European Auto Source (EAS)
      10-31-2024, 04:27 PM   #1
rhmarquez
rhmarquez's Avatar
Drives: 2014 BMW 435i
G82 Full Speaker Replacement
Hi, I recently acquired the full Bavsound setup (Ghost subs + Stage 1 kit) for my 21’ G82 with Harman Kardon. I was able to find a tutorial on how to replace every speaker, except for the Rear-Passenger Side speakers. Anyone have an idea on how to do this? Thanks in advance!
2014 F32 435i M-Package | Alpine White with Dakota Red interior | ESS Tune | AFE Power Intake, Charge Pipe | M-Performance Exhaust | Bilstein B8 Struts | 19inch Vorsteiner Wheels with Michelin Pilot Sport 4S | Carbon Fiber goodies
      11-22-2024, 12:29 PM   #2
stbm5
Drives: 2018 M5 DG
I previously did this on an older M4, I don't recall it was any different from doing the front speakers. I had never done a speaker installation before and thought it was all really easy. have good trim tools, that helps a lot. I bought some others that weren't from bavsound and think they were better. also have on hand extra fasteners and cloth tape. also put something on the floor so you don't scuff anything. helps to have an extra person when taking off the door panels, they can hold it up while you disconnect things.
      11-23-2024, 04:00 PM   #3
Sandman03456
Drives: 2023 BMW M4 CSL
I am looking for the same information if anyone has any experience. Thank you in advance.
      11-23-2024, 04:14 PM   #4
Sandman03456
This video may shed some light although it is an M8?
      11-23-2024, 04:26 PM   #5
rhmarquez
rhmarquez's Avatar
https://youtu.be/Bg6H5xJolXg
Yes I ended up removing them using that video, but it’s a little different.
I basically removed the rear seat cusion (like in the video), removed the door sill plastic, and was able to start prying the rear panel off the clips. In addition to the regular fasteners, there are around 6 clips at the top of the panel that hold it against the window. I did not remove the rear seat airbags at all or the rear side panel completely. I was able to replace the speakers by just separating and moving it back.
For the clips just below the window, when I pulled the panel, they unclipped from the window and stayed in the panel. Make sure you remove them from the panel, and reinstall them in the window bracket before re-installing. Attached below is a picture of the clips I’m talking about.
      11-25-2024, 11:04 AM   #6
Sandman03456
Thank you for the advice.
      12-09-2024, 01:05 PM   #7
Sandman03456
Although not a G82, probably similar install?
