02-21-2025, 05:54 PM | #1 |
![]() 247
Rep 255
Axle Back Adding Headliner Rattle
Hello,
Has anyone upgraded their exhaust system and experienced an inside rattle that comes from the headliner? I have ARM downpipes, crossover pipes and mid pipe with IRL axle back with SST valve controller. With everything listed minus the IRL axle back (stock axle back) it did not make the rattle sound. Now it does. All the headliner clips are retained. BMW looked the headliner and had no repair recommendations. When you hear the rattle though and gently push up on the back passenger corner of the headliner, it stops. 2024 G82 M4 Comp Thanks for any suggestions. |
02-22-2025, 10:45 AM | #2 |
![]() 28963
Rep 199,304
Posts ![]() |
The stock muffler is very forgiving; it masks a lot of the unwanted noise. Once you change that, everything will get louder.
Given your setup, I'm not surprised you are getting unwanted noise. you should either go back to stock axle back or switch to catted downpipes + resonated midpipe
https://x-ph.com/sale/ Phone number 702-494-9435 ![]() |
02-22-2025, 01:22 PM | #3 |
![]() 160
Rep 177
It's vibration due to excessive resonance from combination of exhaust parts you put on your car. This is why people on here are on a continuous hunt for a magic exhaust setup that sounds decent and doesn't have drone/resonance issues.
Any rattles you are hearing due to your exhaust parts selection isn't a BMW warranty issue. You can either try to isolate the rattle with sound deadening materials, but you will likely develop new noises over time to have to deal with. Or you can swap out exhaust parts until you find some combo that doesn't cause the issue (like adding a "resonated" midpipe) Have you tried closing the exhaust valves and seeing if it makes a difference? |
Chi5896.00 |
02-22-2025, 09:06 PM | #4 | |
![]() 247
Rep 255
02-23-2025, 12:26 AM | #7 |
![]() ![]() ![]() ![]() 1286
Rep 639
My IRL is pretty drony too, even with a resonated mip pipe. Once I put my catted downpipes on I’m probably going back to the stock axle back.
2024 M3 Comp xDrive
2023 Mach-E Premium AWD |
02-24-2025, 10:06 AM | #8 |
![]() 28963
Rep 199,304
Posts ![]() |
I'm surprised to hear that it drones with stock downpipes and a resonated midpipe. Are you sure it's installed correctly?
02-24-2025, 10:19 AM | #9 | |
Rep 639
I’ve installed quite a few exhausts over my life, so I was fairly confident it was installed correctly. I did take it to an exhaust shop to look at it and make some minor adjustments to get things lined up a little better, still drones.
2024 M3 Comp xDrive
02-24-2025, 12:31 PM | #10 | |
![]() 28963
Rep 199,304
Posts ![]() |
02-24-2025, 03:03 PM | #11 | |
Rep 639
It sounds pretty good 90% of the time, but man when youre going up any type of incline and it’s sitting at 2k rpms it’s pretty ridiculous lol. I can deal with it as it is, but once I put my downpipes in that’s going to push me over the edge I think.
2024 M3 Comp xDrive
02-24-2025, 04:18 PM | #12 | |
![]() 28963
Rep 199,304
Posts ![]() |
GolfCoyote1285.50 |
