02-05-2024, 05:37 PM | #1 |
![]() ![]() ![]() 309
Rep 387
Engine dress bolts torque specs?
Have the deluxe Downstar Titanium kit - wondering if there is a consolidated document of all the torque specs?
really only curious on the larger bolts - such as a strut bolt and center brace bolt. All the little stuff - tightened snug. |
02-06-2024, 04:24 AM | #2 |
![]() 2379
Rep 1,956
Drives: Many, BMW.
If you can’t torque them to spec, especially the chassis reinforcement ones…. 🍚
05-23-2024, 07:22 PM | #4 | |
Rep 387
Little ones 11.8nm / 8ft lbs 41lbs plus 90 degrees for 4 E18s Center angle 41lbs plus 90 6 along top 20 ft lbs 4 outter edge 20 ft lbs Strut tower 20 ft lbs plus 120degrees Headlight are 11.8nm Center brace top 41 plus 90deg The hood cant recall.. |
am4relo_g8245.00 M4Tejas1090.50 |
01-10-2025, 09:24 PM | #5 |
![]() 45
Rep 18
Drives: 2024 M4 Competition XDrive
Does anyone know what the torque spec is on the bolts circled in the attached photo?
Thanks! |
01-11-2025, 10:12 AM | #6 |
Rep 387
01-11-2025, 12:37 PM | #7 | |
![]() 45
Rep 18
I only ask because I also posted to a FB group and got a response of 56nm + 90° for the OEM bolts. I have been holding off on replacing the those with the downstar versions until I had this info. Thanks again! |
01-11-2025, 12:52 PM | #8 |
Rep 2,208
Posts ![]() |
you can't really just swap steel bolts for titanium and apply the same torque + angle spec , the whole point of a torque + angle value is to ensure a specific clamping force that accounts for bolt stretch. but titanium and steel bolts stretch very differently, and the resulting clamping force will not be the same.
01-11-2025, 05:04 PM | #9 | |
![]() 45
Rep 18
01-12-2025, 09:53 AM | #10 | |
Rep 387
01-12-2025, 09:56 AM | #11 | |
Rep 387
01-12-2025, 10:06 AM | #12 | |
![]() 45
Rep 18
So, any idea what I should torque the Downstar replacements to? Or should I just leave the OEM bolts in place? Downstar really should supply this info with their bolt kits. Thanks again! |
01-12-2025, 10:12 AM | #13 |
Rep 387
Downstar really should.
With nothing else to go by. I figured one could just tighten to what one feels is good enough or target OE. I chose target OE. Chris is right though different bolts will have different clamp. Is there another option when installing titanium? For steel bolts you are likely closer to spec. |
am4relo_g8245.00 |
01-12-2025, 10:57 AM | #14 |
Rep 2,208
Posts ![]() |
i actually forgot that downstar makes the bolts in both steel and Ti. with the steel bolts i would probably just try to get it as close to the oem spec as possible. those downstar replacement bolts are using 8mm hex heads as compared to the oem etorx E18, and you may not be be able to get the full 90deg angle on them. if you're concerned about that i would just leave those stock.
M4Tejas1090.50 am4relo_g8245.00 |
01-12-2025, 03:47 PM | #15 | |
![]() 45
Rep 18
Thanks guys! Really appreciate all the input. |
01-18-2025, 12:37 PM | #17 |
![]() 45
Rep 18
Installed the last few Downstar bolts today. Here’s the finished job. I went with navy blue washers to give a bit of blue highlights to the engine bay. My calipers are blue and I have the Yas Marina Blue/Yellow interior. So you can see the color theme of my car.
Thanks again for the info folks. Much appreciated. |
