01-08-2025, 10:26 AM | #1 |
Rep 3,200
NEW PRODUCT RELEASE: Dinan S58 Power Control Unit (PCU)
Featured on BIMMERPOST.com Part Number(s): D440-0200 & D440-0200-W Applications:
Description: Developed wholly from the ground up, the Dinan Power Control Unit (PCU) is an evolutionary step in Dinan in-line tuning modules based off over a decade of lessons learned in the category. At its core the PCU is similar to its precursors and installs in between select sensors and the ECU, adjusting these signals in order to achieve increased performance the stock programming is unable to approach. However, what sets the PCU apart is its integration into more than just the fundamental boost sensors but also additional connections -- inclusive of OBDII. The result is a more capable system that can do so much more than just increase power. Live monitoring of vehicle health via logging, customizable gauges, and code reading/clearing, among others, are now possible ensuring a seamless tuning experience even a novice can be comfortable with. The Dinan PCU is controlled by a free Bluetooth app, available for both iOS and Android, and is home to all the potent features the device offers. Equipped with 5 different pre-set performance levels, in addition to stock, you can choose to select your desired output and enjoy more power for a true install and forget experience, or you can opt to engage in the more advanced features at your fingertips. Boost by gear customization, as an example, allows you to limit power delivery as you see fit in lower gears ensuring optimum traction and a perfect launch. Where the PCU shines however is in data acquisition and monitoring that gives insight into the vehicles overall health and makes certain your tuned vehicle is always running at peak potential. Safety and reliability have been cornerstones of the Dinan brand for generations and not only does the Dinan PCU not hinder any factory safeguards or emissions controls but incorporates its own safeties as well. Going one step beyond our own internal protections, the PCU also grants the end user the ability to monitor up to 20 different engine parameters in real time via customizable in-app gauges for verification of worry-free operation. Those same parameters can also be logged/viewed in app (or exported to CSV) for further scrutiny if desired. All told, the Dinan PCU delivers more power and more features with improved reliability and drivability than ever offered before. Performance without sacrifice is alive and well! Features/Benefits:
*SKU Variations / Warranty: The Dinan S58 PCU is available with a standard 2-YR product only warranty (Dinan S58 PCU – D440-0200) or a factory matching 4-YR/50k mile warranty (Dinan+ S58 PCU – D440-0200-W) that covers both consequential damages as well as labor reimbursement. Functionally, the units are identical but carry different warranty terms. In the case of the factory matching warranty Dinan+ PCU, the warranty ONLY applies to the first VIN the unit is installed on. Successive VIN’s will not be granted warranty coverage from Dinan. Install Video: Last edited by Dinan_Engineering; 01-10-2025 at 04:18 PM.. |
dancing__narwhal187.50 BMW DIY Guy3606.50 JMD975.50 MaC-N54-E82604.50 Sinister84054.00 RetroGamerJP59.00 Froogie0.00 |
01-08-2025, 12:08 PM | #2 |
Rep 2,584
Weak. The power figures is everything someone needs to see to realize this way of piggyback tuning is weaker and only works within an “allowable correction window” of the stock ECU map. This is why piggybacks will NEVER be as good and as complete a solution as a flash will. I wish these community vendors would spend more of their development costs on finding a States side unlock solution rather than putting out all these useless trinket boxes and passing them on as feasible products. Sorry but 👎.
22
GolfCoyote1242.00 Ghost Ritual165.00 CamasM3e933945.50 afo818279.50 mlouro8530.00 BitchinManWheels346.00 E63M6_G42M240i1117.50 squiggout25.00 Jklad425.50 AtlasF803.00 jamabdi432.50 dime4dice21.50 330iToy75.00 FJ_G020.00 TopG4246.00 Greggoryy89.00 stormlv1146.00 Ram.Rx168.50 MParallel598.00 OwnerF16962.00 Juice2674.50 jib-m21.00 |
01-08-2025, 12:49 PM | #3 |
Rep 197,609
More options is always good, i do wish the warranty one cost less (50% less), it would be a best-seller
Ghost Ritual165.00 ///M TOWN32864.00 dancing__narwhal187.50 LENBMW2.00 JMD975.50 mvigod186.00 RetroGamerJP59.00 |
01-08-2025, 01:21 PM | #4 | |
Rep 3,200
Unfortunately that price point is not practical with the factory matching warranty. Keep in mind covering labor for a dealership just to pull a car in and clear a code and nothing else is a $2-300 expenditure. Let alone actually replacing something. |
33
AhsanU4657.50 mike@x-ph.com27851.50 Jnat1009.50 Info@mad-us.com3358.50 JPV21.50 Ilma195.00 bSwiazzy267.50 viciousmo489.50 SnowBob38.50 dancing__narwhal187.50 Hit_Apex3182.50 LENBMW2.00 AM340iMiami284.00 Bumpinjeep6419.50 CamasM3e933945.50 sirwestofash59.00 CJ4212037.00 werdn714.50 stormtrooper.g8377.00 squiggout25.00 Evinrude19751201.00 mPlasticDesign699.50 pizza2401181.00 lofrese1265.50 Ragged Edge371.00 JohnEnglish293.00 BimmerXdrive381.50 MPR2021.50 ficuswhisperer48.00 mrdudley596.50 MM23.00 tyler8892@gmail.com38.00 RetroGamerJP59.00 |
01-08-2025, 01:34 PM | #5 |
i can haz horsepowr ??
4658
Rep 2,110
I'm guessing that boost levels/power in general is less on the base model G8X vs the Competition models?
@maldives.g80
Gone but not forgotten: G80 M3, 991.1 GT3, F80 M3 ZCP, E46 M3 |
01-08-2025, 02:20 PM | #6 |
Rep 3,200
dancing__narwhal187.50 sirwestofash59.00 |
01-08-2025, 02:44 PM | #8 |
Rep 3,200
sirwestofash59.00 |
01-08-2025, 03:54 PM | #9 | |
Rep 2,584
Oh and anyone with a pre 2025 M2 that wants more power (20HP gain) should just run the 2025 M2 BMW factory calibration. It’s flashable without an unlock on that car. Couple that with CSL coding and you’ll have a nice OEM+ response on your hands out of it for a couple of hundred bucks. Last edited by SwankPeRFection; 01-08-2025 at 04:00 PM.. |
01-09-2025, 11:44 AM | #10 | |
Rep 197,609
Piggybacks are for customers that dont want to send their DME overseas. In this case, it makes little sense to compare this product to a flash tune (which is not an option for the target audience) and more sense to compare it to other piggybacks on the market.
9
///M TOWN32864.00 ledphut1003.00 les anderson175.50 roku.g9302.00 brow08140.00 Needsdecaf8595.00 CASHM31.50 m240nj116.50 RetroGamerJP59.00 |
01-09-2025, 12:38 PM | #11 |
Rep 109
Drives: 2023 BMW M3 6MT
Just to confirm, will the Dinan S58 PCU work with the G80 M3 manual? What are the HP and torque increases for the manual M3?
Retired: 2011 BMW 323i, 2012 335i Sportline
Current: 2017 340i | MPPSK | 8AT | Current: 2023 M3 /// | 6MT | Aventurine Red III | |
01-09-2025, 04:01 PM | #12 |
Rep 3,200
Yes it works on the manual as well. A MT G80 would effectively be the same chart as the G87 chart shown above. Delta's across the board regardless of platform are all going to be in ~60-70HP/TRQ range. Final numbers will differ simply based of of varying starting points.
sirwestofash59.00 CASHM31.50 |
01-09-2025, 09:23 PM | #14 |
Enthusiast
Rep 35
Drives: 2024 BMW M3 Comp xDrive
There seems to be a data logging aspect provided with the PCU, but will Dinan review said data logs from buyers and provide guidance on which map to use or parameters to adjust like BMS does with their JB4?
01-10-2025, 05:00 AM | #15 |
Rep 90
Interesting proposition for those that don't want to unlock, but want a bit more than a "normal" tuning box (like logging and DTC clearing in one unit) and are not interested in JB4 capability. I suspect this is probably more appealing to those in the EU, purely because the US has freer access to ethanol so JB4 is probably the "go to" option.
As said above, more options is never a bad thing. At the end of the day the choice is yours as a consumer. From my experience I have found tuning boxes work very well on the S58 platform (one of the very few platforms I would say such a thing), and for those owners that don't want to unlock, a tuning box is certainly a viable and worthwhile option for additional performance. |
01-10-2025, 06:48 AM | #16 |
Rep 21
worth it, just for the warranty aspect alone. not everyone wants to make a 1000whp
01-10-2025, 09:32 AM | #17 |
Rep 1,349
Drives: 2025 G82 MT, 2022 X7 40i
I’m curious as to how the warranty works? Does Dinan deal directly with the supporting dealer.
2025 skyscraper grey manual G82. Instagram: 6SPDG82
01-10-2025, 11:20 AM | #18 | |||
Rep 3,200
The PCU is a "canned tune" and there is no real customization or parameters to adjust (outside of the boost by gear which is arguably kind of customization) so there is no need to check logs to verify proper running. You run the appropriate octane for the level chosen and the PCU should just be plug and play with the logging aspect being a tool for trouble shooting should something come up down the line or with a new hardware modification or what have you. That said, if there is an issue upon install and the car does not run right or causes a CEL, etc. the support team will likely request some logs to assist in determining what may be at play so the issue can be resolved. Quote:
01-10-2025, 11:49 AM | #19 |
Rep 27
If I’m reading this right, for 1995.00 for full warranty, you are plugging in 60 more hp? Seems like a good deal to me? I’m not big into flash tunes. Too many tuners try using the “bad gas” excuse for my liking.
01-10-2025, 02:14 PM | #20 | |
Rep 197,609
$599 no warranty $1999 with warranty its a question on whether you want the extra peace of mind.
01-10-2025, 02:17 PM | #21 |
Rep 80
Could you share what a 2025 M2 would gain on 91 octane? We only get low octane here in Arizona.
Current - 2024 Ram 2500, 2024 Volvo XC60 T8 Recharge, 1998 BMW M3 race car, 2022 Radical SR3XX
Past - 2020 Toyota Supra, 2019 Porsche GT3RS, 2019 Porsche GTS, 2014 Audi S4, 2012 Subaru BRZ, 2001 VW Jetta 1.8t |
summitauto1.50 |
