01-18-2024, 03:10 PM | #1 |
Rep 9
Ventilation / cooling of the brakes for racing
Hi.
I'm thinking about how to improve of the brakes. Very necessary for the raceway. The brakes g82 are overheat quickly and I feel anxiety arises. I found several solutions. If anyone has already done this for themselves, give advice? Which is better – 1) brake duct package - air channels or 2) carbon fiber brake ventilation plate-gills? 1) Speed Engineering Front Brake Cooling Complete Set Front Speed Engineering thinks new in their ideas, developments, designs and products. Speed Engineering's standard is the extremely high demands in motorsport, which is reflected in every work step, whether in motorsport or off the race track Video Rear or 2) Alpha-N G8X M2 / M3 / M4 Carbon Brake Duct Shield Set ncrease brake cooling without clumsy hoses and zip-ties. Alpha-N's carbon fiber brake duct shield set (2 pcs. left + right) for the G8x M2 / M3 / M4 front brakes include an integrated scoop and duct to catch and direct incoming air from your factory brake ducts into the rotor hat where it's most efficiently used, being pumping from the center out through the rotor vanes. |
01-18-2024, 03:50 PM | #2 |
Rep 3,502
Drives: 2025 X5 M60i, 2019 F87 M2C
There's a cover in the front wheel liner that allows for extra air that should be removed when you need extra cooling.
Did you try that? |
01-18-2024, 04:16 PM | #3 |
Rep 9
Do you mean the plastic deflector on the fender liner wheel? I removed it, but the window is quite small.
Look at this article – very well described about ducts and brakes https://www.essexparts.com/news-blog...n-my-track-car So, I'm wondering if ducts should be build or the suport OEM should be replaced for AR. |
