NW Carbon Haus
      10-01-2024, 01:23 PM   #1
NYG
NYG's Avatar
Drives: Audi R8
MP HAS clearances for track wheels
So I've decided on my track wheels and I'm going staggered.
19x10 ET9 / 19x11 ET18
I'm going to be running 275/35 front and 285/35 rear Track Attacks (for now).
According to my offset calculators, I should be 5mm further from the suspension strut in the front but 5mm closer to the rear strut.
Should I assume that I'll need a 5mm spacer? Anyone running similar offsets wheels with HAS that knows if they clear?
I'm trying to be proactive here because by the time I get everything mounted and check it all out, my next track day will be here.
      10-01-2024, 01:32 PM   #2
NYG
NYG's Avatar
Drives: Audi R8
Screw it, I ordered spacers. Just to be safe.
Either way, if anyone is running something similar and has some input - I'd appreciate it.
      10-02-2024, 09:43 AM   #3
Hit_Apex
Riding the knock sensor
Hit_Apex's Avatar
3124
Drives: 21 X5MC | 23 M4CSL
2023 BMW M4 CSL  [0.00]
2021 BMW X5MC  [10.00]
You wont need a spacer in the rear with that setup but you might try it for looks.
NYG12504.50
      10-02-2024, 11:19 AM   #4
NYG
NYG's Avatar
Drives: Audi R8
Ty brotha
      10-02-2024, 12:30 PM   #5
BackOnBlack
Keep Up the RPMs
BackOnBlack's Avatar
1350
Drives: M3CS
2005 BMW 645Ci  [0.00]
2024 BMW M3 CS  [9.80]
If you are going to run spacers less than 12 mm, please be mindful that there is a safety risk with hub-centric ones. Overtime they may get weaker where the wheel mounts and break.
Cheers,
BoB
NYG12504.50
      10-02-2024, 12:50 PM   #6
NYG
NYG's Avatar
Drives: Audi R8
I would run a 5mm if I have to just to push it to factory offset.
      10-02-2024, 04:20 PM   #7
nizona
Drives: G82 M4 2023
I have 11x19 et12 with 295 and no rubbing rear
NYG12504.50
      10-03-2024, 12:08 PM   #8
NYG
NYG's Avatar
Drives: Audi R8
Are you on MP HAS?
      10-06-2024, 07:15 AM   #9
nizona
Drives: G82 M4 2023
Are you on MP HAS?
No stock suspension and I forgot to mention the tires are PS4s
NYG12504.50
