11-03-2023, 12:51 PM | #1 |
Rep 576
Drives: XM/XB7
Mirror Tap to Radar for XM
Today I installed my radar detector with power tapped from the rear view mirror. Took 20 minutes because I didn’t want to break anything and was very careful. Pictures included to show you where the tabs/clips are in the three piece plastic enclosure at the base of rear view mirror. Remove large plastic piece that is below roofline by gently wiggling and pulling down from headliner to release larger clips. Once that is removed, separate left and right pieces around mirror from top of windshield down taking care not to damage tabs. Find wires connecting to mirror harness to tap into. Red with red, black to brown. Button everything back up in reverse order and enjoy!
11-03-2023, 03:12 PM | #2 |
Rep 5,796
Drives: 2024 BMW XM Label
My new MirrorTap will be here today. Unfortunately mine broke off when I was removing it from my iX. The wiring harnesss definitely look different between the two vehicles. Note that there are two different wiring harnesses in the mirror column. You may have tapped into the other one. I’m glad you posted this because I don’t know where my test light is!
r33_RGSport12996.00 XM Label915.00 |
11-03-2023, 09:40 PM | #3 | |
Rep 576
Drives: XM/XB7
VirtualGuitars7862.00 |
11-03-2023, 09:42 PM | #4 |
Rep 5,796
Yeah, that’s the one you want. Those 3 trim pieces come off pretty easily. It’s the same exact housing as the iX and after further inspection, the wiring harnesses do look exactly the same.
11-05-2023, 12:32 PM | #5 | |
Rep 5,796
11-05-2023, 02:18 PM | #6 | |
Rep 576
Drives: XM/XB7
11-05-2023, 02:22 PM | #7 | |
Rep 5,796
Now I get to order a new panel. Grrrr. |
11-05-2023, 03:13 PM | #8 | |
Rep 576
Drives: XM/XB7
11-06-2023, 08:42 PM | #10 |
Rep 5,796
I wish they made the pins a little stronger on these MirrorTaps. They bend way too easily and aren’t always easy to push into the wiring harnesses - especially for those of us with larger hands and not much room to work with.
I still don’t see how you were able to get into the harness underneath the mirror! It’s a really awkward angle and I can get back far enough to see it! I’ll keep trying from the top harness although it’s really tight getting my hand up there. |
11-07-2023, 05:24 AM | #11 |
Rep 576
Drives: XM/XB7
Wasn’t easy holding that position. Was definitely awkward. Also had to use smallest pin set which is different than my previous BMW installations because there was not a lot of space in the harness to tap into. The larger pin set I used for my X5M comp didn’t fit into XM.
11-07-2023, 07:06 PM | #12 |
Rep 5,796
For anyone else doing this on the XM, this is the harness that is the easiest to tap into. There’s four wires in this harness and It’s the two wires on either end. Connect the MirrorTap’s red pin (positive) to the orange wire with the stripe (accessory power), and connect the MirrorTap’s black pin (negative) to the brown wire (ground). It’s a little challenging get your hand up there with enough leverage to push it in, but it will work with enough patience. This is the same same harness and wire pair used on the iX.
This is the one that I’ve been using on the past 3 or 4 BMWs: MirrorTap®, MT-4015, 15" Radar Detector Power Cord with 2AMP Inline Fuse, BMW Tap Size, RJ11 Plug https://a.co/d/35a00ii |
XM Label915.00 |
11-08-2023, 03:39 AM | #13 | |
Rep 576
Drives: XM/XB7
11-09-2023, 02:20 PM | #14 |
Rep 5,796
Finally got around to finishing this little project. This is just temporary though, I need to reinstall both pairs of the front and rear Escort laser shifter sensors which will end up integrating and powering the detector on its own.
Here is what I current have that was carried over from both my M550 and iX M60: Escort MAXcam 360c: https://www.escortradar.com/products/escort_maxcam_360c Escort ZW5 Laser Shifter with Direct Wire: https://www.escortradar.com/products...rd-direct-wire Escort Laser Shifter Add-On Pack: Must call Escort directly to purchase. BlendMount BMG-2036: https://blendmount.com/aluminum-rada...nt-custom-fit/ MirrorTap MT-4015: https://blendmount.com/power-cord-mt...25-lg-mt-4015/ |
XM Label915.00 |
11-17-2023, 05:01 PM | #15 |
Rep 5,796
Finally going to be reinstalling my ESCORT ZW5 laser shifters reinstalled this weekend. This is what they looked like on my M550 (front and rear sensors). Totally illegal AF in Texas, but so is my windows tint. 😂😂😂
11-19-2023, 06:13 PM | #16 |
Rep 840
Thanks for the instructions, which worked the same on my X7 M60i LCI. I tapped into the harness from behind the mirror as the OP did.
11-19-2023, 06:16 PM | #17 |
Rep 5,796
For the next one, it’s so much easier to go from into the harness on the top/front. It’s literally right there in your face. It’s the wires on both ends.
