Feral Industries
      09-26-2024, 12:10 AM   #1
HP Autosport
Supreme Allied Commander
Drives: F80 M3
Location: Santa Barbara, AP Racing, Brembo, GIAC, Nitron, Ohlins, Pagid, www.hpautosport.com
HKSTUDIE Colovers with Camber Plates & EDC Canceller for G80/G82
HKS HKSTUDIE SUSPENSION with CANCELLER for G80/G82
For 2WD/4WD models.
HKSTUDIE is a collaboration product between HKS and Studie AG.
Balancing high speed stability and comfort for city driving
The G8X generation M has electrically adjustable dampers as stock, and while they provide the stability typical characteristics of the M series at high speeds, they still are a bit stiff in daily driving, even in “COMFORT” mode. The HKSTUDIE SUSPENSION was developed based on the concept of “Balancing high speed stability and comfort for city driving”.
High rigidity inverted dampers are used
The mono-tube dampers are equipped, which enables the use of a large-diameter piston and provides high-quality and stable damping force. In addition, high rigidity inverted dampers are used for the front suspension, as the strut type suspension system is subject to heavy bending loads during acceleration, deceleration and cornering. This leads to excellent handling.
Fully-threaded shock body
Fully-threaded shock body is adopted for both front and rear, allowing adjustment to the desired ride height without affecting ride comfort by changing the amount of damper retraction stroke or spring pre-load. Wheel gap between the front tire and fender is noticeably big with the stock ride height, so we set the front end slightly lower relative to the rear to obtain a more stylish appearance and improve high-speed driving stability.
The 30-level damping force adjustment
The 30-level damping force adjustment allows the driver to set the preferred damping force to suit various driving conditions, from city driving to the race track. You will experience the evolved “The Ultimate Driving Machine” by having balanced performance of smooth ride on the street and a steady driving feel at high speed, perfect for the M series.
Features the camber-adjustable top hat
The front unit features the camber-adjustable spherical-bearing top hats for sharp handling. CNC machined aluminum top hats are adopted for the rear unit.
Suspension Error Canceller
“Suspension Error Canceller” is included in the kit to delete the error light upon removal of the electrically adjustable damper.
3-year/60,000 km product warranty
Spring Rate F=7kg R=14kg
More info on HKSTUDIE's site:
https://www.hkstudie.com/en/suspensi...die-ss001c-en/
      09-26-2024, 12:17 AM   #2
HP Autosport
Drives: F80 M3
It looks like an excellent coilover kit for street duty with improvements in handling and stability without sacrificing comfort.
JTO246891.50
      09-26-2024, 12:14 PM   #3
TselaG80
Drives: SMB G80 M3 X-Drive
has anyone tested these out yet ?
      09-26-2024, 12:24 PM   #4
HP Autosport
Drives: F80 M3
No, it's not likely here in the States. These just landed the other day.
HKS and Studie are both very well-known brands worldwide. Their collaboration wouldn't disappoint.
      09-26-2024, 02:13 PM   #5
evoi19
evoi19's Avatar
Drives: 2026 FG G82
2026 G82  [10.00]
I’d be willing to test this. I know it just came out but interested to compare these to my kw v3 also.
      09-27-2024, 10:55 AM   #6
HP Autosport
Drives: F80 M3
PM incoming.
      09-27-2024, 10:56 AM   #7
GolfCoyote
GolfCoyote's Avatar
2140
Drives: 2024 M3 Comp xDrive
I bet these are great, but I also bet they are $$$ knowing Studie
2024 M3 Comp xDrive (725whp/636tq)
2023 Mach-E Premium AWD
      10-13-2024, 04:21 PM   #8
peterfromsd
oem plus
406
Drives: ‘24 M3
MSRP is $3500 on HKS site. I’d be interested in these as well.
      10-14-2024, 01:48 PM   #9
HP Autosport
Drives: F80 M3
Your PM replied with a ship to your door promotional pricing!
      10-14-2024, 05:05 PM   #10
2Times
I'd hit it
2Times's Avatar
1803
Drives: G82
2023 BMW M4 xd  [10.00]
I see these popping up in my ads but haven't seen any feedback yet. Feel free to DM me pricing also... actually looking for a drag setup
2023 M4 xd BSM
IG: MFor_YourPleasure
      10-19-2024, 01:46 PM   #11
RandomBro
Drives: BMW M2 (G87)
Also curious what this promo pricing looks like
      10-22-2024, 02:57 PM   #12
HP Autosport
Drives: F80 M3
PM incoming!
      10-22-2024, 06:48 PM   #13
DKNICK
Drives: 2019 GO5 X40i
I’m very interested in testing these out,
Looking to replace AST springs.
Been shopping for the right coilover option. Also, work at a performance shop, so could video and photograph install.
MenaceM4_G82 on Instagram
      03-12-2025, 08:51 PM   #14
B2Gs
Brad
B2Gs's Avatar
Drives: 2023 SPY M3Cx, SC Hightower 3
Anyone tried? I love HKS and Studie, watched all the videos. Doesn't that HKStudie exhaust just sound purrfect!
      04-06-2026, 03:40 PM   #15
it.g.ma_g87
papi chino
it.g.ma_g87's Avatar
Drives: 24' M2
I just installed this set last week on my g87 M2!
The kit is very nice and all high quality, my understanding is that is the HKS Hipermax S that’s been tuned for the g8x chassis by Studie AG.
Best way to explain is that the ride feels like sport edc dampening but more comfortable. It’s very planted and stable.
This set comes with camber plates and edc cancel so it’s good value for a st comfort oriented coilover compared to v3 or ohlin where you pay an additional 1.5k for those
B2Gs79.50
      04-07-2026, 08:49 AM   #16
WhiteF30M6Spd
Drives: Brooklyn Gray G80 Comp RWD
Looking at their website it's a linear piston but they say "dual preload" which can give you a digressive curve. Digression is usually achieved via free bleed, my guess is they preload and then rely on the bleed adjuster for their 30 clicks of adjustment.
The F vs V graph they have shows damper curve shape with no measurements and only the rebound side. Not knowing what adjustment position is being shown, there is no way to say exactly how these will feel.
Spring rates are 394lbs front and 782 lbs rear
Their bump rubber is softer and more progressive, which is a good thing.
These appear to have a lot of potential as a very good street coilover and probably a fair entry/intermediate skill track coilover.
      04-07-2026, 07:00 PM   #17
stbm5
Drives: 2018 M5 DG
interested in these and also their exhaust
      04-07-2026, 10:04 PM   #18
UsualSuspect
Lieutenant General ***
UsualSuspect's Avatar
71
Drives: '26 M3 CX '20 X3MC '20 AMGGTC
HKSTUDIE coilovers
I'm interested in these coilovers. Hopefully a PM with that special pricing too.
For 2WD/4WD models.
Everyone has a photographic memory, some just don't have film.
      04-09-2026, 09:25 AM   #19
singh1
singh1's Avatar
221
Drives: 2024 M4 competition X-Drive
Just got these installed on my G 82 x-drive.
I had my performance shop Install them and set them to the manuals recommended Setting for dampening & compression — but they felt so comfortable. I had them tighten up the rebound setting even more
Overall, still figuring them out, but love the look and fee.
JTO246891.50
AlterZgo1764.00
