05-10-2024, 11:34 AM | #1 |
Bmw340i Mppsk, bm3 tune,vrsf downpipe dinan intake
100
Rep 192
i need help
im having a very weird issue, and this only happens sometimes. i would say when the car is cold like every 1-2 week i start car get drive train malfunction and it does this weird idle thing and sputters when im driving it my only mods are a m3 cs tune and dahler piggy back. often times i start it on off and it goes away or turn it off and come back after 5 minutes and its gone is it a sensor issue ?
|340i mppsk dinan intake vrsf catted downpipe|
|full alcantera carbon fiber interior| |bootmod 91, 93 and full e85 tune stage 2 agg| |firehawk tires and hawk perfomance brake pads | |bimmer code, | upgraded spark plugs full carbon exterior |
05-10-2024, 11:41 AM | #3 |
100
Rep 192
what obd2 should i get to do this
05-10-2024, 11:44 AM | #4 |
Rep 1,356
05-10-2024, 11:45 AM | #5 | |
100
Rep 192
05-10-2024, 11:57 AM | #7 |
Rep 1,049
Take that bullshit piggyback off and see if the issue persists. If it doesn’t then it’s either that box or the connections for it were loose or something along those lines.
If the issue persists, then it’s something causing a misfire… either fouled up spark plugs because your fueling trims are too rich from the piggyback and you don’t drive your car hard enough to keep them clean on a regular basis or it’s possibly a leaky injector again flouling things up and causing misses. Ideally, you’d scan it for codes to see specifically what’s up like others have suggested, but if you don’t go that way your only other manual troubleshooting choices are what I suggested. Also, when you say an M3 CS tune, do you mean the trans flash and chassis coding or do you actually mean you’re running the CS DME tune via BM3 and then the piggy back on top of that for some goofy reason? |
05-10-2024, 12:00 PM | #8 | |
100
Rep 192
05-10-2024, 12:12 PM | #9 | |
100
Rep 192
GolfCoyote708.00 |
05-10-2024, 12:13 PM | #10 |
Rep 1,049
While you’re waiting, you could unplug and replug each of the piggyback connections that are made to the stock harness/sensors to make sure they’re clicked in place well. Someone on here posted something similar to this with running a piggyback and having goofy connections on the hardness. I think their piggyback company replaced their harness or something, but I can’t remember if it was Burger or Dahler that they had.
05-10-2024, 01:11 PM | #11 | |
100
Rep 192
05-10-2024, 03:11 PM | #12 | |
Rep 500
Isnt' the Dahler just a re-popped Racechip? It should come w/ a plug that takes it back to stock. I'd try that along w/ checking connections. |
05-10-2024, 03:37 PM | #13 |
100
Rep 192
05-11-2024, 08:53 AM | #14 |
Rep 1,954
Not for reading codes, wifi is also annoying to connect, bluetooth connection is instant. I had both and returned the wifi dongle.
05-11-2024, 10:56 AM | #16 |
Rep 2,765
A wired ENET is better than everything. It works fantastically for me. Quickly to connect, read codes, code in changes, flip through menus, etc. All instant. Plus the connection is a bit more stable for me.
Wired ENET into a USB-C/Lightning to ethernet adapter. |
05-11-2024, 11:19 AM | #17 |
Rep 1,049
^^^ I may be old school, but I also agree with this. When messing with flashing anything, a direct cable connection is the most trustworthy as you don’t tend to run across the extremely rare possibility of one connection interfering over another should something pop up and the Bluetooth or WiFi stack takes a dump on you.
05-11-2024, 11:43 AM | #18 | |
Rep 191,471
But for some reason, I had better luck with the adapter. As soon as I got the official PTF adapter, I didn't have any connection issues (I tried the cables and another type of adapter for years and always had problems with the connection).
