11-29-2023, 10:42 AM | #1 |
Rep 59
Exhaust Cutouts M60i
So... I've decided instead of messing with removing the resonator or mufflers etc. to solve the exhaust sound issues, i'm just going to go with electronic cutouts.
Has anyone done these? Also, any recommendations on which kit to go with? |
11-29-2023, 11:34 AM | #2 |
Rep 148
11-29-2023, 01:05 PM | #3 | |
Rep 59
11-29-2023, 01:12 PM | #4 |
Rep 148
11-29-2023, 01:29 PM | #5 |
Rep 59
Been researching and this is the kit I think I will order: https://quicktimeperformance.com/i-3...l#!year%3D2023
11-29-2023, 01:30 PM | #6 |
Rep 59
11-29-2023, 04:17 PM | #9 |
Rep 3,706
No. Doesn’t require a time. The one I have, on my other bmw, it is plug and play, like a small device intercept between oem wiring and the oem flap. I can use remote to permanently open the flap instead of modulate the flap base in throttle condition. Very simple DIY.
2022 G05 B58/PHEV
+ a few very old BMWs |
11-29-2023, 04:29 PM | #10 |
Rep 148
11-29-2023, 04:57 PM | #11 |
Rep 3,706
No, totally not related. Max boost pressure is set in ECU, and control by as you said boost controller. It is in act all the time. Turbo spin rate, if you will, is control by turbo waste gate, which is also control by ECU. Reducing back pressure doesn't change the upper limit. It may actually improve turbo spin up time.
2022 G05 B58/PHEV
Bottom1615.50 |
11-29-2023, 05:45 PM | #13 |
Rep 59
11-29-2023, 07:36 PM | #14 | |
Rep 148
https://youtu.be/o39yqlMJYG0?si=_lVz8U076J_jXJVd |
11-29-2023, 07:40 PM | #15 |
Rep 148
Highly unlikely it will reduce boost, the exhaust system is now more efficient, thus it can clear air out faster allowing the turbo to spin faster, sucking in more air. In theory, you could run less boost (pro tune) with this setup and put out the same power which would be less stress on the turbos.
11-29-2023, 08:22 PM | #16 | |
Rep 3,706
2022 G05 B58/PHEV
11-30-2023, 10:46 AM | #17 | |
Rep 148
