01-27-2024, 08:44 AM | #1 |
Rep 1,673
I just came out of break in. Today I tried a couple WOT launches. With and without launch control. I had a second gear grind. I had a similar issue with my F80 manual. I've read it could be driver error or shift slightly slower. I'm wondering if CDV delete would improve the situation.
Surprisingly, my 0-60 times are no better than my F80 - 4.86-5.0. Although, I'm still learning how to best launch the G80. I have brand new Michelins and the temp was about 45 delgrees. Road may have been damp.
18' F80 6MT, 991.1s cab PDK, F83 6mt, 996 C4S cab 6mt, F30 328iM 6mt
E60 M5 SMG, E39 M5, E46 M3 cab 6mt, E36 M3 5mt |
01-27-2024, 09:16 AM | #2 |
Rep 5,209
Was it a synchro buzz on the 1-2 shift (or on 2-3 if you started in 2nd)? You go to shift fast and get…buzz!buzz!…then the shifter goes into the gate right.
The MT6 is known to twist the mounts under heavy load. On my F80 it was fixed with Rogue Engineering mounts (easy fix, and under $75 for the parts). I believe the G8X manuals have the same trans mounts, so I would try the Rogues in your case.
01-27-2024, 09:53 AM | #3 |
Rep 1,673
It’s the 1st/2nd shift. I’d say it sounds like a synchro. Same as my F80.
01-27-2024, 11:41 AM | #4 | |
Rep 1,673
01-27-2024, 11:43 AM | #5 |
Rep 1,673
Well a little practice helped. Just got 3.96. That’s a full second better than my best time in my F80. I’m sure I can beat the claimed 0-60 time of 3.8.
01-27-2024, 11:52 AM | #6 |
Rep 515
I have CDV delete on my G82 after break in service. It make a big different from 1 to 2, 2 to 3, 3 to 2, 2 to 1. CDV delete totally worth it.
01-27-2024, 12:10 PM | #8 |
Rep 81
01-27-2024, 01:11 PM | #9 |
Rep 1,673
Only midpipe and Dahler. Launching a manual is always tricky. Between bogging down or spinning it takes some time to get it right. I’ll keep trying. So far, I was quicker without launch control.
01-27-2024, 01:50 PM | #10 |
Rep 142
Curious who you guys are making an appointment with for the CDV delete and if that's going to raise any red flags for BMW when it comes to warranty work.
I plan on doing some of these mods and was thinking I'd wait until the warranty is up but I'm not sure I can be that patient. I'm not a fan of how this feels when I want to rip through the gears... |
01-28-2024, 06:53 AM | #11 | |
Rep 1,673
Turbodu07185.00 |
01-28-2024, 07:08 AM | #12 |
Occasionally frequent poster
3012
Rep 2,746
Is only a warranty issue if you go in with complaints about the slave cylinder or clutch.
Current inventory:
01-29-2024, 08:50 AM | #13 |
Rep 2,142
Yeah, I've noticed this on my F87 when rushed into 2nd gear. Hated that grind!
I've had maybe 1 instance where it was trying to exhibit the same grind on my G82. Now I just don't shift that fast. |
