05-04-2024, 09:36 AM | #1 |
Rep 7
Best bootmod3 map for stock g80
Noob question here. I've got a '23 M3 Comp Xdrive, bone stock. Just bought BM3 - shipping ECU out to Femto soon. Which OTS map do you all suggest? I don't really want to mess with downpipes, etc. But I want more power (and prefer lower end/0-60 over 60-120). I'm in Orlando and can get 93 pump gas anywhere, as well as one nearby station with E85, but don't want to be limited on where I have to buy gas. Is OTS stage2 93 octane the way to go? Thanks for your help.
05-04-2024, 10:30 AM | #2 |
Rep 1,050
Without a downpipe, stick to Stage1. Since BM3 gives you one free map, you can either burn that on the Stage1 map or you could run the factory CSL map on the car (which is free and would give you a bump over your stock power level) and then truly decide if you wanna go downpipes or not and if you do, then you can burn the free map credit on Stage2 instead.
hellcat2m4228.50 |
05-04-2024, 01:19 PM | #3 | |
Rep 337
05-05-2024, 07:08 AM | #4 |
Rep 5,204
I’d pick Stage 2 E30 tune since you have Ethanol available (fun fast map), and take the free CS+ tune (daily).
If you don’t want to mix fuels just get the Stage 2. Your cats will be fine, just turn burbles down or all the way off.
05-05-2024, 01:22 PM | #5 |
Rep 7
I feel like once I have a fast tune, would I ever want to flash back to anything else? Seems like I’ll only want more. Or are the stage 2/e30/etc tunes not great for smooth daily driving?
05-05-2024, 03:58 PM | #6 |
Rep 117
Spend 100$ on the map pack… gives you some room with adding mods prior to a custom tune. I ran the multimap stage 1 tune for a while and ran a best of 10.5 at 130 with a 7.9 60-130.
I just added downpipes and moved to stage 2 with the e50 tune… haven’t run the 1/4 yet but the 60 to 130 is a 6.8 now…. But it’s also waaaay hotter… I’m in Fl too over in Tampa. Going to do a custom tune next… then finish up the exhaust. |
05-05-2024, 09:56 PM | #7 |
Rep 5,204
Plenty smooth for daily. The CS+ is free, for when you’re not near any E and need to run 93.
05-06-2024, 11:45 AM | #8 |
Rep 191,471
Get catted downpipes and run stage 2 93 maps, it's fast and reliable and won't cause any issues.
If you do not wish to mess with the downpipes, select the stage 1 93 if you want to mix E85 every now and then, select the multi-map
05-06-2024, 04:50 PM | #9 |
Rep 7
Thanks for the replies. Yeah downpipes feels a bit much for my intended use (no track, daily, etc). Once I get bm3 flashed, what are benefits of taking to a tuner? I’d likely use orlandoautowerks since they’re local. I assume they’ll pull more juice out of it than I could on my own. Again, forgive the dumb questions. Just getting started in this tuning world.
05-06-2024, 05:39 PM | #10 |
Rep 5,204
If you’re using Bootmod3 and an OTS map then a shop is NOT going to get you one more HP than you would if you did it all yourself.
Now if you’re doing a custom tune then a shop or tuner might do the initial map, and then want you to do the logging and revs by email. Some shops go drive for you and hand you a finished tune. Other shops sell you “their tune” which is a slightly hotter version of the BM3 OTS (example: Cary Jordan OTS tunes) but they don’t do any revisions to tweak it to your car. If you have a good safe spot to do rips and collect log data then I suggest you work with a remote tuner (Paul) and do it all yourself. It’s easy, and it’s very satisfying to talk/email with your tuner and learn where your car’s limits are. If you want to go this route we can talk on the phone and make a plan.
05-06-2024, 08:48 PM | #11 | |
Rep 191,471
Going with a custom tuner should yield more results without sacrificing reliability since your tuner will tweak the map based off your datalogs
05-07-2024, 10:57 AM | #13 |
Rep 191,471
You can use stage 2 with HJS downpipes
05-10-2024, 01:44 PM | #15 |
Bmw340i Mppsk, bm3 tune,vrsf downpipe dinan intake
100
Rep 192
your saying without downpipes ? you wil be fine
|340i mppsk dinan intake vrsf catted downpipe|
|full alcantera carbon fiber interior| |bootmod 91, 93 and full e85 tune stage 2 agg| |firehawk tires and hawk perfomance brake pads | |bimmer code, | upgraded spark plugs full carbon exterior |
05-10-2024, 01:50 PM | #16 |
Rep 191,471
The OTS maps are very conservative. You can probably get away with stage 2 if you turn the burbles down, but it's not recommended to run it with stock downpipes.
05-10-2024, 02:20 PM | #17 |
100
Rep 192
just put the burbles on 0 lmaoo
05-10-2024, 02:31 PM | #18 |
Rep 5,204
Exactly. Keep the burbles off, or keep your aggression settings at 5 or less. As an example the CS burble settings look like Agg=3 on Efficient/Comfort and Agg=5 on Sport and Plus.
05-12-2024, 04:18 AM | #19 |
Rep 239
Burbs help keep the turbo spooled between shifts! No idea which settings translates to the min you need to take advantage though. Anything but the lowest settings are likely more suited for a Spoon engine.
05-12-2024, 08:04 AM | #20 |
Rep 5,204
Burbles don’t help spin turbos. Its fuel going out the exhaust for a sound effect. Backpressure spins turbos.
05-15-2024, 12:02 PM | #21 | |
Rep 239
Anyway, anti-lag systems function by dumping a bit of extra fuel in after lift. This fuel ignites in the exhaust manifold creating extra heat and exhaust, keeping the turbo spooled. This combustion happens in a much less controlled manner than in the cylinder.. many small pops as pockets ignite. Burbles. Most burbles you can hear are cosmetic as you really don't need much for anti-lag, but at the core idea can and is certainly be used for performance. |
