the key against the steering column.
MC-10225126-9999.pdf
SIB 65 13 22 (2022-09-01)
BMW M3 2022
ELECTRICAL SYSTEM
After updating dealer owned vehicles to software 22-07-5XX, many current BMW customers and previous Demo users may receive emails stating that they are linked to BMW vehicles they do not own. Also, many users of the MyBMW app may find additional vehicles in their "My Garage" tab that they do not recognize.
MC-10225124-9999.pdf
SIB 61 14 21 (2022-09-01)
BMW M3 2021,2022
ENGINE AND ENGINE COOLING: ENGINE: OIL/LUBRICATION: PRESSURE/TEMPERATURE SENSOR, EQUIPMENT: ELECTRICAL
The BMW Gesture Control function may fail permanently as a result of high temperature fluctuations.
MC-10225117-9999.pdf
SIB 65 09 22 (2022-08-01)
BMW M3 2021,2022
BMW M4 2021,2022
The sound output intermittently drops out entirely. This can be reproduced with all audio sources as well as telephone and voice output.
MC-10224210-9999.pdf
SIB 51 13 22 (2022-08-01)
BMW M3 2021,2022
BMW M4 2021,2022
VEHICLE SPEED CONTROL
During strong acceleration, the fuel filler door possibly opens automatically.
MC-10224205-9999.pdf
SIB 66 24 19 (2022-06-01)
BMW M4 2021,2022
(plus 45 other models)
Vehicle cannot be opened or closed using comfort access, engine start is not possible, and the vehicle may not start when placing the key against the steering column. Note: Opening, closing and starting via the BMW Digital Key or the Digital Key Card are not affected.
MC-10218384-9999.pdf
SIB 65 13 12 (2022-05-01)
BMW M3 2021,2022
BMW M4 2021,2022
(plus 91 other models)
ELECTRICAL SYSTEM
The Headunit High (HU-H), also called NBT, began replacing the Car Information Computer (CIC) on certain MY2013 vehicles with option 609 (as of 7/2012 production). This uses map North America NEXT. The Headunit High 2 (HU-H2), also called NBT-EVO, superseded the NBT HU and was introduced in 3/2014. This uses map North America EVO. The Headunit High 4 (HU-H4, also called MGU21) superseded the MGU starting with certain MY2021 vehicles with option code 6U3 Live Cockpit Professional. This uses map North America JOY. The ENTRY Media/Navigation (HU-B) is the low line business version of the navigation system and was introduced in 3/2014. This uses map North America ROUTE. The ENTRY NAV EVO (HU-B2) replaced Entry Media/Navigation as the low-line business version and was introduced in certain MY2018 vehicles. This uses map North America WAY.
MC-10214990-9999.pdf
SIB 64 02 22 (2022-05-01)
BMW M3 2021,2022
BMW M4 2021,2022
(plus 38 other models)
Mist formation on the windshield inside surface may occur at departure or after MSA (automaticstart/stop). Acoustic abnormality in the area of the recirculated air flap (recirculation flap closing and opening severaltimes). The above may occur individually or in combination.
MC-10214989-9999.pdf
SIB 63 02 22 (2022-05-01)
BMW M3 2021,2022
BMW M4 2021,2022
EXTERIOR LIGHTING: HEADLIGHTS
Excessive condensation has collected in one or both headlights.
MC-10214988-9999.pdf
SIB 64 05 21 (2022-04-01)
BMW M3 2022
ENGINE AND ENGINE COOLING, EQUIPMENT: APPLIANCE: AIR CONDITIONER, STRUCTURE, VISIBILITY: DEFROSTER/DEFOGGER/HVAC SYSTEM: REFRIGERANT HOSES AND FITTINGS
A rattling noise is heard in the vehicle interior when the air conditioning (AC) is activated.
MC-10212798-9999.pdf
SIB 62 02 22 (2022-04-01)
BMW M3 2022
(plus 26 other models)
ELECTRICAL SYSTEM: SOFTWARE
Sport mode is not displayed correctly in the instrument cluster. Instead of a red background in sport mode, the background is displayed in blue (like in Eco Pro mode). Software in the instrument cluster (Kombi).
MC-10212797-9999.pdf
SIB 61 07 22 (2022-04-01)
BMW M3 2022
ELECTRICAL SYSTEM: IGNITION: ANTI-THEFT: IMMOBILIZER/PROXIMITY: KEY/SENDER
Check Control message (CCM) displays "Vehicle key missing" after engine start.
MC-10212795-9999.pdf
SIB 61 01 21 (2022-04-01)
BMW M3 2022
(plus 39 other models)
ELECTRICAL SYSTEM, ELECTRICAL SYSTEM: 12V/24V/48V BATTERY, EQUIPMENT: ELECTRICAL, STRUCTURE: BODY: HOOD
48 V battery may become totally discharged, and possible replacement needed.
MC-10212793-9999.pdf
SIB 36 01 22 (2022-04-01)
BMW M3 2022
EXTERIOR LIGHTING, SERVICE BRAKES, HYDRAULIC, TIRES: PRESSURE MONITORING AND REGULATING SYSTEMS, WHEELS
The customer finds an indication in the myBMWâ?" app that the tires need service due to wear. Even after replacing the tires, the tire service indicator is still present in the myBMW app.
MC-10212790-9999.pdf
SIB 41 02 22 (2022-03-01)
BMW M4 2021,2022
(plus 2 other models)
EQUIPMENT
The trunk floor carpet is wet, primarily on the left side.
MC-10211856-9999.pdf
SIB 84 02 22 (2022-03-01)
BMW M3 2022
ELECTRICAL SYSTEM: SOFTWARE, EQUIPMENT, TIRES: PRESSURE MONITORING AND REGULATING SYSTEMS
The customer finds an indication in the â??myBMWâ?" app that the tires need service due to wear. Even after replacing the tires, the tire service indicator is still present in the myBMW app.
MC-10211810-9999.pdf
SIB 66 15 19 (2022-03-01)
BMW M3 2022
EQUIPMENT, LANE DEPARTURE, STEERING
The steering intervention for Lane Departure Warning (LDW) is too strong (severe), which can create an uncomfortable feeling for the driver. Background: Steering intervention helps keep the vehicle in the lane if the system detects that a lane marking has been crossed. The steering intervention can be noticed on the steering wheel and can be manually overridden at any time.
MC-10211809-9999.pdf
SIB 31 03 18 (2022-02-01)
BMW M3 2021
BMW M4 2021
STEERING
Cracking noises heard from the area of the front axle when rotating the steering while stationary or at low speed.
MC-10214259-9999.pdf
SIB 09 03 21 (2022-02-01)
BMW M3 2021
BMW M4 2021
BACK OVER PREVENTION: SOFTWARE, EQUIPMENT: ELECTRICAL
In some rare cases a customer vehicle might be excluded from one or more Remote Software Upgrade(RSU) campaigns. This SIB gives an overview how to identify these vehicles and how to proceed in case of a customer complaint.
MC-10214254-9999.pdf
SIB 65 12 21 (2022-02-01)
BMW M3 2021
ELECTRICAL SYSTEM, EQUIPMENT ADAPTIVE/MOBILITY, EQUIPMENT: ELECTRICAL: AUX AUDIO JACK/PLUG
BMW AG has issued a Delivery Stop (effective June 9, 2021) on certain Model Year 2021 BMW vehicles that were produced between May 7, 2021 and May 21, 2021. The Receiver Audio Module (RAM) will need to be added to the affected vehicles.
MC-10212528-9999.pdf
SIB 84 05 21 (2021-12-02)
BMW M4 2022
ELECTRICAL SYSTEM: SOFTWARE, EQUIPMENT: ELECTRICAL: ANTENNA
Vehicles which require this Campaign to be completed will show it as ?Open? when checked either in Vehicles which require this Campaign to be completed will show it as ?Open? when checked either in AIR the "Service Menu" of DCSnet (Dealer Communication System), ISPA Next or Warranty Vehicle Inquiry.
MC-10206768-9999.pdf
SIB 84 06 21 (2021-12-01)
BMW M3 2021
BMW M4 2021
(plus 37 other models)
COMMUNICATION: MANUFACTURER TELEMATICS, ELECTRICAL SYSTEM, EQUIPMENT
The SIM card installed in the telematics control unit (ATM2) connects to different mobile providers' networks. However, due to a missing parameter, this does not work and can cause disruption in BMW ConnectedDrive services in areas with insufficient network coverage.
MC-10206692-9999.pdf
SIB 65 21 21 (2021-12-01)
BMW M3 2021
BMW M4 2021
EQUIPMENT, EQUIPMENT: ELECTRICAL: RADIO/TAPE DECK/CD ETC.
SiriusXM satellite radio is not working and does not display a channel list.
MC-10206688-9999.pdf
SIB 61 16 21 (2021-11-01)
BMW M3 2021
BMW M4 2021
The "energy management" Check control message (ID code 415) is falsely displayed when entering the vehicle.
MC-10205095-9999.pdf
SIB 61 15 21 (2021-11-01)
BMW M4 2021
ELECTRICAL SYSTEM: 12V/24V/48V BATTERY, EQUIPMENT, EQUIPMENT ADAPTIVE/MOBILITY
It is possible that the EPP (expanded polypropylene) insert for the lithium-ion battery was not installed in approx. 0.3% of the G82 and G83 vehicles.
MC-10205094-9999.pdf
SIB 65 09 19 (2021-11-01)
BMW M3 2021
BMW M4 2021
ELECTRICAL SYSTEM, EQUIPMENT, EQUIPMENT: ELECTRICAL: NAVIGATIONAL SYSTEM(GLOBAL POSITIONING SYSTEM), EQUIPMENT: ELECTRICAL: RADIO/TAPE DECK/CD ETC.
Customer states the following about their vehicle: active radio or music source is interrupted, the navigation is no longer available, a black screen is shown in the Control Display, the system works again after a short interruption.
MC-10205070-9999.pdf
SIB 11 07 21 (2021-10-08)
BMW M3 2022
BMW M4 2022
POWER TRAIN
MAIN BEARING SHELL.
MC-10204535-9999.pdf
SIB 65 13 12 (2021-09-01)
BMW M3 2021
BMW M4 2021
(plus 30 other models)
The Headunit High (HU-H), also called NBT, began replacing the Car Information Computer (CIC) on certain MY2013 vehicles with option 609 (as of 7/2012 production). This uses map North America NEXT. The Headunit High 2 (HU-H2), also called NBT-EVO, superseded the NBT HU and was introduced in 3/2014. This uses map North America EVO. The Headunit High 3 (HU-H3, also called MGU) superseded the NBT-EVO starting with certain MY2019 vehicles with option code 6U3 Live Cockpit Professional or 6U2 Live Cockpit Plus. This uses map North America LIVE. The ENTRY Media/Navigation (HU-B) is the low line business version of the navigation system and was introduced in 3/2014. This uses map North America ROUTE. The ENTRY NAV EVO (HU-B2) replaced Entry Media/Navigation as the low-line business version and was introduced in certain MY2018 vehicles. This uses map North America WAY.
MC-10204660-9999.pdf
SIB 61 07 21 (2021-09-01)
BMW M3 2021
(plus 59 other models)
EQUIPMENT, EQUIPMENT ADAPTIVE/MOBILITY, STEERING
Groaning, scraping, or squeaking noise coming from the steering wheel area in the interior of the vehicle,when turning the steering wheel.
MC-10203340-9999.pdf
SIB 34 10 19 (2021-09-01)
BMW M3 2021
BMW M4 2021
(plus 27 other models)
SERVICE BRAKES, SERVICE BRAKES, HYDRAULIC
Inform the customer during a consultation that the M Compound (standard equipment) and M Carbon Ceramic (optional) brakes are high-performance brake systems which are designed for sporty, dynamic driving styles. As a side effect of the highest possible brake performance, customers are likely to hear noises due to the extremely resilient materials. In the same conversation, inform the customer that his/her braking performance can help ensure that the noises do not occur or disappear quickly.
MC-10203336-9999.pdf
RECALL 21V554000 (2021-07-22)
Affecting 21537 total vehicles
BMW M3 2021
BMW M4 2021
SEAT BELTS
BMW of North America, LLC (BMW) is recalling certain 2021 2 Series (230i, 230i xDrive, M240i, M240i xDrive), 330e, 330e Xdrive, 4 Series Coupe (430i, 430i xDrive, M440i xDrive) M4 Coupe, M4 Competition Coupe, BMW 4 Series Convertible (430i, M440i), BMW X1 sDrive28i, xDrive28i, 2 Series Gran Coupe (228i, 228i xDrive, M235i xDrive), M2 Competition Coupe, 330i, 330i xDrive, M340i, M340i xDrive, M3, M3 Competition, 530i, 530i xDrive, 540i, 540i xDrive, MINI Hardtop 2 Door (Cooper, CooperS, JCW), X2 sDrive28i, X2 xDrive28i, X2 M35i, Z4 sDrive30i, Z4 M40i, MINI Hardtop 2 Door (Cooper SE), MINI Convertible (Cooper, Cooper S, JCW), MINI Clubman (Cooper S, Cooper S All4, JCW), MINI Countryman (Cooper, Cooper All4, Cooper S, Cooper S All4, JCW All4), Rolls Royce Ghost, MINI Countryman (Cooper S E All4), Rolls Royce Phantom, Rolls Royce Cullinan, and Toyota Supra vehicles. The passenger seat belt Automatic Locking Retractor (ALR) may deactivate early, before the webbing fully retracts. As such, these assemblies fail to comply with the requirements of Federal Motor Vehicle Safety Standard number 208, "Occupant Crash Protection."
RCRIT-21V554-8499.pdf
RCRIT-21V554-3237.pdf
RCRIT-21V554-1114.pdf
RCRIT-21V554-6570.pdf
RCRIT-21V554-5638.pdf
SIB 34 07 21 (2021-07-01)
BMW M3 2021
BMW M4 2021
SERVICE BRAKES, HYDRAULIC: POWER ASSIST: HYDRAULIC
When starting the vehicle vehicle at standstill, various yellow Check Control Messages CCMs appear. ID code 00042: Brake system. Additional notes: Avoid abrupt braking as far as possible. Drive at a moderate speed. Have it checked by your nearest Service Center. ID code 2046: Braking force assistance. Additional notes: Braking force assistance failure. Higher pedal force required for vehicle deceleration. Drive at a moderate speed. Have it checked by your nearest Service Center.
MC-10204625-9999.pdf
SIB 62 03 21 (2021-07-01)
BMW M3 2021
BMW M4 2021
ELECTRICAL SYSTEM: SOFTWARE, ENGINE AND ENGINE COOLING
When the vehicle is operated in Sport Mode, the engine speed is no longer displayed in the BMW Head-Up Display (HUD).
MC-10202474-9999.pdf
SIB 61 08 21 (2021-07-01)
BMW M3 2021
BMW M4 2021
EQUIPMENT
The cigarette lighter is difficult or impossible to pull it out.
MC-10202470-9999.pdf
SIB 61 04 21 (2021-07-01)
BMW M3 2021
BMW M4 2021
(plus 25 other models)
The customer may complain of a check control message stating "Safe share detected" (CCM-ID 953). Check control message can be verified by checking key reader information or performing the Check control message history service function.
MC-10202469-9999.pdf
SIB 65 17 21 (2021-07-01)
BMW M3 2021
BMW M4 2021
The BMW key card cannot be activated. The activation menu in the BMW iDrive is missing.
MC-10201148-9999.pdf
SIB 51 16 21 (2021-07-01)
BMW M3 2021
BMW M4 2021
POWER TRAIN
Noises from the center console shifter cover at low speeds. The noise can be affected by pressing the gearshift lever knob.
MC-10201142-9999.pdf
SIB 65 11 21 (2021-06-01)
BMW M3 2021
BMW M4 2021
(plus 36 other models)
ELECTRICAL SYSTEM: SOFTWARE, EQUIPMENT ADAPTIVE/MOBILITY, EQUIPMENT: ELECTRICAL: RADIO/TAPE DECK/CD ETC.
MC-10200247-9999.pdf
SIB 61 04 21 (2021-06-01)
BMW M3 2021
BMW M4 2021
ELECTRICAL SYSTEM: SOFTWARE, ENGINE, EQUIPMENT
MC-10200237-9999.pdf
SIB 12 03 21 (2021-06-01)
BMW M3 2021
BMW M4 2021
ELECTRICAL SYSTEM: SOFTWARE, EQUIPMENT, EQUIPMENT ADAPTIVE/MOBILITY
Due to an software error, the adaptation values of the actuator contiguous wheel slip limitation (ARB) may be lost.
MC-10200230-9999.pdf
SIB 65 07 21 (2021-05-01)
BMW M3 2021
BMW M4 2021
ELECTRICAL SYSTEM, EQUIPMENT: ELECTRICAL: INFOTAINMENT: BLUETOOTH/WIFI
HU-H3 MGU RESETS DUE TO BLUETOOTH CONNECTION WITH SAMSUNG ANDROID 11 : The head unit resets when using various apps (e.g., YouTube, Spotify, etc) on the connected mobile phone. This affects Samsung mobile phones (e.g., Galaxy S20 / S21) with the Android 11 operating system.
MC-10200482-9999.pdf
SIB 51 11 21 (2021-05-01)
BMW M4 2021
EQUIPMENT, EQUIPMENT ADAPTIVE/MOBILITY, PARKING BRAKE, STRUCTURE: BODY: ROOF AND PILLARS
ROOF TRIM STRIP LOOSE AT REAR: The roof trim strip may be loose at the last (rearmost) clip as shown. This can occur on either side of the roof, or on both sides.
MC-10198904-9999.pdf
SIB 51 10 21 (2021-05-01)
BMW M4 2021
BACK OVER PREVENTION, STRUCTURE: BODY: TRUNK LID
SERVICE ACTION: CHECK BADGE ON TAILGATE, REPLACE IF NECESSARY . The "BMW" trunklid emblem (arrow) which contains the rear-view camera may not have been correctly fastened during vehicle production. It is possible that the emblem & camera may become detached from the vehicle, such as when going through an automated car wash.
MC-10198903-9999.pdf
RECALL 21V298000 (2021-04-28)
Affecting 12 total vehicles
BMW M3 2021
SEAT BELTS: FRONT: BUCKLE ASSEMBLY
BMW of North America, LLC (BMW) is recalling certain 2021 330i, 330i xDrive, M340i, M3, and 330e xDrive vehicles. The bolt securing the seat belt assembly to the frame was not tightened to specification.
RCRIT-21V298-7991.pdf
SIB 51 07 21 (2021-04-01)
BMW M3 2021
BMW M4 2021
STRUCTURE: BODY: DOOR
INCREASED EFFORT REQUIRED TO OPEN DOORS: One or more doors may require increased effort to open.
MC-10194300-9999.pdf
SIB 51 06 21 (2021-03-01)
BMW M4 2021
STREAKS ON FRONT SIDE WINDOWS: Streak marks are visible, most commonly on the upper rear corner of the front side window. The marks can be present anywhere on the rearmost edge of either front window.
MC-10190851-9999.pdf
RECALL 21V062000 (2021-02-10)
Affecting 893 total vehicles
BMW M3 2021
BMW M4 2021
SERVICE BRAKES, HYDRAULIC, SERVICE BRAKES, HYDRAULIC: POWER ASSIST: HYDRAULIC
BMW of North America, LLC (BMW) is recalling certain 2020-2021 8 Series Coupe, Grand Coupe and convertible 840i, 840i xDrive, M850i xDrive, M8 and 740 Li, 740 Li xDrive, 750 Li xDrive, M760 Li xDrive, X6 sDrive40i, X6 xDrive40i, X6 xdrive50i, X6 M50i, X6M, and 2019-2021 X5 sDrive40i, X5 xDrive40i, X5 xDrive50i, X5 M50i, X5M, X7 xDrive40i, X7 xDrive50i, X7 M50i, and 2021 M3, M3 Competition, M4 Coupe, M4 Competition Coupe, X5 xDrive45e, 745 Le xDrive. The rotor and shaft within the integrated brake system may not have been welded properly and could separate during a hard braking event, possibly resulting in a loss of the Antilock Brake System (ABS) and braking assistance.
RCRIT-21V062-2025.pdf
RCRIT-21V062-7131.pdf
SIB 01 12 20 (2020-12-01)
BMW M4 2021
EQUIPMENT: OTHER: OWNERS/SERVICE/OTHER MANUAL, TIRES
BMW MAINTENANCE BOOKLET AND OEM TIRE MANUFACTURERS' WARRANTIES: In efforts to provide a digital experience to our customers, BMW of North America, LLC (BMW NA) is proud to announce a digital version of both the BMW Maintenance Booklet and BMW Original Equipment Manufacturers' (OEM) Tire Warranties.
MC-10186206-9999.pdf
This is an automated post created with code written by a human.
Appreciate 16
'Cane13200.00
Wombo460.00
kgelfen3603029.00
bl1ss191.50
forcefed5117.00
DLSJ5703.50
3some!90.00
zerotrip141.50
      08-27-2025, 07:56 PM   #3
Hit_Apex
...bitching about brake trouble...
Hit_Apex's Avatar
4160
Drives: 21 X5MC | 23 M4CSL
2023 BMW M4 CSL  [0.00]
2021 BMW X5MC  [10.00]
Appreciate the data dump. Not clear what the call to action is but appreciate the consolidated reference.
MBoriPerf109.00
      08-31-2025, 03:57 PM   #4
My M3
My M3's Avatar
Australia
507
Drives: 2023 M3 Competition X Drive
Thanks for that, will need to decipher it all
      09-12-2025, 04:18 PM   #5
MacRozie
Drives: German Rides: Italian
SIB 41 07 25 Is an interesting one. Why wouldn't it also apply to the '25 M3s if it does for every other year and M3 & M4.
Directions: Drill a hole, weld that hole back. Haha
      09-16-2025, 04:33 PM   #6
godunovs65
godunovs65's Avatar
945
Drives: M3
2025 BMW M3 MT  [10.00]
M3 is build in Munich, M4 in Dingolfing. They are more different than people think. It's a relief though, mine has 0 recalls. The night is young yet.
      09-16-2025, 05:22 PM   #7
BMWnation
BMWnation
BMWnation's Avatar
Drives: 335i, 535, M4
Wow - so many parts, so many isses can and do happen
      01-06-2026, 01:15 PM   #8
analogue
analogue's Avatar
Drives: 1M, iX
New 2026-01-06
SERVICE BRAKES
      01-07-2026, 03:21 PM   #9
jbirb305
Drives: 21 G80 6MT & 13 mazdaspeed 3
so what do we do? do we go to the dealer and see if all/any of these need to be fixed?
      01-23-2026, 07:32 AM   #10
analogue
analogue's Avatar
Drives: 1M, iX
New 2026-01-23
BMW M3 2025
BMW M4 2025
ELECTRICAL SYSTEM
STRUCTURE: BODY
      01-25-2026, 01:34 AM   #11
freshxdough
BMW Master Elite Tech | Gen 5 HV | HV Specialist
freshxdough's Avatar
4117
Drives: 27 M3X | 20 iX 50 | 20 X3 M40i
No. Only if you are actually experiencing the complaint described can an SIB be used as a guide to rectify the complaint. You don’t just go to the dealer and say “do all these SIB’s”.
PM me for M Performance Parts prices, M Performance suspension install, OEM+ add ons, Car Eye etc.
      02-24-2026, 03:22 PM   #12
KenJ9384
Drives: BMW ix50, BMW M3 G80
2026 M2/M3/M4 Delivery Stop for Bearing Shell
I have an M3 order sitting at the VPC in the port of Newark due to the this recall I just received from my dealer. I'm expecting an update in about a week on an ETA for when it will be fixed but due to the amount of cars likely involved, it seems like it could be awhile even if they have the parts ready to ship. Curious if anyone else have received any updates like this. Nothing showing in the NHTSA recall list yet when I search the VIN but BMW says my vehicle is definitely impacted.
      03-03-2026, 07:45 AM   #13
analogue
analogue's Avatar
Drives: 1M, iX
New 2026-03-03
BMW M3 2026
BMW M4 2026
ENGINE
      03-30-2026, 05:25 AM   #14
marconi118
Drives: 06/07 e93 335i
strange that the M2 concerned are 1 month later production, maybe the time to send defective bearings from germany to mexico?
waiting my M2 october production, really puzzled by engine reliability, should-I tune or not?
If it goes ka boom?
      03-30-2026, 05:26 AM   #15
marconi118
bmw replaces the whole engine before delivering the car
      03-30-2026, 05:05 PM   #16
metal_driver
Drives: 2027 M3 Competition (on order)
Wow, that can't be cheap.
      04-25-2026, 02:16 AM   #17
freshxdough
4117
unlikely. there was another run of these that affected G80 with stop sale a few years ago and the fix was to replace the bearing shells. Engine replacement was not necessary.
      04-27-2026, 09:51 AM   #18
marconi118
any news about this recall?
It seems only diesel engines are affected
      04-28-2026, 06:34 PM   #19
analogue
analogue's Avatar
Drives: 1M, iX
New 2026-04-28
