09-13-2024, 07:46 PM | #1 |
Rep 89
Track setup advice
Wanted to reach out to the big brains on this board for some advice.
Car is an M3 Comp Xdrive. My usage: Currently run the stock staggered setup in summer. Also do 5 non-competitive lapping days each summer. Have about 300 laps or 600 miles on track in this car. Am an intermediate skill level driver (not trying to set lap records). Track time is all on star PS4S and Pzero. Got 4 sessions out of my Pzeros and they wore really nicely. Switched to PS4s and they are pretty chewed up after a single session as I am getting much faster. I guess it's time to finally bite the bullet and address this. Tires are overheating, overstressed and the weight of the car is too much. Thinking about this setup: 827m square 19" 9.5" which I can get for less money than Apex wheels. Would just use 4 front 827m wheels. AD09 or RS4 tires. Prefer AD09 because I want to be able to rotate them on 4 corners. Questions: Are the AD09s going to wear as good as the RS4? I only have experience with RS4 and note them as a good endurance tire. Are either of these really going to last materially longer than the PS4S given the TW200 tires are more resistant to heat? Have considered Millway street camber plates but I really don't want to be doing endless adjustments and alignments. Is doing this setup and just rotating these tires after every track day a rational way to avoid getting them? I would be putting the stock PS4S and staggered setup back on after each track day. Is this setup going to ruin the feel of the car on track? Do the rears really need to be 285? Anyone have an experience running a 275 square setup with x drive on track? Do I really need rear spacers if I do this setup? Is 12mm correct? Do I need longer bolts? I run the BMW 275 35 19 square setup in winter but know the rear wheels are 10" and the fronts are 9.5". Is any of this rational? I'm trying the impossible of trying to make this a hybrid track street car and want to address the tire wear issue while also maintaining the street ability of the car which I drive to the office year round as well. Thanks! Last edited by silvermanor; 09-14-2024 at 01:24 AM.. |
09-17-2024, 06:24 AM | #2 |
How Low Can You Go
353
Rep 130
I've got a similar use case to yours, and I went in a pretty similar route to what you're suggesting. I have no experience with the RS4s, but I can compare the PS4S to the AD09 and the difference is night and day in track use, in grip, heat management and also wear.
Differences in my setup are the following: - I went square 285/35/19 on a 10.5" wheel - the stock rears are 10.5", not 10". I'm not sure what is the offset of the 827m on 9.5", you'll probably not need such a big spacer, but you'll definitely need a spacer, at least to keep the stock wheel geometry and track width. - Camber plates on the front with camber set to -3.2º on the front and -1.8º in the rear. Big difference specially in the wear of the outside shoulder, also a bit better grip when loaded up. Going for a 275 instead of a 285 will not differ a lot, specially considering that thread width will vary with different tires. The balance of the car with the square setup has improved for my liking, with a bit more natural oversteery feeling without being overwhelming, the car just rotates better. Important note, I don't daily this car - I use it for maybe 80-20 street-track, but on the street I mostly do some canyon carving on the weekends. |
09-17-2024, 10:32 AM | #3 | ||||
Keep Up the RPMs
1355
Rep 537
Drives: M3CS
Your experience with the tires mimic mine, especially about overheating. I have been looking at various tires just to get similar grip to PS4S, but that would stay consistent throughout lapping sessions. I was pretty much settled on AD09s, but most recent tire test by GRM is changing my mind towards Conti ExtremeContact Sport 02s. Quote:
Cheers,
BoB |
09-17-2024, 11:22 AM | #4 | |
Rep 89
It's interesting that the apex wheels everyone suggests on here is also a 9.5" wheel and most guys run 285s on them. Thoughts? Last edited by silvermanor; 09-17-2024 at 02:32 PM.. |
BackOnBlack1355.00 |
09-17-2024, 11:23 AM | #5 | |
Rep 89
09-17-2024, 12:13 PM | #6 | |
Rep 673
BackOnBlack how we think alike. I too have a few hundred track miles on my PS4 w/OEM wheels. Roughly 8K miles and have possibly another track weekend (coming up) left in it. The outside tires took a massive beating, and will continue to as your progressively push the car more. Obviously the best way to adjust the camber is with a pyrometer on track but this will be my fun and occasional NASA Time Trial (TT4) and I have no intentions of building to pointy end of the rules. I recently got Ground Control camber plates and intend to set the front camber to -2.4 and rears to -1.9 and call it day. You will need some camber up front otherwise the outside will take a beating, another option is to get the CSL hubs. Got a set of 10.5 by 19 ET15 wheels but would then need to modify the fender liners or possibly run spacers (could have gotten away) but another forum member traded me his OEM wheels with 3K PZ4 for my wheels (no tires) so will stick with just that. When the tires wear off, I'll likely run AD09 or Conti like Bob pointed out. Hope this helps. Lutfy |
09-17-2024, 12:36 PM | #7 | |
Rep 89
09-17-2024, 03:50 PM | #8 | |
Keep Up the RPMs
1355
Rep 537
Drives: M3CS
Also, do check out the GC camber plates from Bimmerworld, I think they maybe better than Millway.
Cheers,
BoB |
silvermanor115.50 |
09-17-2024, 03:55 PM | #9 | |
Keep Up the RPMs
1355
Rep 537
Drives: M3CS
I'll see if I can dyno the car during the November event, then I'll figure out my final numbers, then decide on tires.
Cheers,
BoB |
09-17-2024, 06:03 PM | #10 | |
Rep 89
09-18-2024, 10:19 AM | #11 | |
Rep 673
silvermanor these cars are amazingly well engineered. Whatever you do, weight is of course against us. Some camber and you will have a lot of fun! Enjoy in good health mate. Lutfy |
BackOnBlack1355.00 silvermanor115.50 |
09-19-2024, 02:51 AM | #12 | |
Rep 89
09-19-2024, 10:23 AM | #13 | |
Keep Up the RPMs
1355
Rep 537
Drives: M3CS
Frankly, it is nearly perfect out of the box. The only modifications I did was add braking cooling, new brake fluid and pads, and added 10mm spacers (should have gone with 12 mm though), that is it. For lapping around, I am good to go, nothing else needed to have fun. I manage my tires carefully, and still on OEM ones. So, I'd say, it is good to go out of the box for tracking, but not quite ready for track records
Cheers,
BoB |
