02-27-2024, 05:15 PM | #2 |
Rep 18
I run 9.5" ET25 for my summer set on 255/35/19 without issue but not sure if ET30 would have an impact. I believe the upper limit is 265mm for the fronts.
Personally, I would have preferred a 9" set if the availability had been better at the time when I was shopping because at 9.5" I wouldn't go any lower than 255mm due to the amount of sidewall stretch that comes along with it. |
02-27-2024, 05:18 PM | #3 |
Rep 355
this is a good write up from Apex (it should apply to all wheels, not just theirs):
https://apexwheels.com/fitment-guide...guide#overview |
capturedbysebastian16.50 |
02-27-2024, 06:57 PM | #6 | |
Rep 1,741
02-27-2024, 08:13 PM | #7 |
Rep 355
if they're the only option you have and you are set on those wheels, buy them and test it out. if it doesn't fit, just buy spacers. afaik, it shouldn't matter what size the spacers are as long as you get the matching length lug bolt (obviously don't use the stock ones) and you are probably not going like 10mm spacers lol. it might poke out the fender line tho...
