Feral Industries
      09-09-2024, 02:37 PM   #1
papaman1234
Drives: BMW g80 m3
Upgraded turbos and supporting mods
Hey guys, I’m looking to upgrade my turbos on my G80 to the pure turbos. Although right now I’m running just e50 and catless down pipes and intakes. What mods do I need to support upgraded turbos? Do I need upgraded manifold and charge pipes? I’m looking at probably just do E 50 on upgraded turbos.
      09-09-2024, 03:37 PM   #2
Schulminator
Schulminator's Avatar
828
Drives: 2023 SSG G80 Xdrive
Depends on how your power level goals. Pures can support over 900WHP. I would think at the very least you should add a drop in LPFP.
      09-09-2024, 04:51 PM   #3
forcefed
forcefed's Avatar
Drives: .
Trans... if you want to push them to the limit.
      09-09-2024, 11:32 PM   #4
lopeydeath
Drives: 2023 G82 M4C
https://g80.bimmerpost.com/forums/sh....php?t=2104259
Lots of good info.
      09-10-2024, 11:36 AM   #5
mike@x-ph.com
mike@x-ph.com's Avatar
+1
The upgrades will depend on the power goals.
I recommend you start by picking a custom tuner and talking to them about your goals. They will recommend what to upgrade for a safe and reliable build.
https://x-ph.com/sale/
Phone number 702-494-9435
      09-13-2024, 06:51 PM   #6
TopJimmy
TopJimmy's Avatar
Drives: 2023 M3 Comp xDrive
You can do E40-50 on stock fuel system with hybrid turbos. No other bolt ons needed, but you do need a custom tune since bigger turbos demand more fueling from the DI.
Right now I’m dialing in Paul’s Flex tune for upgraded turbos, which gives full power at E40-50, but can run up to E85 with limited boost (to keep fuel supply happy).
SE7EN335398.50
M4Tejas1081.00
      09-14-2024, 11:58 AM   #7
mike@x-ph.com
you should also upgrade the spark plugs to NGK and gap them correctly
      09-14-2024, 01:25 PM   #8
TopJimmy
TopJimmy's Avatar
Or re-gap your OEM/BMW plugs since they are NGKs, as long as they are clean and were used for
M4Tejas1081.00
      09-15-2024, 01:46 PM   #9
mike@x-ph.com
Hmm i was not aware its okay to recap the stock ones, G80/F80Paul keeps telling me to buy new ones
      09-15-2024, 01:54 PM   #10
chris3g
chris3g's Avatar
3157
Drives: 2023 M3 xdrive
The oem plugs are ngk 96206, it’s the same plug except it says bmw on it.
M4Tejas1081.00
      09-16-2024, 07:35 AM   #11
markoz28
Drives: BMW 2017 340i, BMW 2020 M340i,
Maybe he is saying to replace them since they have some miles on them. It’s ideal for an engine like this to change often. Especially with upgraded power levels. I’m going to change mine every 10k. Cheap insurance.
      09-18-2024, 09:24 AM   #12
mikewho_G82
mikewho_G82's Avatar
321
Drives: G82X
if you are looking for max effort, you should consider an upgraded LPFP (maybe pfs drop in) and port injection. more importantly work with a knowledgeable tuner who can help you with the right set up to meet your goals and budget.
here is some more information on S58 and power levels.
https://www.bendcalibration.com/blog/s58-build-path
      09-18-2024, 11:55 AM   #13
mike@x-ph.com
im FBO right now with E30
I will be upgrading to a custom map and E50
After that, I will upgrade my turbos.
Then go PI and another custom map
its going to take a year or so but i hope by the end i will have the comparison between all the different stages with the pros and cons of each
