05-02-2024, 11:03 AM | #1 |
Rep 41
Optimal settings for XHP
Guys
G82 RWD 8 speed, i installed stage two XHP - one thing that drives me absolutely nuts is when I'm in Sport + it jolts when changing gears.,. Feels liker driving a really bad old manual car and i want to get rid of it.. is there a setting that will allow me to disable it? i want the exact same tune just without that silly addon. also are there custom maps for XHP? like CSL one or stage 2 tuner car one etc. had it only few days so still learning thanks in advance |
05-02-2024, 01:27 PM | #2 |
Rep 90
I don't have XHP but I saw several posts that u need to be over a certain throttle opening when you are at Splus mode. The jolt you are feeling is because you are upshifting when the throttle is not open enough. I bet it is shifting lot smoother when you are in Sports plus mode but also at 80 to 100 percent throttle.
05-02-2024, 03:48 PM | #3 |
Rep 1,051
If you’re unhappy with that XHP shit, ask for a refund and then go pay Kubax to flash the CSL factory trans image onto your box. It’ll drive much better and without the bullshit XHP is sometimes known for because all they are about is WOT and not varying degrees of drivability out of their tunes.
05-03-2024, 12:40 AM | #5 |
Rep 283
05-05-2024, 03:00 AM | #6 | |
Rep 41
05-05-2024, 07:54 AM | #7 |
Rep 90
I see. I prefer to do 60-130 runs by starting in the right gear. The gear that will give me the maximum acceleration rather than just flooring the pedal and letting the car downshift from like 8th to whatever gear ... even on stock configuration I never liked the car felt when I did that. I like to be in the right gear, car screaming at 6k or so then floor the pedal. That way car won't downshift no more.
05-07-2024, 05:36 PM | #8 |
Rep 5,204
Luk what are your settings. Give us all details.
05-08-2024, 09:05 AM | #9 | |
Rep 41
05-08-2024, 09:07 AM | #10 |
Rep 41
its stage 2 out of the box, i didn't adjust a single thing also didn't do any of the edit settings like launch mode etc just simpla stage two flash, got race chip gts black running and that is it
does that help or do you need some screenshots? |
05-08-2024, 09:55 AM | #11 |
Rep 5,204
There it is…RaceChip. Its probably interfering or sending unexpected values to the DME. Try disabling the RaceChip or take it out of the loop, then try, and report back your results.
05-08-2024, 10:06 AM | #12 | |
Rep 1,051
All that said, RaceChip is probably the absolute worse piggyback you could pick to run, if you had to run one, which I wouldn’t in a million years. Take it out and see if the problem persists and if it does, then you have recourse to go back to XHP and bitch and complain. If you feel they’re being unfair in taking back their product that doesn’t work for you and they’re also refusing to work with you on a solution, then simply do a chargeback with you CC company and then stop using their software. If they were a respectable business they’d stand behind their product and allow people to return it if there’s some kind of incompatibility issue with it and various tuning options people might choose for these cars. If they wanna be dickheads, be a dickhead back. It’s not like you bought it months ago… it’s 7 measly days! |
05-08-2024, 10:11 AM | #13 | |
Rep 242
05-10-2024, 05:57 AM | #14 | |
Rep 41
no i said this to XHP as they just say disable it but c'mon if it doesn't work with piggyback devices why not to put it in big bold capitals that it might cause issues.. they don't want to take it back and say they will promise to help but so far they only advice is to either disable it , change settings to less aggressive oh and they want to see a video of the car jerking when changing gears, like what is that going to help you with ? you will see the car shakes with a gear change... |
05-10-2024, 06:34 AM | #15 |
Rep 9
I’ve been tinkering with XHP for the better part of the past week on my G82. If you decide to get it, you should absolutely go into this with the expectation that you will be using Stage 3. Anything below that absolutely is not worth it (shifts are weaker and take noticeably longer than Stage 3).
After getting some support from XHP and flashing different settings at least 25 times, I’ve gotten the car down to a level that is 80% acceptable to me. The key to minimizing jerks in Stage 3, is to set “Reassign Shift Speeds” to “Medium” for all three modes (Standard, Medium, Fast). Also make sure Ignition Cut Shifting is off. I’m still playing around with Torque Reduction settings (decreasing them produces less jerk, per gear). I wouldn’t go below 25% though because of the extra clutch wear disclaimer in their docs. I will say the 3rd to 4th shift is still too aggressive at times with the transmission in S3, especially under load. I find myself pulling off the throttle before shifting just to avoid the jerk, but the downshift blips (which I’ve maxed out to +50% across all gears) are way too addicting for me to not use XHP now. Dare I say, the blips almost sound Porsche-PDK level now… If you’re driving around in D1/D2/D3, these settings will keep you very happy in Stage 3 since there’s no jerk at all. It’s only S3 that’s the issue. |
05-12-2024, 07:54 AM | #16 |
Rep 41
05-12-2024, 07:56 AM | #17 | |
Rep 41
05-12-2024, 09:10 AM | #18 |
Rep 5,204
My current XHP optimal settings:
(for Drag Racing and Street Rolls) Drag Race Mode = High Custom Launch = +5 and +5 and Off 2nd Gear = On, On and Off Line Bump = On Stop-Go = On Auto Start/Stop = Off Shiftmap Editor = Custom D upshift: +15, 12, 10, 8, 7, 4, 0 downshift: +20, 15, 10, 5, 4, 2, 0 Custom S upshift: +25, 22, 20, 18, 17, 16, 14 downshift: +35, 20, 15, 12, 7, 3, 0 It’s just what works for me. I’m still playing with the shiftmaps, but the D settings are pretty much dialed in. The 2nd gear starts are great because it avoids a drone spot in my Goliath, which now sounds much better.
05-14-2024, 07:59 AM | #19 |
Rep 12
For those that didn't know there is a confluence for the 8 speed and it explains a lot of info for the various parameters.
https://rbttuning.atlassian.net/wiki...Flash+Settings |
05-14-2024, 09:52 AM | #20 |
Rep 5,204
Our man kern417 created two excellent YouTube videos for the ZF8 on his car.
Part 2 - XHP custom settings https://youtu.be/bqGSePe-vxo?si=PljneU2S06lj68x_ Part 1 - Basics and what is XHP https://youtu.be/G176o7Cj9oU?si=cDS1vwI4JUiHzUL7
dvlg8025.50 |
05-14-2024, 02:16 PM | #21 | |
Rep 41
